Old 08-05-2011, 09:42 PM   #1
Kitty93
Member#: 260210
Default Jdm. Diagnostic plug in?
Is there one? or not. I'm getting a check engine light. And my cars in limp mode.
Thanks.
Kitty93 is offline   Reply With Quote
Old 08-05-2011, 10:24 PM   #2
fishheadback
Member#: 68120
1998 RS 2.0 vf23 STi
& MK6 GTI
No, you have to find the black diagnostic plugs and connect them. Then count the number of flashes on the CEL.
Stock, the plugs are under the steering column.
Mine is swapped, and they are under the kick panel where the ecu is.
Your location may vary. . .
Little more info on it below. Codes are pretty standard on OBD1 Subaru stuff.
http://www.surrealmirage.com/subaru/engine.html
fishheadback is offline   Reply With Quote
Old 08-06-2011, 02:24 AM   #3
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
Actually there is one, on older models (pre 1999) there is a yellowish orange plug for the Subaru Select Monitor. Even US dealers will be able to diagnose it with the cartridge for the USDM Impreza of the same model year.
But as stated above you can also connect the single plug black or green diagnostic connectors and the CEL will flash the trouble code.
Marnix is offline   Reply With Quote
Old 08-07-2011, 03:39 AM   #4
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Evoscan and the SSM1 port is quite handy.
TommyAtomic is offline   Reply With Quote
Diagnostic Plug on 08 subaru? Miketsmith Electrical & Lighting 3 02-05-2015 04:56 PM
Looking for diagnostics help in Allston Ma Snoobydoo127 New England Impreza Club Forum -- NESIC 6 06-28-2011 09:34 AM
ABS diagnostic plug carl s. Brakes, Steering & Suspension 2 06-07-2007 04:36 PM
Diagnostic shops in Marin? Chrisnonstop Bay Area Impreza Club Forum -- BAIC 2 06-21-2004 02:37 PM
who is the best diagnostic mech in club philo2g Tri-State Area Forum 7 12-19-2002 08:46 AM
