Old 07-29-2002, 02:24 PM   #1
Merdock777
Member#: 21256
2002 Impreza 2.5RS
BlindYoAssPlatinumSilver
Default Buzzy tinny engine?
After bringing the revs up if I let of the gas quick I hear a buzzing tinny sound comeing from the engine in ture with with the RPM's. I'm wondering if it's valve lash, but i really have no idea. Does anyone know what else it might be or if it is nothing at all? I'm really sure that my engine wasn't doing that 2 weeks ago so...
Merdock777 is offline   Reply With Quote
Old 07-29-2002, 03:08 PM   #2
Reflex-Arc
Lord of the Gilf
Member#: 1703
2012 Fiat 500 Sport
Copper
Did you check for a rattling heat shield?
Reflex-Arc is online now   Reply With Quote
Old 07-29-2002, 03:40 PM   #3
Section 8
Member#: 821
Do you know where the sound is coming from? It sounds like you think that it is coming from more or less the engine compartment. It could be a heat shield, or something loose inside you muffler or cat (though I doubt it). My muffler has a crappy sould like that when I let off the gas. Its a vibrating noise, and I believe it to be the baffle in the muffler that is doing it.
A piece in your muffler might be loose, or a heat shield. I would bet on a heat shield.
cheeRS,
Greg
Section 8 is offline   Reply With Quote
Old 07-29-2002, 03:55 PM   #4
Merdock777
Member#: 21256
2002 Impreza 2.5RS
I don't think that it is coming from the muffler or the cat. it sounds like its comeing from inside the engine not just in the engine compartment. I'll rev it up in neutral with the hood up and and extra person tonight and see if i can't get a better idea of where it's coming from. I'll also check the heat sheild and see if that is making contact or noise. Thanks for your help any other ideas?
Old 07-30-2002, 02:32 PM   #5
Giova
Member#: 1663
2000 Impreza RS
BRP
Any word on this yet, I think I have the same noise, it only happens when I'm on it past 4500 RPM, I tried recreating it while I was parked and had the hood popped up, I sdon't think it does it with the cas in neutral, only whenin gear and accelerating. I doesn't matter which gear I'm in either. The only thinks that have changed is I have added a Borla header but the noise has started after the header has been on for about one month and I did recently change my oil and put in 5w 30.. Any input would be helpfull thank you all
Giova is offline   Reply With Quote
Old 07-31-2002, 01:32 PM   #6
Jademonkey
Member#: 9213
2000 RS
Red
I have the same noise... I took it into the dealer thinking it was engine ping...he told me it wasn't.... They didn't fix the problem...but they also said not to worry because it's not ping...
Jademonkey is offline   Reply With Quote
Old 07-31-2002, 02:05 PM   #7
Merdock777
Member#: 21256
2002 Impreza 2.5RS
No it's definetly not ping.
Racecomp Engineering pre-order-Updates on swaybars and camberplates dalesalignment&brake VIC Vendor Classifieds 62 07-23-2010 01:06 AM
ABS, Airbag, and Rear Diff light on after washing engine Acejam2k Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 06-02-2010 12:32 PM
Tinny high frequency Vacca Rabite Car Audio, Video & Security 2 08-10-2004 12:32 PM
tinnie-winnie kartboy knob Gundoo Transmission (AT/MT) & Driveline 5 05-07-2003 04:55 AM
