Old 07-31-2011, 03:10 PM   #1
c4t
Member#: 244182
02 WRX WRB sold
07 STI OBP sold
Default stage 2 low boost, look at my log and dyno run
so im only hitting 15.6 PSI on 3rd gear on my 07 sti, temperature is at 85 F
but it has stage 2 tune with AP and a catless dp and straight 3" pipe all the way to the back, shouldnt it be hitting the 19.5 psi or maybe more? even on 4th gear pull i dont reach 18 PSI
here are my logs of 3rd and 4th
https://spreadsheets.google.com/spre...hl=en_US#gid=0
and did the dynorun on the AP on 3rd gear from 2K RPM and its actually getting less HP than TQ heres the dyno run:
thanks in advance for anyone that answers
c4t is offline   Reply With Quote
Old 08-01-2011, 06:26 PM   #2
ryyiann
Member#: 259241
2011 WRX Limited 5dr
flash a high wastegate map
ryyiann is offline   Reply With Quote
Old 08-01-2011, 07:22 PM   #3
c4t
Member#: 244182
02 WRX WRB sold
07 STI OBP sold
what do you mean by that?
Old 08-01-2011, 09:47 PM   #4
ArSoN9
Member#: 285777
2004 STi-
cobb has maps for cars not getting to target boost wether over or under-boosting they have a stage 2 map to correct that.
Also I would look into your high timing figures.. correct me if im wrong but isnt 49.5degrees alot. and that -11.2 boost at 52% throttle isnt good
ArSoN9 is offline   Reply With Quote
Old 08-02-2011, 02:11 AM   #5
c4t
Member#: 244182
02 WRX WRB sold
07 STI OBP sold
they different maps for the 06 sti but for the 07 sti they dont have that option, only 1 map for 93 OCT Stage 2 heres the link
http://accessecu.com/accessport/suba...SF-Intake.html
today weather felt colder and dryer, it said 77F so i did another log, from 1st, 2nd, 3rd and 4th here it is: https://spreadsheets.google.com/spre...t6bWc&hl=en_US
max boost was 18.4 on 4th gear, but remember this car has no cats at all its a straight pipe 3" all the way to the back if anything it should be giving boost creep,
here i took one on 3rd gear starting from 2K RPM with wastegate max , A/F, intake temp and other info 16.2 was highest PSI:
i come from tunning with UTEC so its quite different, any help or comments will be appreciated
Old 08-02-2011, 04:41 PM   #6
Cobb Tuning
Member#: 4803
Your boost is a bit low for that map, but not remarkably so. You may want to take a look at the boost control system and see if any of the lines are cracked and bleeding air. You can also alter the boost pill and see if that impacts your peak boost at all. I would start looking for little vaccum leaks first, especially at the fuel pressure regulator tap on the intake manifold. Let us know if you have any other questions or needs.
Travis
COBB Tuning
Old 08-02-2011, 04:54 PM   #7
c4t
Member#: 244182
02 WRX WRB sold
07 STI OBP sold
Travis
COBB Tuning
thanks Travis i will be checking for vacuum leaks and keep posting when i find an update,
Help me Diagnose my Cobb Stage 2 Low Boost Problem scotty144 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 12-18-2005 10:01 PM
Cobb stage 2 low boost problem - anyone found a fix yet? txl146 Engine Management & Tuning 11 05-28-2004 12:34 AM
Cobb stage 2 low boost problem - let's put this to an end! READ THIS! txl146 Engine Management & Tuning 1 05-23-2004 10:56 AM
Vishnu stage 2 low boost?? impreza2 Engine Management & Tuning 6 05-20-2004 09:56 AM
cobb stage 2 low boost CrashN2mee Engine Management & Tuning 15 03-10-2004 11:03 AM
