Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 02-22-2001, 05:53 PM   #1
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
Post The Competition is Worried..G Stock is worried
Well..Some Are already worried about the new WRX...especially on the track...
http://www.sccaforums.com/ubb/Forum18/HTML/000053.html
Scooby South is offline   Reply With Quote
Old 02-22-2001, 06:24 PM   #2
JayP
Member#: 3125
2001 Mustang Bullitt
Post
They're right to be worried.
AWD, torque and a light weight chassis.
That's a fun combo.
JayP is offline   Reply With Quote
Old 02-22-2001, 07:52 PM   #3
adhowe70
Member#: 3363
1982 Reynard
Blue, Red, and White
Post
I don't know....
I think autocross is slow enough, it will be difficult to keep the turbo spooled all the time. When at low RPM's the car feels like a low compression 2.0 litre car. You know, gutless. So, you either have to shift back into first gear, or drop down to low revs in second. Either way.....
I found the 2001 WRX I drove SLOWER than my RS at the bottom end of second gear. This could be interesting.
adhowe70 is offline   Reply With Quote
Old 02-22-2001, 08:09 PM   #4
JayP
Member#: 3125
Post
Once the turbo guys figure the car out, it'll scare GS.
Old 02-22-2001, 08:22 PM   #5
adhowe70
Member#: 3363
1982 Reynard
Post
But you're not allowed to touch the drivetrain. In GS, you are limited to stock drivertrain (except from the 3rd cat back) and nearly stock suspension, etc.
I am indeed scared (GS comptetitor that I am) but I think the car will be less competitive than you think. If it weighed 2800 pounds like the RS, it'd be a different story. The WRX will win events, but I don't think it will dominate everywhere it goes. And, I think after its first year, it will be re-classed to a faster class. Maybe FS or DS (ES is slower.)
In short, do I want one to show up to my local Auto-X? NO. Do I think it will clean up at nationals? No. I think a well prepared and well driven WRX will win GS at nationals, but not a sweep across the board.
Old 02-22-2001, 08:46 PM   #6
OnTheGas
Member#: 3807
2002 WRX Sedan
Silver, tinted
Post
I'm not too familiar with the GS class this past season, but if the Integra Type R is dominating this class, then SCCA may have made the correct choice in placing the WRX there. The Integra Type R is 2,639lbs @ 195 hp, while the WRX is a comparatively heavy 3,085lbs @ 227hp. Some math tells us:
1 - Power to weight
WRX carrys ~13.6lbs per hp
Integ R carrys ~13.5lbs per hp
Very close to even! Good!
2 - Overall weight
WRX carrys 3,085lbs
IntR carrys 2,639lbs
The Type R is ~85% lighter than the WRX, and that will be an advantage under braking and turning. Advantage Type R!
3 - Drive Train Part 1
WRX is AWD
IntR is FWD
Advantage will go to AWD. However, Type R does have the unusual advantage over other FWD cars in that it has a limited slip differential, which means they can be on the gas a little earlier than their FWD bretheran. So an ace Type R driver will do quite well. Still advantage AWD!
4 - Drive Train Part Deux - Torque
WRX - 217 lbs-ft @ 4,000 rpm
Type R - 130 lbs-ft @ 7,500 rpm
This should be an advantage to the WRX! Torque pulls us out of the corners.
5 - Suspension
WRX - MacPherson struts @ all corners
Type R - ? (Someone help me out here!)
The MacPherson struts worry me a little bit, as I think there are better suspension designs. For Auto-X, keeping the outside front tires in near neutral camber during hard cornering is critical. Some MacPherson strut designs have a disadvantage here.
Someone else will have to let us all know which car has the advantage in suspension design.
6 - Tires
WRX - 205/55VR16
Type R - 195/55VR15
Too close to call since we carry more weight, therefore, we are working our square inches of tire on the ground harder than the R. OTH, we are using are square inches of rubber on the ground more efficiently, since we are AWD. Due to the weight difference, might be a slight advantage Type R.
So the pre-season bench racing summary sees that the differences thusly. The Type R is 85% lighter, but the WRX is AWD and apparently will have a better torque curve. I would say a slight advantage to the WRX because it will likely be easier to drive. Oh, and also, because I'm prejudice!
[edit:fixed some typos. Bad fingers! Bad, bad!]
[This message has been edited by OnTheGas (edited February 22, 2001).]
OnTheGas is offline   Reply With Quote
Old 02-22-2001, 08:59 PM   #7
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Uh, 85% lighter than 3085lb would be less than 500lb. I think you meant that the ITR is 15% lighter, or 85% as heavy. (3085x.85)
Oh, another point of interest-- torque at the wheels matters more than torque at the flywheel. That's what gearboxes are for! I don't feel like digging up ITR data though to tell you what the torque to the wheels is for the ITR vs. WRX in 1st, 2nd and 3rd gear.
Weight is king in autocross-- over 400lb more is a huge disadvantage. I think the ITR still wins with equal drivers... The WRX sure seems to be a much more competitive GS car than the 2.5RS though.
ColinL is offline   Reply With Quote
Old 02-22-2001, 09:27 PM   #8
SUV-ETR
Member#: 1310
2000 Impreza 2.5RS
BRP
Post
Remember that, next year, the stock classes will be completely re-shuffled. Word from the guy running the show (can't remember names...someone help me here) is that there will be a "factory hot-rod" class, where you'll find the likes of the Integra Type R, WRX, etc. The RS and the rest of what is now GS will probably be put in a separate class.
Regardless of where it's classed, I'm convinced that the WRX will be better than the RS, but by how much is unclear. Unfortunately, I have to agree that for this year it SHOULD be in GS. Where would it be better? FS...maybe? In GS you already have things like AWD turbo Talons, Eclipses, and TT's that are similar in weight and horsepower, not to mention 200hp 3-series Bimmers and ITRs that are known for good handling.
Neal
SUV-ETR is offline   Reply With Quote
Old 02-23-2001, 08:10 AM   #9
subrew2
Member#: 2883
2004 STi
Silver/Gold
Post
I think the WRX is classed correctly, based off the ITR, Mit GSX, and BMW 328 etc... Unfortunately, the bulk of "local" based g-stock racing across the country is filled with us "mid-runners" in the RS, Probe GT, GSR, Celica GT, Audi A4 etc.. I think the plan for separating the fast g-stockers into d-stock next year makes sense. The g-stock that will remain should be very competitive.
As to the WRX...I have no clue. I certainly know I would have liked another 65hp at a few events last year, however, I'm a fan of the mid range pulling power of my RS. I also like the 7" wide wheels, and 2800 lbs.
I hoping to run a WRX at a few Oregon Region events this year...but will mainly be running my '99 RS.
In the Northwest, the "unfair" talk is mainly from the PAX crowd. G-stock has a very low PAX coefficient. I actually finished 5th out of 160 cars last year on PAX, with stock struts and 2-year old Yokos. If the WRX is faster, it could prove to be a good pick for the PAX runners.
Chris Hartman www.subrew.com
subrew2 is offline   Reply With Quote
Old 02-23-2001, 10:56 AM   #10
ibis
Member#: 1132
Post
5th of of 160 cars! Damn Chris. Lawrence was telling me the other day that if he is even close to your time while he is in the S4, he will consider it a personal victory
-justin
ibis is offline   Reply With Quote
Old 02-23-2001, 04:41 PM   #11
adhowe70
Member#: 3363
1982 Reynard
Post
Yeah, I have one goal for 2001....
Beat Chris (Subrew2) at 1 (one) event. With the addition of race tires, that shouldn't be out of the question. Difficult, yes, but not out of the question.
Last year I was 5-10% slower than Chris at every event, on RE 92's. I think Chris said he saw a 5% improvement from the RE 92's to the Yoko's.
worry about stock block reliability @ 23psi boost even with a good tune maramaralula Proven Power Bragging 52 06-19-2008 12:24 AM
My SO's dog is sick and I'm really worried Whitford Off-Topic 31 12-23-2007 03:27 PM
is this sound anything to worry about? Brian204 'Old School' Subaru Forum 5 06-10-2004 05:15 PM
Um, is this something we should worry about? Dennis ex24 Off-Topic 35 04-27-2004 01:03 PM
What is the Competition Sports Car Club Site..? iBlueVirus Motorsports 3 07-04-2001 01:17 PM
