Old 08-01-2011, 11:43 PM   #1
Thunderburn
Member#: 287149
2008 Wrx Sti
Default Quick question. How accurate is the Dyno meter on the accessport?
I did a dyno run on this feature and got a result of 334.96 whp at 5481 RPM and 336.58 tq. They seem a little high possibly. I was just curious if anyone knew how close it is to being accurate.
Thunderburn is offline   Reply With Quote
Old 08-04-2011, 10:30 AM   #2
HoboBob
Member#: 253560
'08 Jeep Wrangler
Take it with a grain of salt but it is in the ball park. It all depends how close you were with your weight input.
HoboBob is offline   Reply With Quote
Old 08-04-2011, 06:52 PM   #3
roadtrip1098
Member#: 185688
2006 STi
WR Blue
Technically if you are 100% exact on your weight input, on a perfectly level street, with no wind and are using the right tire size it should be exact. This is because HP=Work/Time and Work=Force*Distance and Force=Mass*Acceleration. The only parameters that the access port cannot figure out is the vehicle weight and wind resistance. It does add a significant amount for "drivetrain loss" if I remember correctly which may make it less accurate. For AWD cars most people go with a 20% power loss figure, don't ask me where they got it, but taking the 20% from your readings would put you around 268HP which is fairly spot on for what STi's dyno at on the wheels.
roadtrip1098 is offline   Reply With Quote
How Important Is That Little Cover on the Bottom of the Bellhousing? williaty Transmission (AT/MT) & Driveline 4 06-02-2010 08:45 AM
how accurate is ap2 dyno feature! EJ20_lee AccessPort 2 05-15-2008 02:05 PM
How accurate is A/F readout on Apexi turbo timer? megaben300 Electrical & Lighting 6 07-24-2006 12:15 AM
how important is a turbo timer on the WRX? turbodreams Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 08-18-2004 06:11 PM
