Old 01-23-2015, 07:15 PM   #1
KManZ
Member#: 220694
2012 STi
Default Help! Rearview Camera Wiring
Before I hack into my stock wiring, I want to ask this. Silly question, but you never know...
I have installed a Pioneer Avic-x9310bt into my non-Nav STi. Trying to get a Rydeen Mini Duo camera to work, but am not having any luck, and I think it's because i may have some wiring incorrect/incomplete.
The camera is powered by the 12v accessory line. It powers on and displays right when I turn the car on, but that's it. Most importantly, it doesn't do anything when I go into reverse.
Look behind the deck, the purple wire for Reverse Signal going into the Pioneer doesn't have anything connected to it. I'm thinking that the head unit needs the reverse signal. So, do I need to run a line from the reverse signal line in the passenger footwell to this purple wire going into the Pioneer HU?
I have read that powering the camera off of the reverse signal wire isn't the best way to go, and that the Avic unit is supposed to sense when you are in reverse. Well, since there is no reverse signal going into the unit from the stock harness, this has to be the answer.
KManZ is offline   Reply With Quote
Old 01-23-2015, 07:28 PM   #2
lookylookitzadam
Member#: 348254
2013 WRX
If I am understanding you correctly, the camera works when you toggle to it in the menus of the unit, but when you shift into reverse, nothing happens. Is that correct?
If so extend the purple wire off the pioneer harness and tap the reverse signal wire in the passenger kick panel. There are tons of write ups for which wire it is. Make sure when you identify it, probe it with a multimeter to verify it gets +12v when you shift.
Sent from my klte using NASIOC mobile app
lookylookitzadam is offline   Reply With Quote
Old 01-23-2015, 07:37 PM   #3
KManZ
Member#: 220694
2012 STi
Thanks for the reassurance, man... There's a lot going on behind the dash, just wanting to make sure before I go tapping the stock wiring.
From what I read, I think it's the brown wire w/ yellow stripe.
Old 01-23-2015, 09:41 PM   #4
hudsonvalleybugeye
Member#: 295068
2001 forester
Sounds right.
I've been out of the mobile electronics game for a little bit, but couldn't you also use the reverse light wire? Is that too old school? I mean, depending on the polarity of the reverse light wire, you may need a 12v relay, but...should be able to signal to the unit.
Good luck!
hudsonvalleybugeye is offline   Reply With Quote
Old 01-25-2015, 04:11 PM   #5
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
xabre1200 is offline   Reply With Quote
Old 01-29-2015, 02:38 AM   #6
smirnon
Member#: 287016
2004 wrx sti 2.0
black
what i did was to connect this "signal" line into my reverse light, not sure if the reverse signal wire in the footwell is easy to locate? But the method i said is whats commonly done here in Singapore
smirnon is offline   Reply With Quote
Old 01-29-2015, 07:02 PM   #7
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
Did you watch the video I posted? The reverse signal wire is on the passenger side and no it does not look hard to locate.
Old 03-21-2015, 08:09 AM   #8
25rsti
Member#: 166324
What about doing this in a GD 02-07?
25rsti is offline   Reply With Quote
Old 03-25-2015, 09:51 AM   #9
KManZ
Member#: 220694
2012 STi
Haven't been back in this thread in a bit, so just wanted to update.
To confirm: the light brown w/ yellow stripe in the passenger footwell is the reverse signal cable.
Just watched it, some good info that I wish I had before I did my install.
Questions:
1) It looks like you ran the wires from the camera through the trunk trim grommet holes. Isn't that the hole the trim attaches to the trunk via the white panel grommets?
2) Did you hook up your parking brake wire?
Old 03-25-2015, 04:02 PM   #10
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
Questions:
Yeah it is but the trunk trim seems to be holding on just fine after all this time without one of those supports attaching it. I think I've had it installed for almost 2 years now and no problems at all. Nope I didn't hook it up to my parking brake wire.
