Welcome to the North American Subaru Impreza Owners Club Friday March 27, 2015
Old 08-05-2011, 10:17 PM   #1
fishheadback
Member#: 68120
1998 RS 2.0 vf23 STi
& MK6 GTI
Default STi shim under bucket help please.
I am in need of some shims for my heads. I have the dimensions and was wondering if anyone knows where to get them and what part numbers I need.
*Shim under bucket*- 11.45mm dia
Thanks
Im not sure how specific they are so I took the size out a few decimal places.
1x 2.52984
1x 2.53111
1x 2.52603
1x 2.52222
1x 2.52476
2x 2.52349
Edit: HOLY SMOKES! I just looked at japan parts and the picture that it shows for under bucket is $81!!!
http://japanparts.com/db/partslist.p...x=0&submit.y=0
fishheadback is offline   Reply With Quote
Old 08-05-2011, 11:04 PM   #2
fishheadback
Member#: 68120
& MK6 GTI
Well I think I found them. Figure I would put them here incase anyone else needs them.
Now the question is where do you get them?? I google search it and all it pulls up is some russian websites.
Originally Posted by Cbgrandtheftauto View Post
I posted the other day about 20K shims. I ran across them in "My Documents" of all places
For anyone interested...
Buckets 13228AA020
Shims:
13218AD000 1.76
13218AD010 1.78
13218AD020 1.80
13218AD030 1.82
13218AD040 1.84
13218AD050 1.86
13218AD060 1.88
13218AD070 1.90
13218AD080 1.92
13218AD090 1.94
13218AD100 1.96
13218AD110 1.98
13218AD120 2.00
13218AD130 2.02
13218AD140 2.04
13218AD150 2.06
13218AD160 2.08
13218AD170 2.10
13218AD180 2.12
13218AD190 2.14
13218AD200 2.16
13218AD210 2.18
13218AD220 2.20
13218AD230 2.22
13218AD240 2.24
13218AD250 2.26
13218AD260 2.28
13218AD270 2.30
13218AD280 2.32
13218AD290 2.33
13218AD300 2.34
13218AD310 2.35
13218AD320 2.36
13218AD330 2.37
13218AD340 2.38
13218AD350 2.39
13218AD360 2.40
13218AD370 2.41
13218AD380 2.42
13218AD390 2.43
13218AD400 2.44
13218AD410 2.45
13218AD420 2.46
13218AD430 2.47
13218AD440 2.48
13218AD450 2.49
13218AD460 2.50
13218AD470 2.51
13218AD480 2.52
13218AD490 2.53
13218AD500 2.54
13218AD510 2.55
13218AD520 2.56
13218AD530 2.57
13218AD540 2.58
13218AD550 2.59
13218AD560 2.60
13218AD570 2.61
13218AD580 2.62
13218AD590 2.63
13218AD600 2.64
13218AD610 2.65
13218AD620 2.66
13218AD630 2.67
13218AD640 2.68
13218AD650 2.69
13218AD660 2.70
13218AD670 2.72
13218AD680 2.74
13218AD690 2.76
13218AD700 2.78
13218AD710 2.80
13218AD720 2.82
13218AD730 2.84
13218AD740 2.86
13218AD750 2.88
13218AD760 2.90
13218AD770 2.92
13218AD780 2.94
13218AD790 2.96
13218AD800 2.98
13218AD810 3.00
13218AD820 3.02
13218AD830 3.04
13218AD840 3.06
13218AD850 3.08
13218AD860 3.10
13218AD870 3.12
13218AD880 3.14
13218AD890 3.16
13218AD900 3.18
13218AD910 3.20
13218AD920 3.22
13218AD930 3.24
These are for the 20K STi with shim under bucket. Thanks again to Marnix for the part numbers
Old 08-06-2011, 02:20 AM   #3
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
The EJ20G type RA under buckets are different and more expensive, the EJ20K shims are not as expensive and the same as EJ207 under bucket shims. I have a few used shims if you're interested I can measure them this Sunday.
Marnix is offline   Reply With Quote
Old 08-08-2011, 12:15 PM   #4
luka
Member#: 194742
1993 Impreza WRX JDM
why are there so many sizes? does each valve have a unique sized shim?
luka is offline   Reply With Quote
Old 08-08-2011, 12:31 PM   #5
fishheadback
Member#: 68120
& MK6 GTI
Not neccesarily. Quite a few of mine take the same sized shim. every motor is different though. Just allows you to make sure everything is within spec. The shimless bucket are the same way.
Old 08-08-2011, 12:43 PM   #6
luka
Member#: 194742
Every time I think I'm ready to build a motor I learn something new like this and it's so discouraging. I want to build one so bad but I can't justify the investment in parts and time and then miss something like this and the entire investment is a waste.
gaaahhhhhh. </whining>
Old 08-08-2011, 05:05 PM   #7
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
If you don't change your cams or valves, you can usually reuse most of your shims/buckets. I only had to buy a couple when I rebuilt my STi engine.
eastcoastbumps is offline   Reply With Quote
Old 08-09-2011, 01:58 AM   #8
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
These are the thicknesses of the spare/obsolete used shims I have...
1x 228
1x 233
1x 234
1x 236
1x 239
1x 243
2x 246
2x 247
2x 250
1x 251
1x 253
I can get the shims size between 1.88-2.08 and between 2.40-2.51 mm new for 20 bucks but I'm not a seller here so I can only help you if you can't get them elsewhere thru official vendors...
Old 08-09-2011, 07:43 AM   #9
fishheadback
Member#: 68120
& MK6 GTI
Thanks for checking for me Marnix.
I emailed Dave @ Rallispec and he said he could get them for me. I might just do that but it could take 4 weeks to get them.
Or I could just take the head off and take it by the machine shop to have the stems ground and use the shims that I already have.
Decisions decisions.......
Old 08-09-2011, 10:13 AM   #10
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
If you have a source for shims I would order shims and leave those stems well alone
Old 08-09-2011, 10:14 AM   #11
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
By the way those EJ20K STI shims are only 1,100 yen each at Japanparts.com, that's not expensive (certainly not 83 bucks).
Old 12-13-2011, 09:05 PM   #12
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
I think you might have been looking at the wrong part
See this link http://japanparts.com/db/partslist.p...x=0&submit.y=0
Part 034-043-13218-1 and 034-043-13218-2 are 1100 but if you look at the picture they are shim OVER bucket
Part 034-043-13218-4 is 6300 yen or 81$ each! Check the picture and you will see its the under bucket type
Old 12-27-2011, 06:59 PM   #13
fishheadback
Member#: 68120
& MK6 GTI
The picture is incorrect on the site just an FYI. I didnt have any trouble getting the correct ones I needed from them.
Old 01-04-2012, 04:43 AM   #14
ciper
Member#: 15543
90BJ Legacy LS ABS
In case anyone cares the Tribeca under bucket intake shims are not the same as these. i ordered one and they are about 7mm and have a lip built in.
The Tribeca exhaust solid bucket/shims are ok though
EJ20K shim under bucket adjustment? suberdave Pre-2002 Factory Turbo Powertrain 3 12-31-2009 01:10 AM
f/s shim under bucket cyl head sense of nature MWSOC Private Classifieds 1 10-07-2007 07:16 PM
Tech Works Shim Under Bucket Question-Where to get replacement shims? MY99 2.5GT Built Motor Discussion 14 04-19-2006 02:33 PM
Shim Under Buckets capkapak Private 'Wanted' Classifieds 1 01-09-2006 04:42 AM
shimless or shim under buckets for wrx heads TexRex2002 Private 'Wanted' Classifieds 0 05-07-2005 11:17 PM
