Old 11-23-2012, 02:23 PM   #26
iambigsteveo
Member#: 311459
2011 5Door WRX
World Rally Blue
Sorry for resurrecting an old thread but I am trying to figure out how to optimize the audio quality running to my aftermarket sub using the factory head unit. I tapped into the speaker wires running the audio signal to the amp which takes speaker inputs. I have amp remote turn on wire connected to the accessory wire behind the head. The sub works and it sounds mediocre, sounding like it's not capturing the lows really well. I am assuming because it's receiving the audio signal from the speakers rather than from the head unit. Could this problem be solved if I were to use the T harness for the OEM sub?
iambigsteveo is offline   Reply With Quote
Old 11-23-2012, 04:17 PM   #27
dsn112
Member#: 332561
2016 WRX LTD
I had the same problem using the speaker inputs on an amp and switched to the audiocontrol LC2i and it is a million times better. I just think the output off the factory head is terrible. The Lc2i corrects the signal for the amp. Makes a huge difference in sound
As far as at the speakers or headunit, it doesn't make a difference, however if your tapping the rears to make it easier, than that is your issue. The fronts are where the factory head sends the bulk of the signal for bass.
Try switching your radio to through mode to see if that changes anything. If it doesn't and you are hooked up to the rears, switch them to the fronts and it will be better. Add the lc 2i and it will be worlds better.
dsn112 is offline   Reply With Quote
Old 11-23-2012, 06:19 PM   #28
iambigsteveo
Member#: 311459
2011 5Door WRX
World Rally Blue
It's interesting you say to use the LC2i because I bought that when I went through the installation of the sub and it didn't work. Perhaps it was because I was tapping into the rear speaker. But at any rate, it wouldn't auto turn on and I spent hours trying to figure out and I just didn't work. Ran the remote turn on wire to the lc2i and it turned on but the sound coming out of the sub was terrible. Took the lc2i out of the mix by running the audio directly to the amp it sounded better but still not much for the lows. I determined the lc2i to be defective and returned it and am living with my system the way it is. Perhaps I may try running the wires to the front speakers if you think that is where the power is primarily being supplied to.
Old 04-29-2013, 11:04 PM   #29
ptak
Member#: 355012
2013 STI sedan
Originally Posted by ngordon28 View Post
Has anyone upgraded the amp on the factory sub-woofer with positive results? I am thinking about usingRockford Fosgate Punch PBR300X1 Car Amplifier - 75 W @ 4 Ohm to power the kicker sub. Any thoughts?
I just don't like the way the factory sub sounds. It's way too muddy. I'm hoping that the Rockford amp controls will help, if not then new sub in the factory same box. This is my wife's car but I regret buying the sub and want to see if I can make the best of it. Didn't expect that I wouldn't be able to control the way the sub sounds.
Did you end up doing this? I have been having the same thought and can't find anything about just upgrading the amp or even adding an active cross over.
ptak is offline   Reply With Quote
Old 05-05-2013, 04:45 AM   #30
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
Just wanted to poke my head in and say that SVXdc is one of the most informative audio guys on this board. He helped me purchase and create my own harness for an unde-rseat subwoofer that I purchased for a 2002 RS way back in the day. His parts are solid. Would be nice SVXdc if you can offer the correct parts to make our own Kicker Sub Harness'.
ejicon is offline   Reply With Quote
Old 05-11-2013, 09:51 PM   #31
ptak
Member#: 355012
2013 STI sedan
Default Amp Upgrade!!!
I decided to venture down a route I hadn't seen any one take yet. Based of what little data about the subwoofer I could actually find I bought the Rockford Fosgate PRB300X1 amplifier. Side note, it almost fits into the stock amplifier location on the backside of the OEM box but not quite. Any way, I severed the wires of the harness on the SUBWOOFER side of the harness (at the connection point of the harness coming from the HU and the subwoofer harness) allowing enough wire length to strip and connect to the highlevel input connection that came with the amp. I used the "power wire" powering the original amp and used that as my 12v turn on wire (remote), ran the 10gauge power wire from the battery (Super easy to hide and run back, I'd say less than 5 minutes), and used the mounting bold of the subwoofer box as the grounding point (no need to drill holes into the metal). As for the speaker wires, I cut those at the mid way point (coming out of the box to the OEM amp) and wired up some 14gauge speaker wire to my new RF amp. If you're curious the black cable is hooked up to the positive terminal of the sub and the grey negative; at least on my kicker it was. After all was hooked up and wired I put in the 30 amp fuse into the power wire, fired up the radio and from what I can notice it's a ridiculous difference over the stock amp. Now reason for doing this; on nice days I like to drive with the windows down and sunroof open. This allows for alot of wind noise and I like my bass (former audiophile but didn't want to break the bank), I found at high volumes (28+ with bass at 4-5, and 30+ with bass at 4) the speakers bottom out causing sound distortion and since the sub input ran off speaker wires (at least as far as I could find) caused the sub to cut out; pissing me off at a relatively good level. So, I weighed my options and having liked the fact that the OEM unit as a whole fit so well and out of the way I didn't want to give up any trunk space. Then I found the PRB300x1. specs fit well, small and easy to install or hide if you desire so I bought it thinking WTH give it a whirl. Got the amp and the recommended 10gauge kit off ebay for 150 and free shipping; not bad. I installed it all and had everything hooked up in 90 minutes or less. I have yet to drive with the windows down but with this extra control at the subwoofer I can leave my bass at 2-3, run high volumes with out the speakers (front) distorting and the subwoofer no longer cuts out. Even having not driven with the windows down yet I'm extremely happy with my purchase and small but significant upgrade. Oh, reason I haven't done my "wind" test yet is its been raining the last few days; I snuck the install in between rain drops...yes that fast (if you know what you're doing). I'll be happy to answer questions and sorry for no pics yet. Like I said I was doing it between rain drops. My personal review of the OEM unit as it is from the dealer, I makes a difference. I did listen to a 2011 wrx non nav sound system and I must say it sucks, no news there so I opted for the oem sub option. It was good but driving with the windows down was disappointing to say the least due to reasons listed above. Currently with it powered by my new RF amp, sounds amazing, mids and low bass are much better and I'll have much better control once I wire in the RF punch EQ remote (another 20 from ebay). I'll take any questions or ideas about my install and review.
Old 05-11-2013, 11:12 PM   #32
XERO287
Member#: 253541
2011 WRX 5DR Premium
So.much.text.so.little.spaces.
XERO287 is offline   Reply With Quote
Old 05-13-2013, 09:49 PM   #33
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
Seriously! As XERO287 hinted, WHITESPACE is a good thing! Many people won't bother reading a huge block of text like that.
Any way, I severed the wires of the harness on the SUBWOOFER side of the harness (at the connection point of the harness coming from the HU and the subwoofer harness) allowing enough wire length to strip and connect to the high level input connection that came with the amp.
I used the "power wire" powering the original amp and used that as my 12v turn on wire (remote), ran the 10 gauge power wire from the battery (Super easy to hide and run back, I'd say less than 5 minutes), and used the mounting bolt of the subwoofer box as the grounding point (no need to drill holes into the metal).
As for the speaker wires, I cut those at the mid way point (coming out of the box to the OEM amp) and wired up some 14 gauge speaker wire to my new RF amp.
Now reason for doing this; on nice days I like to drive with the windows down and sunroof open. This allows for a lot of wind noise and I like my bass (former audiophile but didn't want to break the bank).
Then I found the PRB300x1. specs fit well, small and easy to install or hide if you desire so I bought it thinking WTH give it a whirl. Got the amp and the recommended 10 gauge kit off ebay for 150 and free shipping; not bad. I installed it all and had everything hooked up in 90 minutes or less.
SVXdc is offline   Reply With Quote
Old 05-13-2013, 09:55 PM   #34
SVXdc
Member#: 25837
1996 SVX L AWD
Laguna Blue Pearl
The power wire coming from the factory radio harness (which the Subaru Kicker harness used to power the original amp) is +12V Battery/Constant. The Kicker's original amp has a circuit to detect sound and shut off after a period of silence.
So you really need to change your amp remote turn-on to tap the +12V Accessory (key-switched) power lead. If you'd rather not mess with the original Kicker harness behind the HU, you can tap that power from elsewhere in the car (e.g., fuse panel in driver's footwell) and run the wire back to the subwoofer.
Old 05-22-2013, 11:00 PM   #35
turfburn
Member#: 357226
I had the same issues with the sub in my hatch and was disappointed when I got it. I was able to find some direct plug in harnesses and threw a dual gang 100k potentiometer on those harnesses and I now have a volume control on the sub. Cost about 15 dollars. Put a low pass choke on it as well and that further cleaned up the tone. Just FYI for those searching on how to deal with this!
turfburn is offline   Reply With Quote
Old 05-22-2013, 11:02 PM   #36
turfburn
Member#: 357226
Gravity also makes a 20 dollar line level device that creates a remote amp on signal the same way the stock amp does if you want to give that a go instead. 20 bucks on amazon.
Old 08-08-2013, 10:41 PM   #37
Avaholic
Member#: 364821
2013 XV Crosstrek
Default Poteniometer
turfburn - would you please throw together some install steps to add these 2 items to the OEM sub? I purchased the entire Kicker upgrade kit for my car and I can't even use the darn sub. Really frustrating!
Thanks!
Chris
Avaholic is offline   Reply With Quote
Old 08-08-2013, 10:49 PM   #38
Avaholic
Member#: 364821
2013 XV Crosstrek
Default "dual gang 100k potentiometer and low pass choke?"
turfburn - would you please throw together some install steps to add these 2 items to the OEM sub? I'm sure there'd be MANY people most grateful!
Thanks!
Chris
Old 08-15-2013, 04:41 PM   #39
turfburn
Member#: 357226
Here are the links for the parts and some photos. You will have to move pins around in the harnesses to get it to work, but you can do that with a small pick or screwdriver pretty easily.
Here are links for everything:
https://plus.google.com/photos/10246...KKc2b3aupDWzQE
http://www.radioshack.com/product/in...ductId=2062359
Ebay Choke:
Treble Blocker Low Pass Crossover 160hz 4ohm Sub Woofer (290396059206)
Ebay source of harnesses:
Best Kits Mazda 1990-2001 12/8 Pin Aftermarket Harness (400128801187)
Harness Part numbers:
BHA7901
BHO7901
This also explains how to wire the potentiometer:
http://www.beavishifi.com/articles/Volume_Control/
Old 01-15-2014, 04:00 PM   #40
subwrx2014
Member#: 375396
I know is an old thread, but it helped me out today, so i wanted to simply say thanks for the part numbers and pic's!
subwrx2014 is offline   Reply With Quote
Old 01-24-2014, 10:31 PM   #41
njccmd2002
Member#: 378900
2014 IWSTI
did u get this to work, i cannot make the wires on the bottom side..
njccmd2002 is offline   Reply With Quote
Old 10-18-2014, 06:33 PM   #42
dsak172
Member#: 119684
Hey on that harness (H630SFG130), can it be rigged to hook up any amp beside the factory kicker sub?
Like convert it to RCA L/R somehow? I only see 6 pins on the "connect to sub amp" plug, looks like it's for a mono amp. If hooking up to an amp with stereo L/R RCA, wondering if it can be split.. Forgive me if that's a basic stereoism no-no. I was thinking of getting the kicker sub but I have a 12" and old fosgate amp.
Thanks!
dsak172 is offline   Reply With Quote
Old 11-06-2014, 03:04 PM   #43
turfburn
Member#: 357226
Thanks!
In theory you can get a line level converter (I linked one on Amazon in the older post) and that would work for using with a regular amp.
http://www.amazon.com/BOSS-Audio-B65N-Level-Converter/dp/B000LP4RMQ/ref=sr_1_3?ie=UTF8&qid=1415304326&sr=8-3&keywords=line+level+to+RCAhttp://www.amazon.com/BOSS-Audio-B65N-Level-Converter/dp/B000LP4RMQ/ref=sr_1_3?ie=UTF8&qid=1415304326&sr=8-3&keywords=line+level+to+RCA
Old 01-27-2015, 03:50 PM   #44
Liquid_IQ
Member#: 404084
Originally Posted by NSBcruiser View Post
Update:
Talked with my local Subaru place, they couldn't find a replacement harness for the sub.
So I called Kicker and they do have the harness along with all the replacement parts, but Subaru will not let them sell individual parts from the kit. But Kicker did have the part number that Subaru uses. Called five Subaru dealerships in upstate NY and the cheapest I've found it for was $129.00.
'08-'11 Sedan w/o NAV
Part#: H630SFG130
I got the sub for next to nothing, so I figure $129.00 is a great deal a genuine Subaru accessory that retails for a MSRP of $499.99. Would have liked to make my own harness, but the factory harness has the correct high pass filter in-line, is plug and play, and up to Subaru's quality standards (most likely better than I would have made).
I wasn't ever planning on getting subs for the car, but when a good deal on a factory upgrade part comes along it's hard to say no. Especially since I just installed Subaru's media hub and new poke 6 1/2" component front door speakers and poke 6 1/2" rear door speakers.
I realize this is an old thread but does anyone have the part number for the wiring harness for the sedan - 2008+ with Navigation? The harness looks completely different, with only one small box.
Liquid_IQ is offline   Reply With Quote
Old 03-25-2015, 09:30 PM   #45
BubbaJay
Member#: 416981
Order the factory and reverse factory plug from an aftermarket retailer, build T harness. Seems to be the easiest way to do it, thats what i did.
BubbaJay is offline   Reply With Quote
Factory Subwoofer Help geckoboy86 Car Audio, Video & Security 3 07-17-2011 06:34 PM
Kicker Subwoofer Tube Speaker stewgod SCIC Private Classifieds 10 12-20-2007 10:07 PM
FS: 10 in. Kicker Subwoofer, MTX Amp, and box WRXfirefighter26 NWIC Private Classifieds 2 10-07-2006 01:57 AM
eclipse avn and factory subwoofer HELP lukerussell Car Audio, Video & Security 6 04-02-2006 04:40 PM
kicker subwoofers for sale [DFW] BlkTS02 Texas Impreza Club Forum -- TXIC 5 08-06-2004 08:53 AM
