Old 08-04-2011, 07:09 PM   #1
scooby kidd
Member#: 242136
1993 Impreza v2 sti
Rattle can black
Default Ej20g to ej20k
Here is the deal I bought a 93 Subaru L with a full v2 sti swap later found out that it was a pile and literally blew a hole in the top of the block behind the altenater under the intake Man. But otherwise I have a ej20k replacement complete ready to go so if anyone That has some knowlede/experience with these turbo motors wants to make some $$ I live in Avondale and would like to have the car running ASAP seeing it's going to be my dd thanks
scooby kidd is offline   Reply With Quote
Old 08-04-2011, 11:44 PM   #2
RallyColtTurbo
Member#: 16819
The fastest way would be to put the EJ20G intake manifold and accesories on the EJ20K longblock.
Everything will bolt up and the ECU should be fine.
If you want to run the EJ20K intake setup, then you will run into compatability problems with the throttlebody sensors and the EJ20G ECU. Unfortunately the throttlebodys won't simply swap between manifolds.
Why did the EJ20G throw a rod?
RallyColtTurbo is offline   Reply With Quote
Old 08-05-2011, 06:34 AM   #3
peanutswagon
Member#: 197057
1997 98 Foz V3 swap
Where is Avondale? And what year is the 20k?
peanutswagon is offline   Reply With Quote
Old 08-05-2011, 07:56 AM   #4
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
As RCT suggests... Easiest and trouble free.
Be careful not to break the EJ20K aswell, these engines do like to rev but the rod bolts cannot handle the stress...
Marnix is offline   Reply With Quote
Old 08-05-2011, 01:01 PM   #5
scooby kidd
Member#: 242136
1993 Impreza v2 sti
Rattle can black
Avondale is out west of phx and also need to take into account it's running a stand alone here is the link of the car and all it's mods http://www.socalsubies.com/forums/sh...ad.php?t=11187
Old 08-05-2011, 01:04 PM   #6
scooby kidd
Member#: 242136
1993 Impreza v2 sti
Rattle can black
I don't exactaly know why it threw there was plenty oil and boost was set at 7psi my guess is that the motor was just tired
Old 08-05-2011, 03:34 PM   #7
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
Rod bolts? I believe you, but I haven't heard that issue before. Just the bearings.
Smoke is offline   Reply With Quote
Old 08-05-2011, 03:52 PM   #8
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
The bearings go because the weak rod bolts increases bearing clearance and causing the bearings to wear out.
It could very well be that the broken motor of the topic starter also has thrown a rod due to a a sheared bolt.
Old 08-05-2011, 05:55 PM   #9
scooby kidd
Member#: 242136
1993 Impreza v2 sti
Rattle can black
Nicely put who wants to make a lil cash and help put this beast back together
Old 08-05-2011, 08:06 PM   #10
scooby kidd
Member#: 242136
1993 Impreza v2 sti
Rattle can black
Well I did some research and the complete motor I had bought is in fact a ej20g not a k but the valve covers are in fact different all the connections on the manifold look the same except the car I have is running a older us model pwr steering pump an a ac delete
Old 08-06-2011, 02:22 AM   #11
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Everything swaps over, just use the longblock. It really is not that hard if you have a few tools (and an engine hoist).
Need pictures of Ej20G and EJ20k THrottle Body bmxpunk Pre-2002 Factory Turbo Powertrain 39 12-17-2012 06:19 AM
JDM EJ20G and EJ20K ECUs Marnix Pre-2002 Factory Turbo Powertrain 3 09-21-2012 10:55 AM
ej20g cop to ej20k wasted spark De-Specialist Subaru Conversions 7 06-22-2011 04:46 PM
WTB: JDM ej20g, ej20h, ej20k, or ej20r heads manxaru Private 'Wanted' Classifieds 7 03-23-2008 02:44 PM
ej20g vs. ej20k Spilner Subaru Conversions 33 07-01-2007 06:32 AM
