Old 08-05-2011, 12:08 AM   #1
ToxicCrucible
Member#: 254200
2008 WRX - 316hp
Rally Blue
Default Confused on what map to get
Im at stage 2 right now. I am getting a new VF52, front mount, turbo inlet and CAI in the next 2 weeks.
Am I still at stage 2 or 2.5? There is a company that has a 2.52 map but it looks like it is all based on the stock air box.
vf-52 turbocharger (OEM Turbo on the 09+WRX)
-Stock boost control solenoid with the VF-52 restrictor pills found on the 09+WRX.
-Stock Engine
-Aftermarket Downpipe
-Stock or Aftermarket Cat back exhaust system.
-Alternate maps are provided for use with either one of the following
----Stock Airbox (Stock Air Filter is preferred)(Has been tested to work well with aftermarket drop in filters)
----K+N Typhoon intake system Item #69-8004TTK
----TurboXS intake system Item #WS08-CAI
----Ultimate Racing intake system Item #UR-10034
----AEM intake system Item #21-478WR
----AVO intake system Item #S2C07G42A002T
----Perrin intake system Item #PSP-INT-320
ToxicCrucible is offline   Reply With Quote
Old 08-05-2011, 12:09 AM   #2
poly_poly-man
Member#: 262988
2005 Baja Turbo
Regal Blue Pearl
why don't you get a protune?
poly_poly-man is offline   Reply With Quote
Old 08-05-2011, 12:45 AM   #3
ToxicCrucible
Member#: 254200
2008 WRX - 316hp
Rally Blue
yeah, thats always an option. I figured I already had the access port might as well use it
Old 08-08-2011, 07:47 PM   #4
424wrx
Member#: 171948
08 wrx vf52 swap
best et,12.6@108.7
i have that tp map.it comes with all those maps for the different intakes. i highly reccomend the map.
424wrx is offline   Reply With Quote
Old 08-09-2011, 12:10 AM   #5
ToxicCrucible
Member#: 254200
2008 WRX - 316hp
Rally Blue
Cool, I decided to get the 2.52 map Thanks!
Old 08-09-2011, 08:02 AM   #6
424wrx
Member#: 171948
08 wrx vf52 swap
best et,12.6@108.7
make sure you email cobb and get a copy of accesstuner race software. thats the only way to up load the map to the accessport.
Decided on what TV to get CalcVictim Off-Topic 27 12-04-2008 06:10 PM
Need advice on what parts to get. ndubz Newbies & FAQs 18 11-21-2008 01:58 PM
Need input on what clutch to get. rallysport02 Transmission (AT/MT) & Driveline 2 03-11-2005 08:13 PM
Input on what Turbo to get... Works Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-01-2003 10:33 PM
Any Suggestions on What Intake To Get? ejicon Legacy Forum 12 11-01-2001 05:36 PM
