Old 07-27-2011, 01:40 PM   #1
rlig
Member#: 116838
2007 STI CGM
1998 2.5RS WRB
Default First datalogs after engine rebuild. Thoughts?
Hey all,
I know, everyone is probably sick of these "i'm new to teh datalogz, plz halp" but any input would be appreciated. I'm beginning to understand what i should be looking at and what it all means.
2007 STi
75k miles
Cobb stage 1 93 octane
Use shell/bp 93 octane gas
Rotella 5w-40
1200mi since new shortblock, valves, etc
85degF, ~50% humidity
First Log (my commute from work to the highway):
https://spreadsheets.google.com/spre...VFRFE&hl=en_US
Second Log (highway cruise):
https://spreadsheets.google.com/spre...RwMkE&hl=en_US
Third Log (3rd gear pull):
https://spreadsheets.google.com/spre...Z0dEE&hl=en_US
I'm comfortable with the first two logs, but the third log has me slightly concerned. The DAM is at 1 which i'm pleased with and the maf seems to be reading consistently, boost is hitting target and tapering off, the knock feedback is pretty low and occurs right about throttle lift-off time, but the knock learning is what concerns me.
I plan to get a pro-tune in a few months when i get all the requisite stage 2 items, but wondering if i should invest in one before then.
rlig is offline   Reply With Quote
Old 07-27-2011, 05:41 PM   #2
redline23
Member#: 285799
2012 WRX 5-Door
I'm new to datalogs as well, just started learning about them today and what all the stuff means. I think it looks pretty good, just that your ecu remembers where it encountered knock and pulled timing, twice in a few places. I'd be concerned about that too. Maybe you can try to reset the ECU to see if you get feedback knock and it learns the same values again?
From what I've seen on the romraider forums, you don't need the accel position, just throttle position. AFR would be interesting to see, however I think it would be ok since AF Learning is pretty neutral IIRC.
redline23 is offline   Reply With Quote
After engine rebuild car started, but will not now. Keaton522 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-10-2011 03:36 PM
Bad Sounds after Engine Rebuild (video inside) salvator_rizzo Normally Aspirated Powertrain 22 07-27-2010 01:28 PM
Problems after engine rebuild bendavi17 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 02-23-2008 09:58 PM
Blue smoke still after engine rebuild DeezNutz1833 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 31 10-20-2005 02:51 PM
Do I need to change oil sooner after engine rebuild? cky211 Service & Maintenance 5 05-17-2003 05:03 PM
