Old 07-27-2011, 07:36 PM   #1
VinceCarter
Member#: 284694
2006 WRX 6 Speed
277/323 @ EFI Logics
Default Any Tips on Cleaning an Engine
I have a 2006 WRX and everything under the hood is stock except for an SPT intake.
What would be the best (most efficient, cheapest, safest etc.) way to clean the engine....it is quite dirty.
Thanks for the help.
VinceCarter is offline   Reply With Quote
Old 07-27-2011, 07:54 PM   #2
hermanclick
Member#: 285656
Nice5
hermanclick is offline   Reply With Quote
Old 07-27-2011, 09:28 PM   #3
vinxH
Member#: 159796
2006 WRX
what I did was sprayed degreaser on the engine (avoid the alternator, and also avoid the intake if you are using the cone filter) and then water-hosed it all down. looked new after that. you can probably dilute the degreaser a bit with some water, i just used straight degreaser.
you have an 06 which is still pretty new so i doubt you need to do any scrubbing.
vinxH is offline   Reply With Quote
Old 07-27-2011, 10:16 PM   #4
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
Take it out of the car.........
Find someone or some place with a steam pressure washer. Soak it down with Simple Green or a fairly heavy duty grease cutting liquid via spray bottle. Then have at it with the steam washer. Put 1-2 spoon fulls of Dawn or another good dish soap in the water to help cut the grease-oil, then finish up with clean water/steam. Let it sit for as long as possible B4 starting to be sure all harness and plugs are dry.
If you can pull off the TMIC remove battery before cleaning .....it will make things way easyer
dangerousatom is offline   Reply With Quote
Old 07-27-2011, 10:28 PM   #5
vinxH
Member#: 159796
2006 WRX
^That's overkill if he has an 06. He can probably do a 75/25 mix simple green and water and still be able to make it look like new.
Old 07-28-2011, 03:04 AM   #6
kateviliams
Member#: 285333
use good engine degreaser and spray it on the dirty parts. but cover the distributors with plastic bag allow the degreaser for few minutes and use regular hose. use the sponge and small brush to clean dirty area. and wash it away you see your engine is clean.
kateviliams is offline   Reply With Quote
Old 07-28-2011, 04:01 AM   #7
khail19
Member#: 14489
2005 FXT 5 spd
Cayenne Red
Distributors? Really?
khail19 is offline   Reply With Quote
Old 07-28-2011, 08:39 AM   #8
sorrowfulkiller
Member#: 170439
I <3 Lamp
e85 works wonders..... I never said it'd be safe while the engine is still in the car however.
sorrowfulkiller is offline   Reply With Quote
Any tips on an 03 wrx timing belt? Subydoo420 Newbies & FAQs 2 03-08-2008 09:41 PM
Any tips on doing a 2.5L engine swap? Kickerz Legacy Forum 1 01-04-2008 12:32 PM
Advice on buying an engine, only an engine... BoozeRS05 Newbies & FAQs 0 07-12-2007 12:32 AM
Any tips for cleaning, under the hood? RobK0000 Car Care & Detailing 5 03-13-2007 06:44 PM
Best way to clean an engine? wcbjr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-31-2003 10:41 PM
