Old 07-27-2011, 04:37 PM   #1
kristian1977
Member#: 142585
2002 WRX Wagon
Default 1.2 bar turbo actuator on a td04
Hey guys I was wondering if i could just put a 1.2 bar actuator on my td-04 and skip the BCS? My car suffers from crazy boost oscilation at half throttle. doesn't matter if I run on the stock map or the Cobb stage 2. Ive replaced the bcs already and some of the vaccum lines but nothing seems to settle it down. I even messed with the wastegate preload.
I have no problem hitting target boost but the surges from full boost to 10psi make the car a pain to drive smoothly.
Car is stage 2 with a Catless DP and 3" all the way back.
thanks for your help.
kristian1977 is offline   Reply With Quote
Old 07-28-2011, 10:31 AM   #2
kristian1977
Member#: 142585
2002 WRX Wagon
Anyone?
Old 07-28-2011, 10:41 AM   #3
nhat
Member#: 140163
03 STi
hellaflunctional
have you done any logging?
Old 07-28-2011, 11:40 AM   #4
kristian1977
Member#: 142585
2002 WRX Wagon
Nope, Dont have the means too.... I just have a cobb APv1 but ill look in to it.
Old 07-28-2011, 11:50 AM   #5
fenix-silver
Member#: 231700
2004 WRX Wagon
If you have a APv1 you can log using Romraider.
fenix-silver is offline   Reply With Quote
Old 07-28-2011, 01:08 PM   #6
quazimoto
Member#: 70395
That is a terrible idea.
quazimoto is online now   Reply With Quote
Old 07-28-2011, 01:50 PM   #7
SubieLuvin
Member#: 248202
2013 WRX Sedan
Bad idea. Is this a generic Cobb tune or did you get it done by a local tuner? If its fine under wot then its probably just the tune being doo doo for street driving on your vehicle. Getting a flutter then a backfire by chance?
SubieLuvin is offline   Reply With Quote
Old 08-02-2011, 06:42 PM   #8
kristian1977
Member#: 142585
2002 WRX Wagon
flutter no, backfire yes. The map is an ots map. So would a 1.2 bar actuator be bad? I figure that way it would have to hold boost until 17lbs before opening, right?
3" turbo inlet on a TD04? pittsburghscoobie Newbies & FAQs 21 04-14-2011 07:22 PM
2003 2.5rs Turbo bolt on help DemiSlayer Normally Aspirated with bolt-on Forced Induction Powertrain 8 03-07-2008 04:34 PM
diagnosing a worn turbo seal on stock TD04? nicknaz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-28-2008 05:54 PM
Can I use a different WG Actuator on stock TD04 dan1587wrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 06-16-2007 02:20 AM
2.5 open deck on a TD04 stocker/crank question drrice Built Motor Discussion 1 09-27-2006 10:34 AM
