Old 10-12-2011, 12:28 AM   #26
Dat8687
Member#: 243261
2004 WRX
Java black pearl
The pre-set on the Wastegate is 14.7 psi.. Is it possible to just throw this turbo on and leave the boost at 14.7 and not worry about running lean? Or do you have to do big in jectors if you keep the boost at 14.7 psi
Dat8687 is offline   Reply With Quote
Old 10-12-2011, 01:21 AM   #27
Mark2JZ
Member#: 83818
eventhough its the same pressure, its not the same volume of air. its not advisable to put on a larger turbo with stock injectors and think you cannot run lean.
Mark2JZ is offline   Reply With Quote
Old 10-15-2011, 11:17 PM   #28
Mark2JZ
Member#: 83818
sorry to bump this without hp/tq numbers yet......BUT, at least im installing it
out comes the VF39:
in goes this perty thing:
once everything is in i can schedule a tune. can't wait
Old 10-17-2011, 08:12 PM   #29
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
Looking Great Mark
Should be fun for you to go and chase some cars down at HPDE and Open Track days once its all installed and tuned
Kirill
RallySportDirect.com
RallySport Direct is offline   Reply With Quote
Old 10-18-2011, 12:36 AM   #30
Mark2JZ
Member#: 83818
^definitely kirill! those are my exact intentions for the build.
im stoked! just waiting on a spot to get a tune at yimi during the wait i think ill order a koyo......
Old 10-18-2011, 10:10 AM   #31
wrx50
Member#: 151714
06 WRX
Default Tomei
My 7960 is in my 06 WRX awaiting final tune. I will post impressions later today or tomorrow.
wrx50 is offline   Reply With Quote
Old 10-18-2011, 10:42 AM   #32
RallySport Direct
Member#: 33174
We are Open Late!
Mark, you should also consider getting a external oil cooler for the warmer months when you will be on the track. Its as important to keep the oil cool as water to help prevent thermal breakdown of the oil at high temperatures.
Cant wait to see your results
Kirill
Old 10-19-2011, 12:18 AM   #33
pooster.online
Member#: 120461
2004 WRX STi JBP
damn the Tomei definitely has to be the most beautiful/blingin turbo I've seen..
I definitely have to get my hands on one as soon as I get the funds!
any idea on how your gonna pass CA emissions every 2 yrs tho? I dont expect the visual inspection to be that oblivious that beautiful piece of art...
pooster.online is offline   Reply With Quote
Old 10-19-2011, 01:21 AM   #34
CT26SupraTurbo
Member#: 213393
2003 WRX
Tomei Powered
I'm pretty happy with mine.
M7760 with stock 2.0 liter!
Any other guys running tomei turbo?
CT26SupraTurbo is offline   Reply With Quote
Old 10-19-2011, 12:24 PM   #35
Thran
Member#: 63612
2004 dom 2.5 wrx
Rally Blue
cant wait to see your results
Thran is offline   Reply With Quote
Old 10-19-2011, 12:56 PM   #36
ArSoN9
Member#: 285777
2004 STi-
did you have any issues with fiting the turbo? I have heard the tomei's with their larger wastegate actuator hittin aftermarket heatshields and tmics...
lemme know how the install goes Im considering putting the larger m8265 in a bugeye
pumped to see the numbers it puts down
ArSoN9 is offline   Reply With Quote
Old 10-19-2011, 01:26 PM   #37
CT26SupraTurbo
Member#: 213393
2003 WRX
Tomei Powered
check out this/
http://www.rallysportdirect.com/Tome...MS-M7760-Turbo
off of my car
Cobb heatshield had to be bended out a bit. but I seriously won't even call that a "fitting issue". It fits Process West TMIC just fine but I can see it could be a potential problem with something bigger TMIC
Old 10-19-2011, 02:35 PM   #38
Mark2JZ
Member#: 83818
M8265 uses a slightly larger inlet, though not 3". an aftermarket silicone inlet will slip over it.
i only had to trim my oem heatshield a bit to clear the wastegate arm. otherwise everything fitted up just fine.
Old 10-21-2011, 06:54 AM   #39
FRWRX
Member#: 15306
2011 STi
White pearl
just received my 8265 today. it only took 2weeks since order.
i have to rebuild the engine and will let you know. it should take 3 weeks from now.
FRWRX is offline   Reply With Quote
Old 10-26-2011, 03:52 PM   #40
Blacksheep6
Member#: 239945
Any mumbers? I'm ordering the M8265 and I'd like to see how it performs.
Blacksheep6 is online now   Reply With Quote
Old 10-28-2011, 09:26 AM   #41
wrx50
Member#: 151714
06 WRX
Default M7960
car: 06 WRX stock block
tomei cams
tomei equal length header
jic exhaust
spearco top mount
04/05 six speed swap
spt intake (current weak link)
ported intake manifold
tomei m7960
hard inlet
tgv delete
hks down pipe
fuel pump
1000 injectors
22.5 psi at @ 4200 tapering to ~18 at redline
I always forget mods so I'ii update as I remember.
I have been driving with the above mods for a week now and can say I really enjoy the different between the vf39. I dont have any numbers, but I can say that boost builds much faster and I'm at full spool at 4200. On dry days the tires start to break loose into second gear (Rs-2). In my opinion, part throttle passing on the highway is the best. If Im doing 70 or 80 and give it a little more gas I'm in triple digits. In addition the turbo is a little louder which is nice. I hope to get a bigger intake so I'm not almost maxing out MAF and then hit the dyno. My butt dyno gives this turbo a thumbs up.
A quick thanks to Sammy and all the guys at Six Star Motorsports and Ryan for doing the tune.
Old 11-01-2011, 04:05 PM   #42
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Update?
Fierysun is offline   Reply With Quote
Old 11-01-2011, 08:38 PM   #43
Mark2JZ
Member#: 83818
im getting tuned nov 7th. one more week
Old 11-02-2011, 09:17 PM   #44
Dat8687
Member#: 243261
2004 WRX
Java black pearl
Cant wait
Old 11-07-2011, 11:42 PM   #45
Mark2JZ
Member#: 83818
nothing earth shattering. conservative tune by paul at yimi - 325whp/317tq
seems its basically a TD06-20G. the power comes on very linear, it doesn't have that huge torque rush that the stock VF39 does at very low rpms. Above 4.5k rpms its very strong, the HP curve doesn't drop off at all, all the way to redline. I wanted an autox/trackday setup, and this does the job. basically i have to get used to driving it again since the power comes on so smoothly, and my powerband moved up quite a bit in the rpm range.
overall im happy with it, just know that there are other choices for 325whp.
Old 11-08-2011, 10:43 AM   #46
RallySport Direct
Member#: 33174
We are Open Late!
Mark,
What boost level was this power made? And this was also on CA 91 octane correct?
Kirill
Old 11-08-2011, 11:34 AM   #47
Mark2JZ
Member#: 83818
19-20psi peak, CA 91 octane, yep.
the grimmspeed bcs is quite loud, lol
Old 11-08-2011, 02:33 PM   #48
Fierysun
Member#: 82745
2005 Subaru STI
That's a really flat HP curve from peak to redline. Looks like it can make alot more power with a more aggressive (non-track) tune.
Old 11-08-2011, 03:52 PM   #49
Mark2JZ
Member#: 83818
paul had it up to 333whp and backed off. my car seems to be on the low/average side of STi's. it made 277whp/320tq at stage2.
the difference in power is definitely there, but the power curve feels like a built MR2 that i used to have. very linear. the engine now loves to rev up top.
i haven't seen anyone dyno the M8265 yet, but maybe it will be laggier, and give better numbers up top? for me the power curve of the M7960 is about as laggy as i'd like for my intended use of the car.
Old 11-08-2011, 04:02 PM   #50
Thran
Member#: 63612
2004 dom 2.5 wrx
Rally Blue
really.. i wonder what kind of power output the M8265 will have, but you are right, i think a synergy 20g for the price would be a better option. The curve looks great thou for your purpose! and you do got a tomei turbo at the end of the day...
I would assume the build quality and reliability will be much better for the other turbo options that would get that same power output
All New Tomei Stock Location Turbo's! M7960, M8265! Great Performance, Qualiy, Price RallySport Direct Vendor 'General Sale' Forum 11 06-27-2011 10:21 AM
Tomei UEL vs Maddad header/exhaust manifold?? AWD>FWD Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 10-16-2010 02:05 AM
Tomei vs Maddad vs GT Spec wr6xwhit Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 10-15-2010 11:23 PM
FS : Scic, Tomei Tomei Tomei Headers W/ Upipe vanquish88 Engine/Power/Exhaust 6 07-22-2010 06:30 PM
Turbo manifold, Tomei vs HKS which one is better? Jimmy168 Newbies & FAQs 6 05-04-2008 02:13 AM
