North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC
Old 08-07-2011, 05:43 PM   #1
hail2theTheif
Member#: 42548
2015 Base STi
Black (CBS)
Default L ---> RS window switch toubles....ELECTRICAL GURU's please help
I'm having an interesting/confusing problem with my RS Door Card/Switch conversion....
My passenger window (all others work) won't go up. I've swapped the wires around for the down switch and get it to go back up that way which tells me the motor is not fried.
I've even randomly swapped wires around so when I pull up on the switch the window can go down or up, but only one way at a time. When wired up only one way regardless of the direction will work at a time. So the switch itself isn't broken. It has to be some kind of wiring issue.
SO, does anybody have a diagram or photo of a proper wire setup for this?
Or, any idea what might be switched around that would be "blocking" a signal to the switch for functioning both up/down?
hail2theTheif is offline   Reply With Quote
Old 08-07-2011, 06:09 PM   #2
tobigforhisshoes
Member#: 251434
04 WRX
WRB 319/285 bobby tuned!
I'm trying to follow, but have you used a switch from a working window to rule out the switch is not bad?
tobigforhisshoes is offline   Reply With Quote
Old 08-07-2011, 06:31 PM   #3
hail2theTheif
Member#: 42548
2015 Base STi
Black (CBS)
Yes. But also, I've wired the switch to test both up/down functionality and can get it to work both ways but only one way at a time.
IE: When it's wired so that it works going down, the switch will not work going up and vise versa.
Old 08-07-2011, 06:33 PM   #4
bc-roush
Member#: 187384
05 STi WRB
JohnJohn Tuned BEAST!!!
Year and model helps for diagrams... may be able to assist with that. And Good switch?
bc-roush is offline   Reply With Quote
Old 08-07-2011, 06:36 PM   #5
tobigforhisshoes
Member#: 251434
04 WRX
Is it a six pole wiring or four pole wired switch?
Old 08-07-2011, 07:06 PM   #6
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
Remove the drivers seat and check the wiring under the carpet. I have seen several instances of frayed / broken wires that caused windows to stop working.
* Note: This applies only to GC/GM/GF chassis cars.
Old 08-07-2011, 07:15 PM   #7
hail2theTheif
Member#: 42548
2015 Base STi
Black (CBS)
Sorry totally forgot years. It's a 93L impreza wagon ----> 2000 RS Door Card/Switch Swap.
The passenger door switch is a 5 wire single level connector.
The switch appears to be in working condition as I can get it to work one way or the other but just not both up/down at the same time.
It would be awesome if someone even had a photo of a completed conversion or maybe just RS wiring?
I'm guessing there is something messed up in the middle wiring from door to door...but I really don't know.
Old 08-08-2011, 10:23 AM   #8
bc-roush
Member#: 187384
05 STi WRB
Is it sedan or coupe rs?
When I look up diagrams, the 93 wagon and rs sedan are the same.
Old 08-08-2011, 01:18 PM   #9
hail2theTheif
Member#: 42548
2015 Base STi
Black (CBS)
It's an L wagon to RS Sedan.
That's interesting that it would show the same...The wires from the RS switch plugs have a totally different color combination than the L wires.
Old 08-08-2011, 03:28 PM   #10
Teryn It Up
Member#: 225919
2000 2.5rs
Psh... F Kartboy brackets
So, maybe I missed it but the window doesn't go down from both the driver and passenger switches?
If so I would check the continuity of the wire from the switch to the motor for both the driver and passenger control.
Disconnect the connectors at the switch and motor and use an ohm meter to check the resistance. If it is high resistance or OL then you have found the problem.
Teryn It Up is offline   Reply With Quote
Old 08-08-2011, 03:58 PM   #11
bc-roush
Member#: 187384
05 STi WRB
I will check the computer at work and see if its the same there...
Old 08-08-2011, 09:27 PM   #12
hail2theTheif
Member#: 42548
2015 Base STi
Black (CBS)
By doing that, it's basically checking there is a signal going from one end to the other right? Seems easy enough. Feel a bit dumb for not thinking of the obvious haha.
Apparently my Multimeter is busted so I'll be taking a trip to the store for a new one. I will test this out and report back.
Old 08-08-2011, 09:28 PM   #13
hail2theTheif
Member#: 42548
2015 Base STi
Black (CBS)
Awesome. Thanks. At least this way I'll be able to make sure the proper wires are merged together.
Old 08-09-2011, 12:04 AM   #14
bc-roush
Member#: 187384
05 STi WRB
Ok different colors... The one above is the 93 the one below is the rs...
Hope this helps...
Need some help on coilovers guru's please help Jdev08sti Brakes, Steering & Suspension 9 05-20-2011 02:46 PM
Calling all Guru's, please help GboneRS Normally Aspirated Powertrain 10 09-29-2003 12:48 PM
Digtial camcorder guru's please help SjpWrx Off-Topic 5 09-26-2003 08:16 PM
car audio guru's please help! NateDogg Car Audio, Video & Security 5 07-07-2003 06:00 PM
Turbo guru's, please help! dandbest Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-27-2001 10:21 PM
