Old 07-29-2002, 05:08 AM   #1
edkwon
Member#: 453
2014 Audi S4 B8
Metallic Gray
Default will this set up of bolt ons require additional fuel management systems?
I'm pondering a WRX engine and gettin the mods bolted on before installing the engine itself, this includes a 3 in uppipe/downpipe/intercooler radiator and turbo hoses/ and hgher flowing turbo cat back exhaust.
Now will this simple combination require upgraded fuel injectors and possibly a S-AFC for fuel management. I'd like to avoid this if possible since i am thinking of moving to Ca, where visible AFCs can get your butt nailed.
Ed
edkwon is online now   Reply With Quote
Old 07-30-2002, 05:19 AM   #2
edkwon
Member#: 453
2014 Audi S4 B8
Metallic Gray
c'mon, somebody? *bump*
Old 07-30-2002, 05:31 AM   #3
Narcisse91
Member#: 3931
WRX, Ninja, RX-7
Legacy, Fiat 850
You're planning to "bolt on" all the exhaust piping, as well as the turbo, onto an RS engine, correct?
You're going to want some sort of management. The AFI guys might be able to answer that with their own experiences, but if it were me, I wouldn't just bolt it up and hope for the best.
Narcisse91 is offline   Reply With Quote
Old 07-30-2002, 06:52 AM   #4
jimb
Member#: 9923
2005 Legacy GT
RIP MBP WRX
Assuming your running the wrx ecu, than no, you should do fine. No problem with fueling, however, you'll be able to squeeze more out of the motor with an safc.
jb
jimb is offline   Reply With Quote
Old 07-30-2002, 09:38 AM   #5
edkwon
Member#: 453
2014 Audi S4 B8
Metallic Gray
Not an RS engine, you misread what i posted, i'm talking an EJ20T swap into an RS engine bay.
Ed
Old 07-30-2002, 09:44 AM   #6
TurboRex
Member#: 8635
04 STI, 07 FXT
You don't need engine mgm at all. The safc may get you another 10hp or so.....maybe if tuned right. I honestly don't think the safc is needed unless you get larger injectors. I ran 12's on the stock ecu and injectors without a problem before installing the safc.
Good luck,
Greg
TurboRex is offline   Reply With Quote
Old 07-30-2002, 09:45 AM   #7
TurboRex
Member#: 8635
04 STI, 07 FXT
Oh yeah, make sure you have a good fuel pump though.
Greg
Old 07-30-2002, 09:49 AM   #8
Narcisse91
Member#: 3931
WRX, Ninja, RX-7
Legacy, Fiat 850
Ed
What do you mean by bolting on the mods before installing the engine itself? The way that reads, you're bolting parts of the WRX powertrain on before you install the engine. Are you talking about bolting parts onto the WRX engine before install? Because you can't really install the engine if you have a full exhaust already bolted to it. Although it's probably possible, you're going to have a hard time lowering it into the engine bay. You're going to want to connect that afterwards.
A WRX ECU and fuel system can handle the mods you listed, for the end result of an engine with the mods listed. Do you have a WRX ECU?
Old 07-30-2002, 10:55 AM   #9
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Default Re: will this set up of bolt ons require additional fuel management systems?
Funny, I understand this post perfectly.
You should be ok with that stuff, Ed. I know lots of WRX'ers running that stuff without management all the time.
I agree with the above comment about making sure you have a proper fuel pump, though. Your RS one may not flow enough for it.
Will this set up work? Wrgb Car Audio, Video & Security 12 10-19-2009 08:58 PM
will this set up work?? kosmider12 Car Audio, Video & Security 2 09-12-2006 03:35 PM
Will this set up rub? BlowDro Tire & Wheel 2 08-23-2006 09:41 AM
will this set up work. siliversti06 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 06-11-2006 10:32 PM
Will this set up work? JoBamBo Car Audio, Video & Security 3 12-27-2005 04:26 AM
