Welcome to the North American Subaru Impreza Owners Club Friday January 30, 2015
Go Back   NASIOC > NASIOC Classifieds > Vendor Storefront Forums > Perrin Performance
Old 07-26-2011, 01:03 PM   #1
PERRIN
NASIOC Manufacturer
Vendor Sales Rating: (10)
Member#: 6776
Default NEW - XD Stout Mounts for 02-07 WRX & STI Rear Sway Bars
NEW! - Introducing The XD Stout Mounts For 2002-2007 WRX & STI
Also Internally Known as Super Stout Mounts
Guaranteed to be the beefiest Rear Sway Bar Mounts you can get for your WRX or STI. These Mounts will put up with any size sway bar under any driving conditions including street, track, drag, rally, rock crawling, hill climb, car show, Auto X, time attack, rally cross, mud bogging, drifting and much more.
Will work with any sway bar that uses bushings that fit the 2004-2007 STI or 2006-2007 WRX.
Hard As A Rock
PERRIN Stout Mounts correct a significant weak point in the OEM suspension. OEM mounts are very flexible, and have been known to break when larger rear sway bars are installed. PERRIN Stout Mounts are machined from a custom extruded piece of aluminum. Extruding the bodies first gives them added strength and creates less waste during machining. They are then black anodized for corrosion resistance.
Stable Base For Your Stiffer Bar
PERRIN Stout Mounts are overbuilt to handle the added stiffness of upgraded swaybars. From auto cross to full rally, you will never have to worry about these failing!
Construction
Machined from billet aluminum, our XD sway bar brackets are drilled for Zerk grease fittings and hard anodized gold.
Easy to lube
PERRIN XD brackets feature Zerk grease fitting so you can easily lubricate your sway bar bushings without having to loosen or take apart your sway bar mounts.
Strongest Ever!
The PERRIN XD brackets will never break, even under the most extreme driving conditions.
Did I mention these flat out look bad ass!
MSRP $209.99
Most Coupon Codes Will Work On This Item To Save You Some Money.
Click HERE to check this item out!
Wholesale Clients Please Contact Your PERRIN Sales Rep.
PERRIN is online now   Reply With Quote
Old 07-27-2011, 07:56 PM   #2
fizzyl
Member Sales Rating: (8)
Member#: 103490
06 STi
Will just the bushing brackets work for the front sway bar? I can't remember what it looks like down there...
fizzyl is offline   Reply With Quote
Old 07-27-2011, 08:16 PM   #3
PERRIN_Chris
Vendor Sales Rating: (0)
Member#: 186665
2014 BRZ
These are just for the rears swaybar, using our PERRIN Stout mounts.
PERRIN_Chris is online now   Reply With Quote
Old 08-01-2011, 04:47 PM   #4
PERRIN
NASIOC Manufacturer
Member#: 6776
Installed Shot - This is one of our techs test cars so they are a little dirty.
FS : 05 wrx springs, sti rear sway bar mxer254 Suspension/Brakes/Handling 2 05-12-2011 05:29 AM
*** PERRIN REAR 2008 WRX and STI REAR SWAY BARS ARE IN *** PERRIN Suspension/Brakes/Handling 13 07-24-2008 10:07 PM
wrx and sti rear sway bars same? Mojambo Brakes, Steering & Suspension 5 11-12-2006 12:40 PM
ATX: FS stock wrx and Sti rear sway bars aznburn210 TXIC Private Classifieds 1 11-09-2006 07:04 PM
FS: stock wrx and Sti rear sway bars aznburn210 Suspension/Brakes/Handling 0 11-08-2006 09:25 PM
