Welcome to the North American Subaru Impreza Owners Club Sunday July 5, 2015
Old 08-01-2011, 10:25 PM   #1
MikeyAE86
Member#: 185525
1993 Impreza wagon
Default EJ20G target boost 12.8 only hitting 10. Problem?
Here is my problem:
On my 99% stock EJ20G ( K&N drop in, 05 sti DP)
im only hitting 10 psi at WOT.
So i thought it might have been the factory boost control. I can hear it clicking when i rev the motor up. And if i unplug it it only hits spring pressure ( 7 PSI on stock TD05H)
So then i thought maybe the ECU was screwed up somehow or mixed up with a wagon 10 psi ecu. So i just recived a Z4 ecu (12.6 target boost) and it too only hits 10 PSI
Now im stumped.
Any ideas?
Thanks in advance
-mikey b
MikeyAE86 is offline   Reply With Quote
Old 08-01-2011, 10:44 PM   #2
69subaru360
Member#: 159682
1995 WRX
2015 F150 (ordered)
You added a second cat to the downpipe. Could be the restriction.
Clean the boost control solenoid, plug in the green connnectors under the dash so it clicks and spray brake cleaner through it. Be sure all the hoses are in good shape, properly routed and the restrictor is in place.
Or just put on a mbc and be done with it like everyone else does. You can turn it up to 14-15 psi then.
Old 08-01-2011, 10:50 PM   #3
MikeyAE86
Member#: 185525
1993 Impreza wagon
yeah i just pulled the line off the wastegate and it pulls to 15 easy, i lifted at around 5k right as it touched 15 and my warning light went off
so gotta be the boost control
so just clean it up and try again?
Old 08-01-2011, 10:50 PM   #4
MikeyAE86
Member#: 185525
1993 Impreza wagon
and the downpipe only has the primary cat, the second cat is gutted and missing
Old 08-01-2011, 10:53 PM   #5
69subaru360
Member#: 159682
1995 WRX
2015 F150 (ordered)
Yes, try cleaning it. Really just pick up a mbc, set it and forget it. The boost control on these sucks anyway.
Old 08-01-2011, 10:57 PM   #6
MikeyAE86
Member#: 185525
1993 Impreza wagon
ive got one. So 14 is safe? Im on 91 in CA and ambient temps of 100 degrees
Old 08-01-2011, 11:06 PM   #7
69subaru360
Member#: 159682
1995 WRX
2015 F150 (ordered)
The fuel cut is 15.5 or so.
If you are worried about set it to stock boost levels.
The Z4 is a tame ecu compared to most of the other jdm ecus. You'd probably be ok.
Old 08-02-2011, 12:24 AM   #8
eg33GC
Member#: 206851
56 Belair
Pro Street
im going full noob here, but does anyone have a comprehensive vacuum routing diagram?
i recieved an engine in shambles
eg33GC is offline   Reply With Quote
Old 08-06-2011, 12:19 AM   #9
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
Hey Mikey... Something is definitely going on with your boost control solenoid. My car NEVER saw below 12 psi with that ecu. I actually would go to 14 or so and then taper down a couple of psi. It could actually also be bad gas OR knock sensor because these ecu's are very smart and will pull timing and lower boost if you are knocking badly.
This is directly from Enduring Solutions website in the UK regarding the OEM JECS ecu:
"Closed Loop Knock Control is arguably the most important feature on a road car ECU. Given the variability of pump fuel in the UK, the amount of detonation an engine will experience on different tanks can vary considerably. An ECU equipped with knock control will listen to the output of the knock sensor and retard ignition timing until no more detonation is sensed. The OEM JECS ECU will also richen the mixture and reduce boost pressure if significant detonation is heard. An aftermarket ECU without this facility relies on every tank of fuel being exactly the same as the one it was mapped on or has to be mapped with a safety margin, costing power. Owners of knocklinks will know that activity between tanks of the same type of fuel can vary significantly, which is why knock control is one of the most important features of an ECU. It is very rare for aftermarket ECUs to offer it, even as a cost option. "
Enduring Solutions offers a tuneable daughterboard and software combo which turns our ecu's basically into standalones while keeping all the factory safety features of the ecu intact.
http://www.enduringsolutions.com/faqs.html
blkgm8 is offline   Reply With Quote
Old 08-07-2011, 11:11 AM   #10
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Rather roundabout way to say it sounds like a knock issue.
TommyAtomic is offline   Reply With Quote
Old 08-07-2011, 05:46 PM   #11
jdmwrx94
Member#: 211619
94 jdm wrx
red
without the mbc my z4 would run between 10 and 13 psi depending on temp
jdmwrx94 is offline   Reply With Quote
Old 08-08-2011, 02:14 AM   #12
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
Yea... I guess I could have just said it sounds like a knock issue without giving the reasons why to back it up. LOL.
Actually I meant literally when I said had that ecu in my car. He just picked it up from me. I just thought I would chime in with some information that may actually help with his problem.
Old 08-15-2011, 10:59 PM   #13
klys
Member#: 225974
2012 Impreza WRX
Plasma Blue Pearl
Default I also need it
Indeed I've been looking all over the net for a real MY92-95 wrx boost/vacuum line diagram.
I can't seem to reach more than .5bar the car feels sluggish
I have a new uncracked sti uppipe
pretty much a 3" turbo back
no known leaks
thanks to anyone who can help out
Also compression of all 4 cyl is between 170 and 173 PSI
klys is offline   Reply With Quote
Old 08-16-2011, 02:52 AM   #14
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
This is the best I have. It is for a '92 libertyRS EJ20G. It is close to the WRX. One difference that I know of for the vacuum side of things is that there are no purge valves on the JDM WRX.
rob is offline   Reply With Quote
Old 08-16-2011, 07:29 AM   #15
luka
Member#: 194742
1993 Impreza WRX JDM
libertyRS had a water-to-air intercooler?
luka is offline   Reply With Quote
Old 08-16-2011, 12:17 PM   #16
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
Yes.
Mikey what is your boost gauge reading when the engine is off? Is it exactly 0 or a bit below? That could also explain why you think you're only running 10 whil ein fact you might be running almost 13 above atmospheric pressure.
Marnix is offline   Reply With Quote
Old 08-16-2011, 12:18 PM   #17
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
indeed it did.
Old 08-17-2011, 12:03 AM   #18
klys
Member#: 225974
2012 Impreza WRX
Plasma Blue Pearl
thanks and which ports is which on the 3 port solenoid shown here:
I'm guessing if you turn the drawing 90 counter clock wise it should be OK?
Oh and is there really an O2 sensor cause I have the original dump pipe and it looks like a temps sensor...
I now have a brand new greddy downpipe without any holes except for a wideband around where the 2nd cat used to be.
thanks.
Old 08-17-2011, 12:05 AM   #19
klys
Member#: 225974
2012 Impreza WRX
Plasma Blue Pearl
Source of some info concerning boost solenoid
http://autospeed.com/cms/title_Shoot...7/article.html
Old 08-17-2011, 06:43 PM   #20
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
That site seems to have alot of good info on pre-2002 wrx's in general including some great stuff on the differient subaru top mount intercoolers.
Old 08-18-2011, 08:41 AM   #21
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
On some JDM engines the O2-sensor is installed in the RH exhaust manifold right before the uppipe. In the downpipe there is an EGT-sensor.
Old 08-18-2011, 11:18 AM   #22
blessthekellen
Member#: 273859
MY98
WRX
I am having the exact same issue with my 95 WRX STi.
Hitting 10 PSI consistently through every gear. Reset the ecu. All is fantastic. Car runs smooth and pulls very hard, but will not hit its "target" boost. I have been told the stock PSI on these cars is approx. 14 with the ecu in the V2 STi's.
I unplugged the line going to the wastegate as well. Boom 15 PSI with ease.
Does this mean there is something wrong with the factory boost solenoid? This has been asked but no one has given a straight up answer. Solution: Grab a MBC, set it and forget it at 15 PSI since the factory boost solenoid is clearly on its way out/not working correctly?
blessthekellen is offline   Reply With Quote
Old 08-18-2011, 02:54 PM   #23
Jarrod164
Member#: 253937
1995 WRX
By unplugging the line going to the wastegate, you theoretically get infinite boost right?
It is possible that your wastegate actuator is opening too soon but I would tend to say boost controller more (the wastegates rarely fail right?). And even if your wastegate is opening too soon, if you put in the MBC, the wastegate won't see any pressure until the MBC hits its point (unless it's one of those bypass ones).
Jarrod164 is offline   Reply With Quote
Old 08-18-2011, 10:20 PM   #24
klys
Member#: 225974
2012 Impreza WRX
Plasma Blue Pearl
Yeah I looked under the car today and it's indeed there!
I did a boost leak test and I found that the gasket between my plastic turbo outlet pipe to intercooler was squeezed wrong.
I fixed it and now I'm getting close to .7 .8 kg/cm2 but car is still VERY slugish much like my 2000 Brighton when the check engine light is on due to a sporadic knock sensor fault (happens when it rains hard).
seems like the timing is being pulled.
can an ABS light put the ECU in limp mode as mine is on?
Old 08-19-2011, 01:33 AM   #25
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
Is the speedo working?
Problems Hitting target boost levels with grimmspeed MBC... ScooByBooSt007 Newbies & FAQs 6 04-29-2011 04:06 PM
utec 04 wrx only hitting 10 psi Joebrauk Newbies & FAQs 5 02-10-2011 03:38 PM
2002 Bugeye - logs look great, but only hitting 8 lbs. boost STGI Cobb? saab-on-the-cobb Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-30-2009 03:23 PM
Only hit target boost in 5th and 6th gear, normal? (AP stg. 2) homiusang AccessPort 11 04-28-2006 10:05 PM
boost fluctuations, not hitting target boost! SILVERHKSWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-17-2005 09:23 AM
