Old 08-04-2011, 10:28 AM   #1
JonnyD91
Member#: 250084
2010 WRX Sedan
DGM Cobb Stg. 1
Default 2010 WRX Stage 1 knock issue? logs inside.
Not to sure whats going on here but i did some 3rd gear pulls it was about 91 degrees out and im not sure if im seeing a knock that's bad or its just noise.
Logs below:
https://spreadsheets7.google.com/spr...hl=en_US#gid=0
https://spreadsheets6.google.com/spr...hl=en_US#gid=0
JonnyD91 is offline   Reply With Quote
Old 08-07-2011, 02:40 AM   #2
Nimbus09
Member#: 212399
09 wrx 301hp/328tq
'00 miata blue
lol, why is your boost target 25psi??? and omg at the IAT's!!! you should also be logging your dynamic advance multiplier. it seems very obvious you are trying to detect knock and that parameter is important. the stuff you see in fine and feedback seem fine.
Nimbus09 is offline   Reply With Quote
Old 08-07-2011, 09:45 AM   #3
Cobb Tuning
Member#: 4803
Logs below:
Hello.
Your log is missing "Throttle Pos." which is a crucial parameter. I would just log the default AccessPORT list by going into the "Monitor" menu and selecting "Reset Log List".
Also, when providing logs, you want to list all your mods (if any) and also the exact map you are running (ex. stage 1+SF 91 ACN).
Bill
Old 08-07-2011, 05:50 PM   #4
JonnyD91
Member#: 250084
2010 WRX Sedan
DGM Cobb Stg. 1
I am currently using Stage1 93 MTv102
I did 4 more pulls on some new gas ans the outside temp was now 72 degrees. How do these look?
Is the knock sum normal for what is shows in the log?
Max boost i hit was around 15.38psi
Also another question how come the AP shows vacuum @ -10 and my boost gauge shows -21?
I did this before I saw the response to the post. I can log again with the other parameters. But do these look a little better than the first ones?
Thanks
John
https://spreadsheets.google.com/spre...JvZ2c&hl=en_US
https://spreadsheets.google.com/spre...VTNmc&hl=en_US
https://spreadsheets.google.com/spre...haY1E&hl=en_US
Old 08-07-2011, 08:16 PM   #5
Cobb Tuning
Member#: 4803
They look good as far as knock correction is concerned. Do some additional 3rd gear WOT runs (if you can do so safely) with the default set of parameters.
Your gauge probably reads in. Hg in vacuum compared to the AccessPORT which always is in units of psi (if imperial units are selected).
Bill
*** PhatBotti Tuning: 2010 WRX 304whp/323wtq Homestead-Miami Spdway Video Inside! *** PhatBotti Tuning TKR Proven Power Bragging 25 12-22-2012 06:23 PM
2010 WRX Stage 1 Mileage melacon AccessPort 14 05-29-2011 11:45 PM
Engine Knock. Data log inside. whitey615 Engine Management & Tuning 12 05-27-2010 02:36 AM
Log of my 05 WRX stage 1, thoughts? Overlord2kx Commercial ECU Reflashes 4 05-29-2007 01:32 PM
Vishnu Stage 2 Knock Issue Quelled w/ User Tuning Obsidian Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 06-24-2003 09:50 AM
