Old 08-06-2011, 03:33 PM   #1
Ryan314
Member#: 82989
Hybrid EJ257
Default Valves hitting pistons... Now with pics
So after researching and finding out that a timing issue will not cause valves to hit the pistons (valves hit valves with a timing issue, causing bent valves etc. etc.), what DOES cause valves to come in contact with the pistons? Improper lash setting?
Ryan314 is offline   Reply With Quote
Old 08-06-2011, 03:43 PM   #2
Nappula
Member#: 260249
Valves hit valves if timing between two camshafts is incorrect.
Valves hit pistons if timing between camshafts and crankshaft is incorrect.
Correct me if my way of thinking is incorrect.
(Of course there is the possibility if the whole desing in engine components has gone wrong-> piston going too far out to deck + extremely high or advanced valve lift)
Nappula is offline   Reply With Quote
Old 08-08-2011, 04:05 PM   #3
Ryan314
Member#: 82989
Hybrid EJ257
Thank you.
Anyone else?
Old 08-08-2011, 04:09 PM   #4
Crazy_pilot
Member#: 164242
1992 SVX
2008 Spec B
Interference engine means that if the engine is grossly out of timing (ie; timing belt breaks while engine is running) the valves can colide with the pistons. Non-interference (like the EG33) mean that the valves to not have enough travel to strike the pistons regardless of timing.
Crazy_pilot is offline   Reply With Quote
Old 08-08-2011, 05:48 PM   #5
Alaskan EJ20
Member#: 160040
2002 Bugi / 1993 L
Symmetry Tuning
^^ wrong. interference means the intake and exhaust valves run on different cam shafts (DOHC) and if incorrect timing they will interfere with each other or pistons, (SOHC) non interference heads can still have bent valves but only by hitting pistons. hope this helps.
too much AVCS adjustment can cause valves to hit pistons aswell but this is another can of worms.
Alaskan EJ20 is offline   Reply With Quote
Old 08-08-2011, 05:52 PM   #6
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Look at you engine without the timing belt covers on it. it all depends on where you belt slips that determines what makes contact. I for some reason you slip the belt around the crank pulley and all the cam gears stay engaged on the belt during that event you would have a good change of valve to piston contact. If a cam gear slips in relation to the others you can have valve to valve contact.
You can also easily have valve to valve contact when timing the motor if you don't follow the service manual instructions in regards to what direction to turn the camshafts to get them lined up.
Old 08-08-2011, 06:01 PM   #7
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Actually you can have DOHC non-interference engines but they are rare and they would require a huge C.C.
Old 08-08-2011, 06:20 PM   #8
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
These
Old 08-08-2011, 06:52 PM   #9
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
If it is a gross error in timing, it certainly could.
Want to see my pistons...?
CKxx is offline   Reply With Quote
Old 08-11-2011, 04:31 PM   #10
tre mendez johnson
Member#: 19034
2005 saab 9-2x
Does anybody know if there is a way to determine whether or not valves are bent or not, like rotating the cams to see if there is any difficulty.
The reason I ask is that my wife's 05 Legacy GT had the timing belt tensioner go bad (actually the bolt into the block sheared off) and caused her vehicle to stop running.
It got towed home from the dealership and I'll be replacing the timing belt to see if it'll start up. I'm wondering if this is a waste a time if there is an easy way to determine if stuff is bent up.
tre mendez johnson is offline   Reply With Quote
Old 08-11-2011, 04:34 PM   #11
Nathan Explosion
Member#: 215525
2006 WRX Wagon
Start with a leakdown test.
Nathan Explosion is offline   Reply With Quote
Old 08-11-2011, 04:55 PM   #12
scooby24
Member#: 56414
2004 Forester XT 5MT
Matter of fact, he isn't. Interference specifically implies valve and piston non-clearance.
http://mechdb.com/index.php/Interference_engine
non-interference engines will NOT run the risk of valves striking the pistons.
It's a very simple definition. I don't know how you got your misinformation, but don't try to correct someone when you don't know what you're talking about.
scooby24 is offline   Reply With Quote
Old 08-11-2011, 07:39 PM   #13
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
This^. An easier way to look at it is: An event that occurs when the valves and pistons (or if the timing belt snaps the valves on two different camshafts and possibly still the pistons) occupy the same space at the same time. They collide and sometime down the road (if its not taken care of) the head of the valve(s) pop of the stem and tear up the piston (and sometimes other pistons as well), the bore, and the head.
2Fast4U1DAY is offline   Reply With Quote
Old 08-21-2011, 05:17 PM   #14
Ryan314
Member#: 82989
Hybrid EJ257
Please take a look at these pictures and tell me if you think there is anything wrong.
Old 08-21-2011, 05:26 PM   #15
Adams Engines
Member#: 289435
2005 STI 441hp
WRB Dynapack
If you cant physically see they are bent. Assemble the head(no cams) with spark plugs.....have c.c. Facibg up and fill it with liquid......if it leaks out past valves they are bent(large amounts of carbon on valves can cause the same thing however usually will not leak out as fast
Adams Engines is offline   Reply With Quote
Old 08-21-2011, 05:27 PM   #16
2.5ReallySexy
Member#: 167943
^^^^^^ Seems good to me haha
2.5ReallySexy is offline   Reply With Quote
Old 08-21-2011, 05:30 PM   #17
Ryan314
Member#: 82989
Hybrid EJ257
Well the shop is telling me that I had intake valves hitting the pistons. I'm no mechanic, but if these valves were hitting the pistons for 7k miles, wouldn't my valves be damaged? I see no damage to the lip or anything. I have 15 valves with no bends to them what so ever, and one exhaust valve that cleanly snapped off and caused the engine to fail (obviously).
Old 08-21-2011, 05:32 PM   #18
Adams Engines
Member#: 289435
2005 STI 441hp
WRB Dynapack
Usually see contact marks on pistons and edge of valves but really need to look carefully
Old 08-21-2011, 05:50 PM   #19
Ryan314
Member#: 82989
Hybrid EJ257
Here are better pics...
Old 08-22-2011, 09:16 AM   #20
Ryan314
Member#: 82989
Hybrid EJ257
Bump.
Old 08-22-2011, 09:23 AM   #21
SW00P_G
Member#: 5591
EJ257 Gt35r
What are those scratches on the valves? What were the symptoms that caused the motor to be taken apart? Try to roll the valves on a flat sheet of glass to see if they are bent. Or assemble the head and use the liquid method.
And why is there only a pic of 1 piston and valve?
SW00P_G is offline   Reply With Quote
Old 08-22-2011, 10:47 AM   #22
Nappula
Member#: 260249
By looking those pictures id say valve(s) have not been in contact with that piston(s). To be sure you must measure your valves.
You said there is just one damaged valve? If so, id say you had either bad valve or incorrect installation.
Old 08-22-2011, 12:53 PM   #23
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
What kind of pistons are those? They don't look like they have very much valve relief in them especially for oversized valves which I am not sure if you do or don't have.
Put the valve in a drill and spin the drill. If it wobbles at all the valve is bent.
Crystal_Imprezav is offline   Reply With Quote
Old 08-22-2011, 04:17 PM   #24
V8Slayer
Member#: 111565
2007 Legacy Spec.B
324hp/313tq EVOIII 16G
I never would've thought of that, it actually sounds like a great idea!
V8Slayer is offline   Reply With Quote
Old 08-22-2011, 10:22 PM   #25
Ryan314
Member#: 82989
Hybrid EJ257
100mm Mahle 4032.
Here's the summed up version of what happened:
Long story short, I am in a huge battle with my machine shop right now. My hybrid motor snapped an exhaust valve clean off a month ago or so. The motor had 7k miles on it. Excessive driver's side head noise was reported to them when the motor had 2k miles on it. They instructed me to keep driving it. At 7k miles, an exhaust valve snapped off in the driver's side head. Go figure?
Here's where I'm at now. The machine shop is blaming it on a timing issue, yet my mechanic checked the belt and pulleys before pulling the engine and it did not skip timing or seize a pulley. The engine is now torn apart and I have NO bent valves. I have 1 cleanly snapped exhaust valve and 15 perfectly straight non-bent valves. And of course, a destroyed cylinder 2 and piston, and driver's side head.
They are claiming I had intake valves hitting the pistons. They insist to talk about this issue instead of the issue that really caused the failure, which was the snapped valve!
FS : oem engine parts. cams valve springs pistons eh69758 MAIC Private Classifieds 13 08-05-2011 02:41 PM
Rebuilt EJ255 Knocking. Valve? Rod? Piston Slap? Merp Built Motor Discussion 45 12-12-2009 10:45 PM
Setting timing belt, somethings not right... valves are going to hit pistons! enjoi926 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 07-26-2009 01:01 AM
Valve Tick/Piston Slap. Video inside, please help! Disco_Inferno Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 07-07-2009 11:11 PM
Lose timimg belt, valves hit pistons? Y or N rallynutdon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-19-2008 03:31 PM
