Old 07-28-2011, 11:06 PM   #1
dudenhoeffer02wrx
Member#: 280362
2002 wrx
midnight black
Default feedback knock and fine knock learning??? please explain.
can someone just sum up what the difference is between fine knock learning and feedback knock? and waht are some average numbers i very rarely see any feedback. and am seeing 1.05deg under boost.
dudenhoeffer02wrx is offline   Reply With Quote
Old 07-28-2011, 11:09 PM   #2
redline23
Member#: 285799
2012 WRX 5-Door
http://www.romraider.com/forum/topic1840.html
TLDR: Feedback knock: A sensor just heard knock and pulled timing.
Fine knock learning: The ECU has learned it is seeing knock under that condition and pulls timing to prevent knock.
redline23 is offline   Reply With Quote
Old 07-28-2011, 11:11 PM   #3
redline23
Member#: 285799
2012 WRX 5-Door
Oops, double post.
I'll just add more information then :P http://www.romraider.com/forum/topic5371.html
Old 07-28-2011, 11:55 PM   #4
dudenhoeffer02wrx
Member#: 280362
2002 wrx
midnight black
thanks that is awsome.
Old 06-21-2016, 01:06 AM   #5
Rob_STI_PNW
Member#: 387796
2015 WRX
RED
Feedback, real time correction
Fine knock learn, proactive correction that prevented a knock event from ever occurring, think of it like it overdraft protection
Rob_STI_PNW is offline   Reply With Quote
Old 06-21-2016, 10:38 AM   #6
ColdSoda
Member#: 200545
2008 SPEC B
since this is an accessport thread... I'll post this article, since it sounds like you might have some other questions too:
https://cobbtuning.zendesk.com/hc/en...How-to-Datalog
That does cover feedback knock, etc and other parameters.
ColdSoda is offline   Reply With Quote
Old 06-21-2016, 12:10 PM   #7
wasatchwrx
Member#: 438547
2003 Wrx VF48
Whether the ECU decides to correct using feedback, fine knock learning or DAM adjustments is based on what mode it is in.
Taken from the badnoodle guide: FYI, IAM = DAM
If (in fine correction) {
If (pulled more than 4 degrees or the ECU is unhappy) {
Goto (IAM correction)
If (Large/rapid change in engine load) {
Goto (FBKC)
} else {
Check to see if any adjustments need to be made
Stay in FLKC correction mode
If (in FBKC mode) {
While (engine load is rapidly changing) {
Check for knock and pull timing if needed
When (Done) {
Go back to previous mode
If (in IAM correction) {
Find optimal IAM
Go back to FLKC mode
wasatchwrx is online now   Reply With Quote
How come I Can't see feedback knock correction, fine learning knock correction? AraSh Open Source Reflashes 23 01-08-2014 07:04 PM
constant fine knock learn? olazy AccessPort 5 05-24-2011 11:53 AM
Fine Knock Learning in ATR Tripintaz AccessPort 5 10-01-2010 09:31 AM
Explain how the Knock Sensor works signal wise.... PLEASE! reddevil Built Motor Discussion 18 10-10-2009 12:32 AM
Knock correction, please explain Egan Engine Management & Tuning 68 11-03-2003 11:45 AM
