Old 08-09-2011, 10:54 AM   #1
fenderpicks
Member#: 287694
Default What kind of car ramps does our WRX need...?
So im about to change my entire exhaust system to a turbo back and i saw some threads people talking about using ramps for the rear and then jack stand in the front.
So i was looking up for ramps and apperantly there are regular ramps and low profile ramps.
So i was wonderin if anyone knows what type of ramps we need or recommended
fenderpicks is offline   Reply With Quote
Old 08-09-2011, 10:57 AM   #2
Davenow
Member#: 23676
Whatever ramps your car can drive up on. Normal ramps are fine with non lowered cars without a crazy front lip.
Low profile ramps dont get the car up as high, making them less usefull, so if you dont NEED them, I would skip them.
Davenow is offline   Reply With Quote
Old 08-09-2011, 10:58 AM   #3
2011WRXMT
Member#: 270426
2011 WRX Premium
Satin Pearl White
Jack stands front and rear if you dont have a lift.
2011WRXMT is offline   Reply With Quote
Old 08-09-2011, 11:03 AM   #4
Davenow
Member#: 23676
This.
I always put some sort of secondary support under the car, even if its not tight up against, I dont take chances, I have seen a car come off stands with someone partially under it, and I have seen more than one set of ramps fail with a car on them.
If I am going to put the car on stands, I slide the ramps under the wheels or under the frame somewhere (if the wheels are off)
Old 08-09-2011, 11:06 AM   #5
wrx904
Member#: 97365
Stage III DGM
Originally Posted by Davenow View Post
This.
I agree with this. I also have a 12 ton bottle jack near me when I am under a car.
wrx904 is offline   Reply With Quote
Old 08-09-2011, 11:09 AM   #6
Davenow
Member#: 23676
I am a nervous nelly when I have to lay under the car
If I have one end up, I support it on 2 stands (obviously) and stick my other 2 stands under somewhere. And if the wheels are on, I usually stick at least one ramp under.
If all 4 wheels are off/in the air, I use the 4 jack stands (one each corner obviously) and I leave the jack under the pinch weld semi tight. I also usually stick one of the wheels or the stands under the car as well. If I have a wheel under the center front and center rear, and am working in the middle (shifter or whatever) and the car comes off all the supports, it will land on the wheels. I will damage 2 wheels, but the only thing that will happen to ME, is a ruined pair of underwear.
Old 08-09-2011, 11:11 AM   #7
j4k3
Member#: 262126
O fo WRX
Really blue
Jack stands, wheels under frame.
j4k3 is offline   Reply With Quote
Old 08-09-2011, 11:11 AM   #8
scooby24
Member#: 56414
2003 BMW 330i ZHP
I got rhino ramps from advance auto for 45 bucks I think. My car is lowered and I have no problems by putting a piece of wood at the front of the ramp. The rear doesn't need the wood.
scooby24 is offline   Reply With Quote
Old 08-09-2011, 07:15 PM   #9
Lightnin
Member#: 272630
2011 WRX Sedan
A pressure treated 2x12 and some wood screws
Lightnin is offline   Reply With Quote
Old 08-09-2011, 07:18 PM   #10
424wrx
Member#: 171948
08 wrx prem sedan
vf52 swap. bilstein susp
i have them too. ditto on the wood in the front. they work good though.
Old 08-09-2011, 10:13 PM   #11
leecea
Member#: 37359
2003 WRX
3rd vote for Rhino ramps.
leecea is offline   Reply With Quote
Old 08-09-2011, 10:49 PM   #12
fenderpicks
Member#: 287694
Alright Rhino ramps it is
But 8000 or 13000?
Old 08-09-2011, 10:55 PM   #13
scooby24
Member#: 56414
2003 BMW 330i ZHP
13000, the sturdier ones.
Old 08-10-2011, 12:20 AM   #14
Ozo
Member#: 281992
2006 WRX
Make sure you order it online for in store pickup with coupon code 'A123' for $20 off!
Ozo is offline   Reply With Quote
Old 08-10-2011, 12:38 AM   #15
fenderpicks
Member#: 287694
Okay so i decide to make my own ramp... it will have less of a incline and raise higher
What kind of gas milage does a WRX really get, anyways? DrDRum Off-Topic 50 09-20-2007 05:54 PM
What kind of tranny fluid does the MT WRX use? Night Kid Transmission (AT/MT) & Driveline 8 11-24-2002 02:58 AM
what kind of car does TXIC drive [27] Texas Impreza Club Forum -- TXIC 5 06-20-2002 07:42 PM
What kind of cars does your significant other drive??? Scooby South General Forum Archive 92 07-12-2000 05:41 PM
Message Board Statistics All times are GMT -4. The time now is 08:49 AM.
