Old 08-08-2011, 12:38 PM   #1
TickTack
Member#: 100353
Default TickTack's 500+whp 2006 STI - Built motor, BW 8375, Manley, Treadstone, GrimmSpeed
Spent a few hours on the dyno on Friday and was very happy with the results. The bump in power and torque is great and the increase in drivability and the smoothness of part-throttle driving is fantastic. Much better than my previous road tune. New setup is as follows:
2006 STI - stock motor/turbo - 75k
ACT clutch
3in catless TBE
APS 65mm CAI
Big TMIC
GrimmSpeed xpipe, EWG uppipe
GrimmSpeed ported exhaust manifolds, intake manifold and TGV deletes
GrimmSpeed 3mm phenolic spacers
GrimmSpeed crank pulley
GrimmSpeed 3-port BCS
Turbosmart Hyper-Gate45 Wastegate
DW1100cc sidefeeds
DW300lph pump
Stock temp NGK plugs, gapped to .024
Tuned well and ended up at 326whp/403ftlb @ 24psi on the Dyno Dynamics at DB Performance. Tuner says stock STIs typically put down around 200whp on his dyno.
My plan is for a larger turbo (ATP gt30r?) and a mild build (pistons and rods?) for the winter. Tuner said that the power from all of the port work probably won't be realized until I've got a larger turbo and that this was about all he could get out of the VF39 on my setup.
TickTack is offline   Reply With Quote
Old 08-08-2011, 01:04 PM   #2
rexblake
Member#: 178426
2010 S4
Gray
Those are some killer numbers for a vf39 on that dyno.
rexblake is offline   Reply With Quote
Old 08-08-2011, 01:07 PM   #3
TickTack
Member#: 100353
Yeah, I was happy. The chart doesn't specify, but for what it's worth, I assume this is 'Shootout Mode'.
Old 08-08-2011, 01:49 PM   #4
rexblake
Member#: 178426
2010 S4
Gray
I guessed as much as well. Shane said that is a 1.16 correction factor or so.
Old 08-08-2011, 01:52 PM   #5
TickTack
Member#: 100353
Good info; thanks!
Old 08-08-2011, 08:34 PM   #6
sumfoo1
Member#: 82146
2005 Legacy GT
Try to run it on pump at all ??
sumfoo1 is offline   Reply With Quote
Old 08-08-2011, 09:16 PM   #7
TickTack
Member#: 100353
It was on pump and then I did the port work, phenolics, pump, injectors and EWG. So no, not really.
Old 08-08-2011, 09:21 PM   #8
sumfoo1
Member#: 82146
2005 Legacy GT
I'm just trying to gather more info on the dw side feeds. Debating between Them and 1600cc fic top feed conversion.
See if they run/ idle ok on pump
Old 08-10-2011, 04:07 AM   #9
socalLGT
Member#: 89752
08 STI
I've used the FIC 1680 top feeds on a couple cars and they are amazing. Idle like stock with better than stock consistency on gasoline. The big DW side feeds work well too, especially if you are on E85. If your turbo isn't too big (say a 20G) the DW are definitely the path of least resistance and lower cost. If you are going with 60+lb/min turbo then the FIC1680's are more than worth it.
socalLGT is offline   Reply With Quote
Old 08-10-2011, 08:13 AM   #10
sumfoo1
Member#: 82146
2005 Legacy GT
yeah i'm splitting the difference with the tried and true gt3076 and occasionally running it on e85 (using it as a race gas tune)
Old 08-10-2011, 09:32 AM   #11
2barsti
Member#: 210644
Wow, nice #'s! Hope to see you around in the Blaine area.
2barsti is online now   Reply With Quote
Old 08-11-2011, 11:24 AM   #12
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
Hrmmm how do you display max hp & max tq ?!!
Visconti is offline   Reply With Quote
Old 08-11-2011, 12:04 PM   #13
TickTack
Member#: 100353
Thanks! I'm all over Blaine everyday, haha.
On the dyno plot? That I don't know.
Old 08-11-2011, 01:02 PM   #14
coffeemillionaire
Member#: 287191
2006 STi
World Rally Blue
Great numbers! I'll be having a similar setup. BTW, that's crazy tq! I bet you get put back in your seat quite a bit lol
coffeemillionaire is offline   Reply With Quote
Old 08-16-2011, 10:49 PM   #15
mdefalco25
Member#: 62985
2005 STi
Platnium Silver
So can anybody confirm idle on 93 oct with the DW 1100cc injectors? I will be running e85 as the primary but wanted to know if I would run into issues if and when I switch to 93 to either do it every so often or in a pinch. Any help is appreciated. Thanks!
mdefalco25 is offline   Reply With Quote
Old 08-18-2011, 10:56 AM   #16
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
that poor poor clutch
Old 08-18-2011, 10:58 AM   #17
TickTack
Member#: 100353
Well, it's getting to take a little breather now; I think I cracked the oil pickup yesterday on the way to work. I caught it fast, wasn't beating on the car, just noticed the light flicker at a stop light. Pulled off very slowly, heard a quick couple clicks getting into first then the light went off and it drove fine for about 100ft into a parking lot.
Over-nighted a new pickup and will be digging in tonight. Hopefully I don't have to pony up for my build 4 months before I was planning to.
Old 08-18-2011, 06:00 PM   #18
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Ouch that must of sucked, good thing you got the new oil pick up!
I can vouch for this car as I have seen it in person many times, its pretty damn torquey!
-Will
GrimmSpeed is offline   Reply With Quote
Old 08-22-2011, 11:27 AM   #19
TickTack
Member#: 100353
I think I definitely dodged a bullet last week. Dropped the oil pan over the weekend and found this:
Bolted this one up, resealed the pan, filled her and and started just fine:
Hopefully it lasts until the snow hits the ground!
Old 11-15-2011, 05:07 PM   #20
TickTack
Member#: 100353
Been making progress on getting ready for the winter build/project. Car will be getting a new motor and turbo setup. Still nailing things down, but I've got my turbo. Decided to bring new life to a BW 83-75 TS and see how I like it.
Before:
Torn down, housings blasted:
Compressor housing clear coated:
Turbine housing clear coated and baked (turned an awesome bronze):
Center section was in great shape, so I'll be putting it all back together tomorrow after the hot side is good and cool. Here it is next to a VF39 wheel.
Old 11-16-2011, 05:24 PM   #21
NoGraffix
Member#: 276209
I am Rub
Function>Form
that wheel comparison gave me goose bumps
NoGraffix is offline   Reply With Quote
Old 11-16-2011, 06:13 PM   #22
Nuke209
Member#: 108089
2003 WRX
NF Performance
needs bigger turboz
Nuke209 is offline   Reply With Quote
Old 11-17-2011, 05:04 PM   #23
TickTack
Member#: 100353
Haha, yea, yea, yea. If we all ran 10's, what on earth would you do?
Old 11-17-2011, 05:18 PM   #24
Nuke209
Member#: 108089
2003 WRX
NF Performance
buttwipe
When comparing this turbo (the 83-75) to the 88-75. Spool is nearly identical and much more wider powerband.
I should know, I tuned this turbo here LOL and the 88-75
Old 11-17-2011, 06:31 PM   #25
Schister66
Member#: 271648
2015 STi
Gotta love e85 torque. I wish my STi had that much grunt...
Schister66 is offline   Reply With Quote
FS : 2006 STi OEM stock intake system box silencer filter etc. EfiniRX8 Engine/Power/Exhaust 9 04-25-2011 02:47 AM
FS : (NY): Stock Exterior Parts - 2006 STI - Doors / Sideskirts / Taillights / ETC Mac323 Exterior/Styling 7 12-09-2010 05:48 PM
2006 sti VF39 E85 4400' Elevation medamullet Proven Power Bragging 21 12-28-2009 11:07 AM
NC - 2006 STI - Crystal Gray - ~25k miles ihaveadent Private Vehicle 'For Sale' Classifieds 48 10-18-2007 08:37 PM
NC - 2006 STi - Crystal Grey - ~25k miles - $26900 ihaveadent Private Vehicle 'For Sale' Classifieds 8 05-02-2007 12:54 PM
