Old 02-24-2013, 02:12 AM   #51
subi400
Member#: 216984
1996 Impreza outback
Green
So,
I have a question. Is this the part number that I need for the 5th gear assembly? Isn't it just the two gears that are replaced and not the syncro and such?
32315AA420
Would you guys get a new 36 and 50mm nut?
So, I have seen a couple of subaru transmission charts and one shows the 2001 outback 5 spd with a 3.9 FD while the other one shows it has a 4.11. Is the 2001 outback really have a 4.11 FD?
subi400 is offline   Reply With Quote
Old 02-24-2013, 10:06 AM   #52
MikeC5
Member#: 104702
95 Legacy
Green
I haven't purchased the gear set yet but I'm 99% sure that the 'set' is the two mating gears and nothing more. If the sychro looks bad it would be the time to replace it but I don't expect the 5th gear sychro gets much abuse. If the nuts aren't too expensive I plan to replace them. Otherwise I'll re-stake and maybe use some red loctite for good measure. I agree that the transmission charts don't provide a very clear picture of what the diff gears should be. Your best bet is to check it on the car by rotating driveshaft and counting rotations to get one full turn of rear wheel. My '02 Outback with original trans does have 4.11 gears.
MikeC5 is offline   Reply With Quote
Old 04-14-2013, 06:42 PM   #53
MikeC5
Member#: 104702
95 Legacy
Green
Getting started on the swap. Everything appears to be good shape in the spare tranny. I see the 50 mm pinion shaft nut is not a regular hex nut so a special tool, 499987300 is in order. The pinion shaft has two lock nuts though, a smaller one is 27 mm on the very end of shaft. As near as I can tell, if only swapping 5th gear I should only have to remove the large lock nut? A threw a few picutres up here:
http://imageshack.us/a/img542/3516/img1473io.jpg
http://imageshack.us/a/img594/291/img1477g.jpg
http://imageshack.us/a/img14/2797/img1478ww.jpg
Old 04-15-2013, 04:32 PM   #54
Storm
Member#: 5218
96L Most Over-
Developed Beater
Correct. The 27mm nut can stay in place.
Jay
Old 04-15-2013, 06:28 PM   #55
MikeC5
Member#: 104702
95 Legacy
Green
Well the 499987300 tool is more special than I thought... as in several hundred dollars special. Nor does it appear finding a deep enough deep well 50 mm socket at a reasonable price. Has anyone had any luck jury rigging something to tackle the 50 mm lock nut? I'm thinking get a 'regular' 3/4 drive 50 mm or 2" socket, machine out a clearance hole on the drive end to clear shaft and then weld on a section of pipe for leverage. Not very elegant....
Old 04-15-2013, 10:04 PM   #56
Storm
Member#: 5218
96L Most Over-
Developed Beater
I cut my 50mm socket in half and welded a section of tubing between the halves. I had a picture online somewhere, but darned if I can find it now......
Jay
Old 04-16-2013, 12:07 PM   #57
MikeC5
Member#: 104702
95 Legacy
Green
Thanks Jay. That seems like a good plan.
Old 04-18-2013, 03:13 PM   #58
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Jay
Yep. We've been doing that for decades to make our own Porsche special tranny tools...
Old 04-18-2013, 07:10 PM   #59
MikeC5
Member#: 104702
95 Legacy
Green
On its way! Just have to weld it up...
Old 04-20-2013, 10:26 PM   #60
MikeC5
Member#: 104702
95 Legacy
Green
Got it apart and am ready for the new gears. Anyone ever remove the speedo shaft? Is there a C-clip holding it in? I removed the gear and the speed sensor but cannot see what is holding it in there.
Old 04-28-2013, 09:46 PM   #61
WoodsWagon
Member#: 180769
lots of junkers
I took a pic of the driven 5th gear that I chipped when my puller broke trying to get it off the shaft. Would you run this?
WoodsWagon is offline   Reply With Quote
Old 04-29-2013, 11:34 AM   #62
Frogsthatmoo
Member#: 153374
2001 Outback Wagon
I'm glad to see someone going through with this. I ended up delaying this mod for a while, but may be doing it soon now that MikeC5 is doing it.
Frogsthatmoo is offline   Reply With Quote
Old 04-29-2013, 04:43 PM   #63
drewmob
Member#: 214192
2003 WRX
I would, but it depends on usage. I don't flog on 5th for many reasons so it wouldn't bother me.
drewmob is offline   Reply With Quote
Old 04-30-2013, 10:26 PM   #64
Frogsthatmoo
Member#: 153374
2001 Outback Wagon
That chip doesn't look terrible. It also doesn't look like it would spread into a fracture very easily.
Old 05-05-2013, 09:01 PM   #65
MikeC5
Member#: 104702
95 Legacy
Green
Installed the new gears and am almost ready to button up the case...
Old 05-05-2013, 09:06 PM   #66
MikeC5
Member#: 104702
95 Legacy
Green
Old 05-28-2013, 04:11 PM   #67
subi400
Member#: 216984
Green
Ok, so I am getting ready to hopefully do the 5th gear swap into the 2000 outback 5 spd 4.11 FD tranny that I have.
However, I have been talking with flatirontuning about a particular gear set. The RA none sti gear set has this 3.083 / 2.062 / 1.545 / 1.151 / 0.825 from the rallyspec site. Well, the 2000 outback 5 spd has the gear set of 3.454 / 2.062 / 1.448 / 1.088 / 0.871 / 4.111FD. Since the 2nd gears are supposedly the same (pending tooth profile), I was thinking of doing this set up: 3.083 / 2.062 / 1.448 / 1.088 / 0.780 4.11 FD.
Or maybe something like this: 3.083 / 2.062 / 1.366 / 0.972 / 0.780 4.11 FD, the 3rd and 4th is the stock 02-05 wrx gear stack.
Either way, still going to do a swap sometime soon the 1st gear in my current 5 spd tranny in my 96 impreza wagon is too short... 2nd could be a bit taller.
Old 05-28-2013, 07:26 PM   #68
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
looks good to me
Old 06-15-2013, 09:45 PM   #69
MikeC5
Member#: 104702
95 Legacy
Green
I got everything back together today and wow, with the new clutch it is sweet! I think the clutch in there was original with 170K miles. Not too shabby... it wasn't going to last much longer though- was within a hair of the lining rivets. It's much more comfortable at 70 mph and the engine still has enough torque to go up hills without downshifting. I don't know why they geared these so low to begin with..
Old 06-15-2013, 09:56 PM   #70
Storm
Member#: 5218
96L Most Over-
Developed Beater
Nice job!!!!
Jay
Old 06-16-2013, 07:49 AM   #71
MikeC5
Member#: 104702
95 Legacy
Green
Thanks. Now I've got to take care of a little rust and maybe put some Legacy struts on there...
Old 06-16-2013, 09:23 PM   #72
Frogsthatmoo
Member#: 153374
2001 Outback Wagon
Which gear did you go with?
Old 06-17-2013, 05:52 AM   #73
MikeC5
Member#: 104702
95 Legacy
Green
I'll double check later but I believe it was this one which was the tallest set available.
32315AA420
Old 06-17-2013, 12:16 PM   #74
Frogsthatmoo
Member#: 153374
2001 Outback Wagon
.735?
Old 06-18-2013, 07:57 PM   #75
MikeC5
Member#: 104702
95 Legacy
Green
Yes. Yes alone is too short of an answer according to the software... I guess to help prevent 4 letter words?
5th gear or no 5th gear??? richstage5 General Community 38 01-14-2011 06:21 PM
aftermarket taller 5th gear? jam69007 Transmission (AT/MT) & Driveline 5 05-14-2010 08:16 AM
Taller 5th gear for 5MT? BadTrip Transmission (AT/MT) & Driveline 49 06-17-2008 10:09 PM
Taller 5th gear for 04 FXT 5M? Seayak Transmission (AT/MT) & Driveline 13 05-03-2006 12:16 AM
USA STi gets taller 5th and 6th gear Jude DeMeis STi Forum Archive 18 03-16-2003 05:42 PM
