Old 07-31-2011, 08:42 PM   #1
kyleyap
Member#: 214088
1995 WRX Type RA
JDM YO!!
Default testing o2 sensor
anyone here ever est there o2 sensor with a multimeter?. I was trying to see the voltage while it was running but it didnt seem to work right.
kyleyap is offline   Reply With Quote
Old 08-01-2011, 09:07 AM   #2
suberdave
Member#: 101865
88 GL-10 STi
its real hard to check it with a multimeter. unless you have a real fast good one, such as a Fluke 78 or so.
what you realy need is an oscilloscope or graphing multimeter.
you have to back probe the signal wire, you should find the voltage should vary between .200 volts and .800 volts. it should wave between the two, about 3-5 times in 5 seconds, at 2500RPM.
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 08-01-2011, 11:59 AM   #3
kyleyap
Member#: 214088
1995 WRX Type RA
JDM YO!!
i was just using a cheap multimeter so that explains why it didnt work right
Old 08-01-2011, 10:47 PM   #4
69subaru360
Member#: 159682
1995 WRX
2015 F150
Usually they seem to have 2 failure modes. It takes a dump completely and you get a cel or the car surges at cruise speeds and hesitates on light accel with no cel.
Old 08-02-2011, 12:23 AM   #5
kyleyap
Member#: 214088
1995 WRX Type RA
JDM YO!!
i was thinking it may have a partial failure or something. It sometimes has a slight hesitation on wot pulls but nothing major. i was thinking it may be the o2 sensor because it keeps failing the local emissions test and i dont wanna just change a bunch of parts unless its necessary
Old 08-02-2011, 01:22 AM   #6
pmugabi
Member#: 280926
I could never get a stock 02 sensor to work correctly on my car (as shown by my narrowband AFR gauge). The only time it worked as expected was when I got a wideband (Innovate LC-1) and wired up the narrowband output to the car.
pmugabi is offline   Reply With Quote
Old 08-02-2011, 08:35 AM   #7
69subaru360
Member#: 159682
1995 WRX
2015 F150
The O2 sensor does nothing at WOT.
Old 08-02-2011, 09:20 AM   #8
suberdave
Member#: 101865
88 GL-10 STi
+1
also if you havent already check plug gap and coil packs for cracks.
-=Suberdave=-
Old 08-02-2011, 09:57 AM   #9
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
I seem to remember something about you already doing the coil pack upgrade. Did you replace the plugs when you upgraded coils? What plugs did you install and what did you gap them?
TommyAtomic is offline   Reply With Quote
Old 08-02-2011, 10:14 AM   #10
kyleyap
Member#: 214088
1995 WRX Type RA
JDM YO!!
I havent done plugs yet. I have ngk iridiums gapped at .028 waiting to go in
Old 08-02-2011, 08:36 PM   #11
jonny_88
Member#: 245030
2006 16g'd WRX TR
CGM
I'm having problems with misfiring at constant speeds, and I also have a misfire code on each cylinder. Could a bad o2 sensor be causing this problem?
Also, pmugabi, is it normal to wire up the LC-1 to the ecu on narrowband? I might just do this if that's the case. I checked on a new sensor at o'rielly's and they wanted $240.
jonny_88 is offline   Reply With Quote
Old 08-03-2011, 03:03 AM   #12
pmugabi
Member#: 280926
Misfire could be any of plugs, coils, MAF, 02 sensor.
Yes it's easy to wire up an LC-1 as a narrowband sensor, the LC-1 manual describes how to do it. What I did in my case was to hack off the connector at the end of the 02 sensor and use that to connect to the LC-1 loom, that way you can go back to another stock 02 sensor any time you like. Plus replacement wideband sensors are only about $50-60.
FS : 07 sti rear o2 sensor Unrealgtx Engine/Power/Exhaust 7 08-04-2011 05:55 PM
Is there any way to test O2 sensor readiness? woodyak Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-25-2006 06:07 PM
Is there a way to test the O2 Sensor? F15DOC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 07-08-2005 01:07 PM
Dealer Bench testing o2 sensor? Can it be done? ShawnRS Normally Aspirated Powertrain 1 11-21-2004 06:13 PM
how to test O2 and MAF sensor Travis R General Forum Archive 3 01-04-2001 12:46 AM
