Old 08-01-2011, 06:14 PM   #1
Rymantas
Member#: 264225
2011 WRX Sedan
Question 2011 WRX Stage 1 Boost Readings
Hey guys,
I've been reading around and searching for an answer but there doesn't seem to be anything definitive.
I recently bought an AP and flashed the stage 1 93 OTS map and after letting it learn and settle, I was peaking at 15.6 psi in 4th gear(Stock intake/exhaust). So i uploaded the HWG map and drove it for about 200 miles and now im peaking anywhere from 17.4-17.8 psi in 4th gear.
My question is: Is the HWG map causing to much boost? I know the stated levels are 16.5 +/-0.8psi.
Do I have anything to worry about?
*Ive searched the site and google but cant find a definite answer. If i missed a sticky somewhere, just point me in the right direction*
Rymantas is offline   Reply With Quote
Old 08-01-2011, 06:31 PM   #2
ryyiann
Member#: 259241
2011 WRX Limited 5dr
you should have never flashed the hwg map. Boost target for stage 1 is 15.3. If you were hitting 15.6 with your normal wastegate map you should have left it because you were only .3psi off. now your around 2 or so psi off. If i were you i would be using the map that produces 15.6 psi because thats damn near the target boost for stage 1..
ryyiann is offline   Reply With Quote
Old 08-01-2011, 09:21 PM   #3
Rymantas
Member#: 264225
2011 WRX Sedan
My map says target is 16.5 psi +/- .8psi. Im using 93 OTS not 91 OTS which is 15psi. And yes i double checked the map is for the 2011 wrx.
And if anyone wants to know ive been logging every chance i get and have no knock and solid 11 AFR during boost. No feedback knock or fine knock during full acceleration in all gears.
Old 08-02-2011, 12:13 AM   #4
Tripintaz
Member#: 245218
2013 STI Limited
The AFR reading on the AP is not accurate. You need a wideband to see what your real AFR is.
17+ PSI might be a little much for a stock exhaust WRX. I would be more worried about how much boost its holding at redline rather than a 17PSI spike.
Tripintaz is offline   Reply With Quote
2011 WRX COBB tuned 295 WHP / 320 WTQ Yellow_Feva Proven Power Bragging 23 12-25-2011 09:16 PM
Dyno Tune: Stock 2011 WRX Stage 1 KWIL Proven Power Bragging 68 07-25-2011 11:36 PM
2011 WRX Stage 2 overboosting issues Jaker AccessPort 32 02-23-2011 03:01 PM
Stage 1 boost reading question wrxslickg AccessPort 2 05-22-2008 06:42 AM
Stage II boost reading off 06AspenWhite AccessPort 12 12-01-2006 07:05 PM
