Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 07-29-2011, 04:21 PM   #1
Redefined
Member#: 263718
2002 Impreza WRX
Default Best way to clean trim?
Curious what people recommend to clean trim. After i get done buffing sometimes i hit spots on the trim with compound. I cannot seem to remove this mess. Any advice?
Redefined is offline   Reply With Quote
Old 07-29-2011, 05:08 PM   #2
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
To remove the compound / wax from trim?
Mr. Clean Magic Eraser.
Seriously.
XanRules is offline   Reply With Quote
Old 07-29-2011, 05:08 PM   #3
Entaille
Member#: 217875
2008 STi
sometimes I get wax on my trim and I don't notice for a bit. I like to use a little wd40 to scrub it down, then I use dawn + green side of a sponge to scrub it and break down the rest of it. after I wash it off and let it dry I follow it up with some forever black or back to black and it looks great.
may not apply to the compound, but worth a shot, and it's common household stuff minus the black detailing item.
Entaille is offline   Reply With Quote
Old 07-29-2011, 08:05 PM   #4
that1dude
Member#: 89734
04 WRX wagon
Stage zer0
Listen to Xan. Those things truly are magic. They work on damn near anything.
that1dude is offline   Reply With Quote
Old 07-29-2011, 08:35 PM   #5
hdempsey
Member#: 126374
2001 Impreza 2.5RS
Pure Aspen White
That's what she said.
hdempsey is offline   Reply With Quote
Old 07-30-2011, 01:29 AM   #6
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....just be careful with anything abrasive you use on trim that can possibly alter the appearance of the finish.
Kean is offline   Reply With Quote
Old 07-30-2011, 02:04 AM   #7
SubieDugie
Member#: 119219
2005 STi
WR Blue
Black Wow Pre-cleaner is great for those situations and before applying any trim protectant/treatment, not just Black Wow. In some cases I have used a mild APC and soft bristle brush. I have also used pre-wax cleansing lotion on plastic to clean it and prep for protectant and have had great results; just don't let it dry on the plastic. Always remove and compounding/polishing residue/oils ASAP. I have yet to try a magic eraser but might have to try it out.
For treating/protecting the trim I use 303 Aerospace Protectant, Sonus Total Eclipse for PVR, Wolfgang Exterior Trim Sealant(stuff is awesome), and Black Wow(great on smaller areas). I have used Mothers' Back2Black and was not the least bit satisfied with it; would actually choose Armor All over it. JMO&E.
SubieDugie is offline   Reply With Quote
Old 07-30-2011, 12:07 PM   #8
Kean
Member#: 25187
'08 Foz Prem TGM
....I will add that the best solution in these cases is prevention, especially if this is a reoccurriong problem for you. When using a polish/compound, take an extra few minutes to mask off vulnerable areas with painters tape. It will save you a lot of headaches.
Old 07-30-2011, 08:51 PM   #9
06legacy555
Member#: 225791
2006 Legacy
Alantic Blue
Yea I go with what Kean said. It takes a bit more time but saves time in the long run.
06legacy555 is offline   Reply With Quote
Old 07-30-2011, 09:17 PM   #10
teesutt
Member#: 127940
Evil shenanigans
Love me some clean trim
teesutt is offline   Reply With Quote
Old 08-01-2011, 07:09 PM   #11
Redefined
Member#: 263718
2002 Impreza WRX
thank you for the advice guys.
Old 08-02-2011, 04:19 PM   #12
jefmcc
Member#: 42303
2004 WRX
Rally Blue
+1 for the Magic Eraser.
++1 for masking with painters tape.
My result with Magic Eraser...
http://forums.nasioc.com/forums/show....php?t=1301008
jefmcc is offline   Reply With Quote
Old 08-02-2011, 09:54 PM   #13
perds
Member#: 274613
2015 WRX
You sir, are a gentleman and a scholar. Thanks
perds is offline   Reply With Quote
Old 08-03-2011, 12:13 AM   #14
matt1067
Member#: 290251
I had the same issue and second the Mr. Clean magic eraser...works wonders without damaging the trim!
matt1067 is offline   Reply With Quote
Old 08-03-2011, 05:39 AM   #15
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
Originally Posted by vivan
Are you sure?
Time to die, spammer.
Old 08-03-2011, 12:24 PM   #16
jefmcc
Member#: 42303
2004 WRX
Rally Blue
No problem. Not sure I would use it on the hard plastic parts though. Just the rubber seals.
Old 08-03-2011, 01:28 PM   #17
maw230
Member#: 277632
2005 Impreza Wagon
Off topic, but I'm in Springfield as well. I drive a sedona red bugeye. Been looking for someone in the area to swap knowledge with (mine is very limited ) and possibly parts. Get a hold of me if you want to meet up sometime.
maw230 is offline   Reply With Quote
Old 08-03-2011, 07:41 PM   #18
ben_shafer
Member#: 251681
2006 STI
CGM
This stuff s absolutely amazing and does not dull out your trim because it doesnt have silicone in it. Pricey but definitely worth it.
http://www.autogeek.net/wolfgang-trim-sealant.html
ben_shafer is offline   Reply With Quote
what is the best way to clean your engine?? waitandbleed92 Interior & Exterior Modification 1 07-20-2003 10:13 PM
What is the best way to clean OEM carpets Scoobie Newbie Newbies & FAQs 9 03-13-2003 12:53 PM
Best way to clean leather steering wheel? minkeybow Service & Maintenance 8 12-13-2002 11:38 AM
Best way to clean powdercoated wheels? (Rotas) BeavisNuke Brakes, Steering & Suspension 7 10-20-2002 02:17 AM
I got egged, what's the best way to clean it? Robmat Car Care & Detailing 4 04-28-2002 06:58 PM
