Old 07-26-2011, 02:46 AM   #1
ShredNW
Member#: 273912
07 wrx
Default Rust specs
Hey guys i have rust specs on the front bottom of my passenger and driver door panels, i tried clay baring it and it took some of it out but not all of the specs. does anyone know of any other methods that will effectively remove these specs? maybe bug and tar remover..?
ShredNW is offline   Reply With Quote
Old 07-26-2011, 08:59 AM   #2
AspenScoob255
Member#: 217405
2006 WRX
What claybar did you use? You may need a more aggressive bar. Pic's of said "rust" spots?
AspenScoob255 is offline   Reply With Quote
Old 07-26-2011, 09:22 AM   #3
JonnyD91
Member#: 250084
2010 WRX Sedan
DGM Cobb Stg. 1
You can try this:
http://www.autogeek.net/finish-kare-...ng-system.html
If anything just use step 2
JonnyD91 is offline   Reply With Quote
Old 07-26-2011, 12:31 PM   #4
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....it really depends on the source. If they are the result of exposed metal from rock chips, you will need to clean/prep and paint those areas to prevent future problems. However, if they are the result of ferrous material embedded in the finish, there are decontamination products available that can address this more effectively than clay. The FK kit Jonny mentioned is one. There are also others like Valugard ABC, CarPro Iron-X, etc.
Kean is offline   Reply With Quote
Old 07-26-2011, 02:27 PM   #5
ShredNW
Member#: 273912
07 wrx
how about rubbing compound? i saw a video on youtube and it recommended that.
Old 07-26-2011, 03:35 PM   #6
Kean
Member#: 25187
'08 Foz Prem TGM
....again, it really depends on the source of the issue. Compound my help remove the rust blooms but if the cause is embedded ferrous contaminants, the problem will likely return. Even clay has it limitations in this respect. Decon products (like the ones mentioned) will help dissolve any corrosion and aid in the release of those metal particles from the paint. ....if your issue is rust as a result of chipping, the answer seems obvious.
Old 07-26-2011, 07:08 PM   #7
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Mostly Fe2O3. It has a molar mass of 159.69 g/mol, a density of 5.242 g/cm3, with a 1566 C melting point, and it is insoluble in water. It also exhibits a rhombohedral crystalline structure.
FS : Stock 2010 STI Spec C Clutch 15k miles dustlove Drivetrain 18 09-15-2011 09:20 AM
FS : SE WI: PICS, Hallman Pro, Perrin Twin tip, Prosport Oil psi, KillerB shroud, Sti F/P 2gnt2wrx MWSOC Private Classifieds 42 08-20-2011 07:45 PM
Rust Bubbles on Roof KaptainKandy Car Care & Detailing 13 08-04-2011 04:20 PM
FS : GT Spec UEL headers Subie_Erin Engine/Power/Exhaust 2 07-28-2011 11:28 PM
small rust specs in paint? Mr.Freeze Mid West Subaru Owners Club Forum -- MWSOC 12 04-23-2003 03:13 PM
