Bay Area Impreza Club
Go Back   NASIOC > NASIOC Chapters > Bay Area Impreza Club Forum -- BAIC
Old 07-29-2002, 11:55 AM   #1
SONofSAM
Member#: 8407
Unhappy ATTN: Bill or Chris
Is there anyway you can help me!
My Engine light turn on after i had clean/steam my engine ( I did cover some of the parts that can't be wet/steam)...
i even try disconnect the battery 2 time's for like 20-30 mins and runs my car around my block for like 3 time's...when i shift from 2nd to 3th gears and step on the gas pedal and i felt the car is little choke (not much! but very little)...the engine light turn on right away Blink Blink...
do you guys think this is a big problem! should i run couple more time's and see's the light still turn on!
Since my car is 96 1.8 model, can you guys pull the code out.
when will be the next installfest!
please educate me a bit!
thanks guys,
SONofSAM is offline   Reply With Quote
Old 07-29-2002, 12:12 PM   #2
christoph1371
Member#: 1090
We can pull the code, sure. I will be busy the next few nights. Try and swing by this weekend.
Does the light come on immediatly after reset?
christoph1371 is offline   Reply With Quote
Old 07-29-2002, 12:28 PM   #3
SONofSAM
Member#: 8407
Nope, maybe a few mins when the car is operate...then light starting to blink...
thanks Chris i swing by this weekend...
Old 07-29-2002, 03:25 PM   #4
Catfish
Member#: 1322
2000 2.5RS Sedan
72 Datsun 240Z
Default You have water in some of your connectors.
It will eventually evaporate but you'll have problems until it does and it may take a week or so for that to happen. Best bet is to check the connectors, starting with the ones you didn't cover before the steam cleaning and dry them out. A hairdryer works great, or if you don't have one simply leaving them unplugged for a few hours might do the trick. Don't forget to check your sparkplug wires as well.
This is why it is so important to make sure you properly cover any electrical connectors (and unplug the battery) prior to any kind of steam/water cleaning.
Catfish is offline   Reply With Quote
Old 07-29-2002, 03:30 PM   #5
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Dude, you know its against the rules to post this in so many forums.
Anyways Id say find all the electrical connectors you can dry them out. I usually take a paper towel and rip a small section so I can stick it in the connector.
ciper is offline   Reply With Quote
ATTN: Bill or anyone else in parts... Stime187 South East Region Forum 0 06-10-2003 01:17 PM
Attn: Bill or Jerry Snowman South East Region Forum 3 10-22-2002 04:18 PM
Attn: Bill & Chris, my 1st request for non-Subie stuff sjt Bay Area Impreza Club Forum -- BAIC 2 03-21-2002 03:20 PM
Bill or Chris? (or anyone else for that matter...) ryball Bay Area Impreza Club Forum -- BAIC 0 02-04-2002 04:41 PM
Attn: Bill and Chris Andrew Bay Area Impreza Club Forum -- BAIC 1 10-29-2001 01:15 PM
Message Board Statistics All times are GMT -4. The time now is 04:46 PM.
