Old 07-28-2011, 07:02 PM   #1
wrx904
Member#: 97365
2015 Mustang PP SC
Default Can someone look at my log????
Ok, I have been getting mis fires in cylinders 1, 2 and 3 and I have been getting a CEL for running lean. I have my log of a 3rd gear pull below. I also have two more logs with this same AP map, one is at idle and the other is driving around the block. Before I logged the 3rd gear pull; I hit 18.5psi in 3rd gear. After the 3rd gear pull I got on it again in 3rd gear and my car would not go past 11.5psi. The only time my car is running rough is at idle with the A/C off. I will also post my mods below. The map that I am running is a email tune. All of this started after I flashed with the email tune. I was running Perrin’s stage 2 map with no problems. Also, no boost leaks and my MAF is clean.
Log
https://spreadsheets.google.com/spre...9BSFE&hl=en_US
Mods
Perrin TBE
Perrin CAI
Perrin TMIC
Perrin turbo inlet hose
Grimmspeed crosspipe with P&P manifold
Grimmspeed uppipe
Forge BPV
wrx904 is offline   Reply With Quote
Old 07-28-2011, 07:52 PM   #2
Cobb Tuning
Member#: 4803
Log
Mods
Perrin TBE
Perrin CAI
Perrin TMIC
Grimmspeed uppipe
Forge BPV
Whoa...time to slow down and take a step back for a sec
The CELs for misfiring and for "Too Lean" indicate a *serious* mechanical or tuning issue, especially when they are occurring on a brand new car like yours. The probably causes are an air leak that was introduced during the TMIC, intake or turbo inlet install process.
Boost went down likely in response to significant knock (which is being caused by the mechanical issue) or due to a pretty big boost leak. The ECU will disable the boost control system is severe knock is encountered.
DO NOT operate the car at WOT if you are still experiencing the "Too Lean" code; in fact you should do anything you can to stay out of boost until the issue can be resolved.
I would give Perrin's customer service guys a call and ask for a good list of diagnostic steps. Best of luck!
Cheers
Lance
Old 07-28-2011, 08:03 PM   #3
wrx904
Member#: 97365
2015 Mustang PP SC
Ok, car is running good again. The vac hose that connects the BVP to the intake manifold blew off. Fixed it.
Can someone look at my AP Log - AVCS Issue deftonez99 Engine Management & Tuning 2 07-07-2010 08:19 AM
Can someone take a look at my logs? cr125r Engine Management & Tuning 51 01-22-2007 06:36 PM
My car is idling roughly. Can someone look at this DeltaDash data? maugustine Engine Management & Tuning 2 10-07-2003 03:27 PM
My car is idling roughly. Can someone look at this DeltaDash data? maugustine Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-06-2003 10:33 PM
Can someone look at my DeltaDash runs? GregUnd Normally Aspirated with bolt-on Forced Induction Powertrain 0 09-18-2002 01:46 PM
