Old 07-31-2011, 10:55 AM   #1
sempersubi
Member#: 230409
2006 STI
white
Default Rally car question
Probably gunu be something that im gunu slap myself for asking but in the subaru rally America cars what is that bird chirp sounding noise that happens when they let off the gas? used to think it was the anti lag but i have never heard that noise from a normal STI or any car for that matter besides the rally cars
sempersubi is offline   Reply With Quote
Old 07-31-2011, 11:08 AM   #2
Psychoreo
Member#: 79643
04 EJ207 Swapped
Mikey tuned 271whp/287wtq
It's either a blow off or bypass valve, depending on the car.
And what the hell is a gunu?
Psychoreo is offline   Reply With Quote
Old 08-01-2011, 07:16 AM   #3
logic246
Member#: 225907
It is called compressor stall , it when you have the throttle closed and there is no where for the air to go and it slows the compressor wheel to stall a bit causing the chirping noise .
logic246 is offline   Reply With Quote
Old 08-01-2011, 07:21 AM   #4
MFR Sweep
Member#: 103510
2006 rex
Aspen Brake Dust
compressor surge. Also called turbo flutter or (incorrectly)wastegate chatter.
MFR Sweep is online now   Reply With Quote
Old 08-01-2011, 07:23 AM   #5
logic246
Member#: 225907
Waste gate chatter is something different .
That is when you have an internal wastgate that does not seal properly or when it is on boost it bleeds off the boost erratically also has a metallic sounding noise.
Old 08-01-2011, 07:43 AM   #6
MFR Sweep
Member#: 103510
2006 rex
Aspen Brake Dust
that is true, but people incorrectly call it wastegate chatter. i should have noted that i guess.
Old 08-01-2011, 09:02 AM   #7
sempersubi
Member#: 230409
2006 STI
white
Gunu = going to lol. So the verdict is compressor surge?
Old 08-01-2011, 09:17 AM   #8
sureshot007
Member#: 142405
#716 G5 Cherokee
nyscoob.com
Or it could just be a sequential blow off valve. Really depends on the car.
sureshot007 is offline   Reply With Quote
Old 08-01-2011, 11:49 AM   #9
RB5 Clone
Member#: 30909
RA East Open Class
Champs 07-08-09
OK mr sempersubi...you see the roof scoops on top of all the rally cars? Those let cool air in for the crews (no A/C in race cars) but often these scoops will literally scoop in birds.
so that noise you hear is the birds excaping.
RB5 Clone is offline   Reply With Quote
Old 08-01-2011, 11:51 AM   #10
sureshot007
Member#: 142405
#716 G5 Cherokee
nyscoob.com
Speak for yourself
Old 08-01-2011, 12:33 PM   #11
rallynutdon
Member#: 24568
1993 Impreza, WRX
drive train, Open class
Originally Posted by sureshot007 View Post
Speak for yourself
When are you bringing your new beast out again to play?
rallynutdon is offline   Reply With Quote
Old 08-01-2011, 12:53 PM   #12
sureshot007
Member#: 142405
#716 G5 Cherokee
nyscoob.com
This summer has been crazy between other racing and broken cars. I haven't even touched it yet, but I figure if I put some effort into it over the course of the next month, I should be ready for LSPR.
Old 08-04-2011, 01:07 AM   #13
Andy Bernard
Member#: 191244
Here's a pretty good description from Garretts website:
"Surge is most commonly experienced when one of two situations exist. The first and most damaging is surge under load. It can be an indication that your compressor is too large. Surge is also commonly experienced when the throttle is quickly closed after boosting. This occurs because mass flow is drastically reduced as the throttle is closed, but the turbo is still spinning and generating boost. This immediately drives the operating point to the far left of the compressor map, right into surge.
Surge will decay once the turbo speed finally slows enough to reduce the boost and move the operating point back into the stable region. This situation is commonly addressed by using a Blow-Off Valves (BOV) or bypass valve. A BOV functions to vent intake pressure to atmosphere so that the mass flow ramps down smoothly, keeping the compressor out of surge. In the case of a recirculating bypass valve, the airflow is recirculated back to the compressor inlet."
Surge although technically bad is unavoidable if you want the kind of response rally drivers want.
Andy Bernard is offline   Reply With Quote
Old 08-04-2011, 01:12 AM   #14
Andy Bernard
Member#: 191244
Slows the compressor wheel until it stalls? What stalls, the wheel? How does that make a noise?
Old 08-04-2011, 01:28 AM   #15
iamfenwick
Member#: 281507
the noise is the air going through the turbo backwards.
iamfenwick is offline   Reply With Quote
Old 08-04-2011, 08:18 AM   #16
Psychoreo
Member#: 79643
04 EJ207 Swapped
Here.
The noise isn't good.
You don't want it to happen on your car.
Even though you think it sounds cool.
Old 08-04-2011, 09:59 AM   #17
greycar
Member#: 192970
They use a surgeless type of compressor housing. It happens during decelleration/braking. On those cars they rarely lift of the gas pedal to keep the throttle plate open and the turbo spooled. With the sequential transmissions they are using there is no need to use the clutch other than to take off so keeping one foot plated on the gas is very easy. This is why the brakes glow so often as well because even while braking they are on the throttle.
greycar is offline   Reply With Quote
Old 08-04-2011, 10:02 AM   #18
logic246
Member#: 225907
Not necessarily true.
Some drivers like an aggressive brake pad , hence the glowing disks . All Rally driver do not left foot brake.
Old 08-04-2011, 10:12 AM   #19
RB5 Clone
Member#: 30909
RA East Open Class
Champs 07-08-09
this statement could be turned around quite accurately...glowin brakes result from braking even while the other foot is mashed on the gas
stages with lots of short straights followed by tight corners also breed cherry red rotors, esp on high end turbo cars
Old 08-04-2011, 11:00 AM   #20
bill@dentsport
Member#: 102459
2002 WRX Wagon
240RS Maxi
If you block off your bypass valve on any turbo car it will make a little bit of chirping but the main reason the SRT cars (Antoine's Evo X is even louder) is super loud is due to the restrictor design in combination with the design of the compressor wheel. Subaru uses an early variation of the TR30 WRC garrett from a Step II mitsu wrc (but a different TR30 on the rallycross cars) and Antoine uses a more recent TR30.
bill@dentsport is offline   Reply With Quote
Old 08-06-2011, 03:56 AM   #21
Seldian
Member#: 290584
For those of you asking what specific sound he is talking about, watch this, you can hear it a ton every 15 seconds.
Seldian is offline   Reply With Quote
Old 08-06-2011, 06:24 AM   #22
axelthrasher
Member#: 144779
200X ZOMG a car 100%
crabon fibre girlfrendorz
LOL!!! Winning!
axelthrasher is offline   Reply With Quote
Old 08-08-2011, 09:45 PM   #23
WhiteoutRally
Member#: 173993
04 STi
Have you ever actually watched a rally drivers pedal box? "rarely lift"? what a load of misinformation. We use trail braking a fair amount to help stabilize the car at speed, as well as on both pedals in the corners sometimes, but that's not why the brake glow. They glow simply from the massive amount of heat generated while on stage where your either flat on the gas or hard on the brakes. Picture driving from 0 to 100, then slamming on the brakes, repeated, for 5-20 minutes non-stop. Also, unlike a track car we do not have the same type of airflow, or oversized brakes/rotors to dissipate the heat (gravel events require a 15" rim keep in mind)
WhiteoutRally is offline   Reply With Quote
Old 08-09-2011, 07:09 AM   #24
logic246
Member#: 225907
‪Petter Solberg WRC Rally Italy 2003 Onboard pure sound FOOT CAM‬‏ - YouTube
WRC cars do have the airflow needed to direct air to the wheels , so do track cars and they still glow.
Old 08-11-2011, 07:04 PM   #25
WhiteoutRally
Member#: 173993
04 STi
I was saying the same type, ie not nearly as much. Wasn't saying there wasn't airflow...
Also, if you compare something like group N brake components (like most of us in the US run, 4/2 pots) compared to big brake track kits, there is so much more surface area to dissipate heat in a track version.
We run 11" x .95" thick rotors in the front, compared to say the wilwood track kit, which runs 12.8" x 1.2". That's a lotttta extra heat dispersing capacity.
Some wrx rally car questions LqSilver General Community 5 11-18-2003 07:21 PM
Project Rally car questions Shag-e Tri-State Area Forum 20 02-12-2002 12:05 AM
Model WRX rally car question... Purdue WRX General Community 9 01-07-2002 02:18 AM
Rally car interior question skidplatez Motorsports 2 05-17-2001 09:59 AM
Rally car question JS General Forum Archive 7 06-14-2000 12:17 AM
Message Board Statistics All times are GMT -4. The time now is 11:20 AM.
