Old 07-29-2002, 03:31 AM   #1
SONofSAM
Member#: 8407
Unhappy Engine Light turn ON...what to do!
My Engine light turn on after i had clean/steam my engine...
i try disconnect the battery 2 time's for like 20-30 mins and runs my car around my block for like 3 time's...then i find out when i shift from second to third gears! the engine light turn on right away Blink Blink... and i feel the car is little choke when everytime i step on the gas pedal...
do you guys think this is a big problem! should i run couple more time's and see's the light still turn on!
please educate me a bit!
thanks guys,
SONofSAM is offline   Reply With Quote
Old 07-29-2002, 11:55 AM   #2
SONofSAM
Member#: 8407
anyone know!
Old 07-29-2002, 01:13 PM   #3
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Sounds like a misfire. Blinking CEL's are indicative of a misfire and if you just steam cleaned your engine you could've gotten some water into your plug wire boots or worse fried the coil pack. You'll either need to pull the code from your local autozone and get to the dealer and buy parts, hoping I'm right. Or just take it into the dealer and ask for some help (most dealers will allow a tech to take a "quick" look at a car before scheduling service).
Old 07-29-2002, 10:34 PM   #4
stentorian
Member#: 12959
2008 Scion xB
Blinking CEL = Misfire
stentorian is offline   Reply With Quote
Old 07-30-2002, 10:37 AM   #5
BOY
Member#: 232
99 RS-T RIP
02 Forster-S
Any updates? It it still misfiring? I'm wondering if over the past few days the coil/wires/plugs have dried out.
Old 07-30-2002, 12:10 PM   #6
SONofSAM
Member#: 8407
Hey,
i find out this morning, that my one of my spark plug wire full of water...i have to take the spark plug out have them dry out and disconnect the battery for like 30 mins...then afterward i plug everything back in, and start the car...Guess what!
the Engine light turn off.
what a breath taking!
Anyway thanks for the some info you guys give me!
And chris, i'm still down to the installfest this coming weekend...
HELP! Check Engine light on & Cruise Control Light Blinking STiURBO Southern California Impreza Club Forum -- SCIC 21 03-15-2007 02:54 AM
Got the CE light - P0037 - Any suggestions on what to do? curveslayer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-07-2007 02:36 PM
Check engine light on and cruise control light flashing mpadovano Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 01-23-2005 03:04 PM
question on what to do about fog lights izhazissuez Electrical & Lighting 2 08-04-2003 04:54 AM
Engine vibrating, check engine light on codemunky Service & Maintenance 2 09-15-2002 08:50 AM
