Notices
Old 08-02-2011, 11:24 PM   #1
staticchmbr
Member#: 140108
2000 impreza OBS
silver/titanium
Default accessport map selection questions 04 wrx.. catless tbe stage 1/2 and economy mode?
so i just purchased a 2004 wrx from a coworker. it is completely stock except for:
a turboxs 4" catless downpipe, and a straight through pipe all the way back into a magnaflow muffler. i have to look under the car, because i forget if he said the header/up pipe was replaced.
anyways, its flashed for the stage 2 91 octane. i have a long drive into work, and i can see the gas needle drop..
would i be ok with going to a stage 1 91 octane map? i also saw on the cobb website that they have an economy map.. LOOK BELOW! what psi is this running? what kindof gas maileage can i expect? will this be ok with my TBE.. i dont want any leaning out...
Map Database
The map database is where you can find the latest AccessPORT maps offered by COBB Tuning. To download a map, simply click on the link that corresponds to your vehicle and map type.
Map NameDescriptionRev. #2004
WRX
Stage 1 91 octStage 1 for Stock Vehicles. 91 octane fuel. 255HP (+12%) / 255lb-ft (+18%)1.30[download map]
[realtime map]
[map notes]
Stage 1 93 octStage 1 for Stock Vehicles. 93 octane fuel. 260HP (+15%) / 260lb-ft (+20%)1.30[download map]
[realtime map]
[map notes]
Stage 2 91 octStage 2 using 91 octane fuel. Requires turboback exhaust. 280HP (+23%) / 285lb-ft (+31%)1.30[download map]
[realtime map]
[map notes]
Stage 2 93 octStage 2 using 93 octane fuel. Requires turboback exhaust. 285HP (+26%) / 285lb-ft (+31%)1.30[download map]
[realtime map]
[map notes]
Valet ModeValet mode operation. Lower Rev limiter and low boost.1.30[download map]
[realtime map]
[map notes]
Anti-TheftAnti-Theft mode. Does not allow vehicle to start.1.30[download map]
[realtime map]
[map notes]
Economy ModeEconomy mode requiring minimum 91 octane fuel. Low boost and increased ignition timing for optimal fuel savings. Not a performance map and not recommended for aggressive driving.1.30[download map]
[realtime map]
[map notes]
Stock ModeStock Mode style map. Uses stock fuel, timing, and boost values for conditions when you need the vehicle's ECU to act like it is still stock.1.30[download map]
[realtime map]
staticchmbr is offline   Reply With Quote
Old 08-03-2011, 10:36 AM   #2
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
It's a stage 2 car, keep the stage 2 map...
wrxdrvr is offline   Reply With Quote
Old 08-03-2011, 12:25 PM   #3
ArSoN9
Member#: 285777
2004 STi-
The economy map just lowers the fuel tables slightly..might make the car run leaner if ur getting on the throttle.
ArSoN9 is offline   Reply With Quote
Old 08-03-2011, 01:10 PM   #4
staticchmbr
Member#: 140108
2000 impreza OBS
silver/titanium
basically, if i run a stage 1, will i run into issues? i see the gas needle drop as im driving.. i want to get some better mileage
Old 08-03-2011, 02:29 PM   #5
BOOSTEDSTI07
Member#: 290154
Remember to update ur firmware by plugging ac into ur home cpu....
BOOSTEDSTI07 is offline   Reply With Quote
Old 08-03-2011, 03:34 PM   #6
staticchmbr
Member#: 140108
2000 impreza OBS
silver/titanium
yea, thats my next step.. the guy i got it off of said it hasnt been updated in about 2 years
so i should be ok running economy on my stage 2 car?
Old 08-03-2011, 03:43 PM   #7
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
I wouldn't run the econo map as a base map but as an RT map on top of a stage 2 base map, yes it should be OK. Not that it will make that much of a difference to make up for the loss of get up and go that the car should have but now won't.
Old 08-06-2011, 12:11 PM   #8
staticchmbr
Member#: 140108
2000 impreza OBS
silver/titanium
just ran through my first tank of gas.. getting around 14 MPG.. mixed highway.. only got on the gas a few times..
i have new plugs and wires, and again the only mods are the accessport stage 2 and corresponding exhaust...
it definitely needs to be updated.. hopefully thats the issue.
Old 08-06-2011, 09:17 PM   #9
Legend2
Member#: 250595
04 wrx wagon
Wires?? I get a average of 24 mpg of mixed driving 28 mpg rural 50-65 min. Lights. On a stg2 93 map. The key is staying out of boost. It sounds like you may have some issues which is why you are getting bad mpg.
Legend2 is offline   Reply With Quote
Old 08-06-2011, 11:54 PM   #10
Mr. Me
Member#: 193598
2002 Bugeye Wagon
Thats really low milage. I just ran from tacoma to bellingham and back today with some city driving in bham and seattle on the way and averaged 29.8 mpg. Im on a 91 octane stg 2 map with a turboxs catless uppipe and cobb catted bellmouth downpipe on my 02 wrx wagon. It also has a 3 inch catback but that shouldnt matter.
All I did that was out of the ordinary was to stay out of boost as much as possible. I just set the cruise control at traffic speed (65-70 mph)
Mr. Me is offline   Reply With Quote
Old 08-07-2011, 11:54 AM   #11
staticchmbr
Member#: 140108
2000 impreza OBS
silver/titanium
i just filled it again, so im keeping a better eye on it. the guy i bought it from said that he got between 19 and 24 mpg.. maybe it was a fluke? im out of boost alot.. just cruising with my foot barely on the gas. im keeping a closer eye on the mileage this time around.. maybe it wasnt a full tank last time since he said he filled it.. hmmm...
also, he got it tuned a precision tuning, so i wonder if its something they programmed into the ecu as a basemap. this is why i need to get my accessport up and running again.. anyone have the obd2 wire for a v1 they want to sell?
Old 06-17-2012, 10:54 PM   #12
sweetmf14
Member#: 322650
Would you get better gas Miles if your not getting on the throttle?
sweetmf14 is offline   Reply With Quote
Old 06-18-2012, 09:29 AM   #13
Cobb Tuning
Member#: 4803
The primary means by which the fuel economy map improves mpg is by disabling boost control (i.e. minimal boost) and some minor timing/ fueling changes. You could achieve most of the gains of this map on one of the performance maps by driving very conservatively and staying out if boost as much as possible.
Bill
Stage 2 and valet mode question the Stryder AccessPort 3 02-16-2010 11:12 AM
FS: VA 04 WRX Cobb AP V.1 Unmarried and ready. All_Thumbs Engine/Power/Exhaust 1 11-04-2007 11:14 AM
Initial D, complete Stage 1, 2, and 3. VCD's wrx2ndregime Non-Subaru Stuff 4 11-29-2006 09:37 AM
Stock,stage 1,2 and 3 time slips sleestak6326 Proven Power Bragging 16 08-31-2006 05:03 PM
Cobb Stage 1/2 and Mass Emissions zerb New England Impreza Club Forum -- NESIC 6 03-18-2006 03:12 PM
