Welcome to the North American Subaru Impreza Owners Club Friday October 9, 2015
Old 07-29-2011, 12:47 AM   #1
Member#: 216924
2009 WRX STi
Default Diagnosing problems with A/F learning and logging
I had read recently in a post on this forum that A/F learning A-D numbers can be used to diagnose problems like air leaks in the intake/inlet system, and was wondering if this is actually the case. If so, what should I be looking for? I know I am currently having a problem (severe overboosting - about 4-5 psi above target), and have the following numbers for A/F learning: A - 7.5%; B - 7.4%; C - 0.5%; D - 0.0%.
Modifications (if they're helpful):
44mm Tial EWG
Intake (Typhoon-type)
TGV deletes
1000CC injectors
Samco inlet
An added note on current issues: I have an exhaust leak - enough that I do not feel exhaust flow out the rear pipes at this point (so a severe exhaust leak...or else my EWG is somehow stuck and diverting all flow to the dump tube). I also definitely have a vacuum or boost leak under the hood.
Any logging values that would be recommended for diagnosing a problem like this? I don't want to do a full throttle pull in the interest of keeping my engine safe, but if there is something I can do, I'm open to suggestions. If anyone has a guide for how to diagnose problems with the AP, it would be very helpful and appreciated.
Tryptofan is offline   Reply With Quote
How to diagnose problem with steering wheel controls? Economatic Car Audio, Video & Security 4 01-25-2011 09:37 AM
Help with reflashing my ecu and logging wrxracer519 New England Impreza Club Forum -- NESIC 11 01-06-2008 07:48 PM
help diagnosing problems with 97 jetta please! jonnydajibba Off-Topic 30 07-12-2006 06:30 PM
Misinformation about leak down testís diagnosing problems with smoking after a long i MO REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 28 09-25-2005 01:36 AM
diagnose problem with CELs nhluhr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-23-2002 08:49 AM
