Old 07-24-2011, 09:15 PM   #1
geist
Member#: 111197
1995 Lexus SC300
Default Misfiring on all 4 Cylinders, looking for ideas/advice.
Hey all,
Trying to pinpoint an issue that's a little tricky!
Lets start with some quick info:
2005 WRX STi, 105,000 Miles.
Car drove fine one day, and then, abruptly one morning decided to "chug" and then throw the CEL light on.. Access port reported misfire on all 4 cylinders, and now when driving the car, it idles roughly, and "chugs" intermittently.. (feels like hitting fuel cut but not as aggressive.)
So far my mechanic has:
Replaced the plugs (oem)
Done a leak down test (Came out great)
Checked the gas for water
Checked the crank sensor
Confirmed that it's not the altenator
Confirmed that it's not the battery (though I need a new one)
Reflashed ECU with Cobb AP2.0
Next gonna test for the camshaft sensors, though wouldn't it only toss half the cylinders if one was bad? (Don't think they'd both die out at the same time.)
Only other thing I could think of is maybe a vacuum leak somewhere?
I haven't had a chance to discuss that in length w/ my mechanic yet...
Only mods to the car are turbo-back, and AP2.0 running off the shelf stage 2 91octane, by the way...
Any thoughts, ideas or experience with the same issue would be appreciated!
(ps yes I searched; all other threads either didn't have the answer or were inconclusive in one way or another! )
geist is offline   Reply With Quote
Old 07-25-2011, 12:19 PM   #2
fmauriwrx
Member#: 154806
2011 SWP WRX
Check the knock sensor. One time I had this happen and the bolt holding the knock sensor was loose resulting in it picking up crazy readings.
fmauriwrx is offline   Reply With Quote
Old 07-25-2011, 04:20 PM   #3
geist
Member#: 111197
1995 Lexus SC300
Of all things, apparently the wire mesh on my air filter managed to chafe its way through a harness wire!?
Glad it's fixed either way, thanks for reading kids!
That being said, for the records (if anyone ever uses that search feature I've heard so much about.) and you happen to have a cone type filter on the car... mines a TXS... Check around it for abrasion!
Thanks for looking and everything!
Old 07-25-2011, 04:57 PM   #4
fmauriwrx
Member#: 154806
2011 SWP WRX
Glad to hear it was a simple fix! All four cylinders misfiring would definitely scare me a bit.
Old 07-25-2011, 05:38 PM   #5
Paidfor
Member#: 267815
Be in awe
dont hate .)
^^^^I dont know.....id almost be glad to see all 4 misfire instead of just one. That way i know its a issue conecting all cylinders (TUNE) as opposed to just one(Bad ringland) lol I don think ive seen anyone blow all 4 ringlands off there pistons lol But give it time, im sure someone will.
Paidfor is offline   Reply With Quote
Old 07-25-2011, 05:50 PM   #6
sc00ter
Member#: 117767
2015 WRX
CWP
I couldn't agree more. As soon as I saw an "issue" with all 4 cylinders I would be relieved instantly knowing it's gotta be a simpler fix than an issue with just 1 cylinder like you mentioned.
sc00ter is offline   Reply With Quote
Old 07-25-2011, 05:53 PM   #7
fmauriwrx
Member#: 154806
2011 SWP WRX
Good point. Didn't think of it that way!
Old 09-12-2013, 12:45 PM   #8
06_Hawk
Member#: 358195
Default All 4 cylinders misfire
Hey guys my 2006 sti had started jumping and misfiring recently. didn't throw a CEL at first now it has. When it first started doing it, it wasn't so bad now its doing it in low RPMs and more when im making a turn and its a quite bit rougher as well. Replaced all spark plugs changed some coil packs, checked harness and wires going to coilpacks, and changed the tune. What do you guys think?
Mods are Invidia N1 exhaust and downpipe, COBB SF intake, and stage 2 tune off the shelf with the accessport.
06_Hawk is offline   Reply With Quote
Old 09-12-2013, 01:56 PM   #9
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20g-xtr 427/427 JJtuned
Does it run better now? Can't tell you what I think without that info!
Dave D. is offline   Reply With Quote
Old 09-12-2013, 03:53 PM   #10
Razgeiz
Member#: 358782
2013 STi
What a first post... have you tried reflashing your map? And what is the CEL?
Razgeiz is offline   Reply With Quote
Old 09-12-2013, 05:29 PM   #11
06_Hawk
Member#: 358195
No it doesn't run better. Sorry I left that out. Yes I reflashed it and nothing. But the CEL reads a misfire in all 4 cylinders.
Old 09-12-2013, 05:32 PM   #12
06_Hawk
Member#: 358195
No it doesn't run better sorry I left that out. Yes I reflashed it and the CEL reads a misfire in all 4 cylinders.
Old 09-15-2013, 12:58 PM   #13
Razgeiz
Member#: 358782
2013 STi
I just thought of this... have you cleaned the MAF??
Old 09-17-2013, 01:23 AM   #14
06_Hawk
Member#: 358195
Yeah I did thanks though
Old 09-17-2013, 11:34 PM   #15
lazyas07
Member#: 262886
99 rs
having this same issue with my 02 wrx. butu was also getting the egt code. easy fix for that was the 2.2 resistor from radio shack. but still have my misfire codes in all 4 cylinders. Read on a forum on her of someone having the same issue and it came out to be his diff that was throwing everything out of wack
lazyas07 is offline   Reply With Quote
Cold weather misfire on ALL 4 cylinders T WReX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 24 01-15-2010 03:49 PM
Misfires on All 4 Cylinders - Cold Weather Related StealthREX Service & Maintenance 16 11-07-2009 06:34 PM
Misfire on all 4 cylinders....why? skyline31 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 05-28-2007 09:11 PM
misfire on all 4 cylinders kettsupp Service & Maintenance 6 05-07-2005 09:09 PM
misfiring on all 4 cylinders tEkkGOD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 09-08-2003 09:26 PM
