Welcome to the North American Subaru Impreza Owners Club Saturday May 23, 2015
Old 07-29-2002, 09:58 PM   #1
mcu81
Member#: 5796
2013 BRZ & 2004
WRX
Default 95L engine swap from 1.8 to 2.2 or 2.5 questions
I have a 95 L 1.8 and the motor is slow, i wanna upgrade to a 2.2 or 2.5. I have heard the 2.2 will run off the original ecu. is this true? and can i drop in a phase 2 2.2 on the stock ecu? thanks all
-mikey
mcu81 is offline   Reply With Quote
Old 07-30-2002, 10:03 AM   #2
mcu81
Member#: 5796
2013 BRZ & 2004
WRX
no 1?
Old 07-30-2002, 10:38 AM   #3
Darby
Member#: 17175
2002 Outback Beaner
2 counts, right?
i'm not sure about the whole ecu thing, but i'd go for the 2.5, 2.0T or STi but you're gonna have to do tranny work as well. I've got a 2.2, it is more powerful than the 1.8 but it does feel like it's lacking sometimes.just my opinion. 2.5's are easier to find aftermarket parts for too.
Darby is offline   Reply With Quote
Old 07-30-2002, 12:13 PM   #4
RaceCarRiot
Member#: 6542
1997 Ver IV
bobjr94's site -- www.fakewrx.com -- has fairly simple directions...it won't work quite as well (might give up a few hp somewhere efficiency-wise) as a FULL (wiring/ecu/headache) swap, but will be much easier, and still run fine.
from my experience, you can run ANYTHING off the 1.8 ECU...not that it will run *well*, but...
RaceCarRiot is offline   Reply With Quote
Old 07-30-2002, 12:46 PM   #5
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Why waste the time? An older legacy or imprezza can be picked up for cheap.
But if you are hell bent on it Id suggest the 2.2l . It seems ever few weeks a new group of people are using the 2.2 engine in some project. For example, many put the 2.2 engine in volkswagon vans for better reliability and sometimes double HP.
Old 07-30-2002, 03:59 PM   #6
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
This makes me wonder... Could the 1.8 run on the WRX ECU? That way I could have a 7000 redline But It would probably have trouble in other areas... Although the WRX is a MAF based car same as the 1.8... Hmmm...
Old 07-30-2002, 04:44 PM   #7
RaceCarRiot
Member#: 6542
1997 Ver IV
nice 2.5L engines go for ~$800...how is a bump of 50 (factory reliable) hp for that kind of money more expensive than buying another car?
Kosta -- hmm...i DO have a '94 WRX ECU laying around...think i should try it?
i'd imagine since the 1.8 has fewer sensors, ones that wouldn't be relaying data to the ECU, it would probably get confused and throw itself into limp mode.
-adam-
Old 07-30-2002, 05:27 PM   #8
mcu81
Member#: 5796
2013 BRZ & 2004
WRX
-adam-
awesome, but where can i find a 2.5 for 800? i been searchin and everybody wants 2 grand.......
Old 07-30-2002, 05:28 PM   #9
mcu81
Member#: 5796
2013 BRZ & 2004
WRX
thanks adam, ill be attempting this as soon as i find a 2.5 for 800 bucks.....well for a grand or under
Old 07-31-2002, 12:33 AM   #10
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
I know of a EJ25 locally I could get for $900, but only locally... And its not through a shop or anything
Old 07-31-2002, 07:29 AM   #11
mcu81
Member#: 5796
2013 BRZ & 2004
WRX
yea, but shipping to philly would b killer! if shipping was less than 350 and its a phase 2 motor, i may b interested
Old 07-31-2002, 10:20 AM   #12
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
in the off rally season i'm swapping full 2.5 running gear, tranny, ecu, wiring harness, engine into the 1.8....
and that's what's needed to make it run properly...
WIRING HARNESS, ENGINE, TRANNY, ECU....
not just slap in the engine and the ecu and call it a day
there's a lot that goes into it.....
none of it is cheap or non time consuming either
Jamie
www.subiegalracing.com
Old 07-31-2002, 05:16 PM   #13
mcu81
Member#: 5796
2013 BRZ & 2004
WRX
Jamie
sent u a pm bought your car and stuff
Old 07-31-2002, 06:10 PM   #14
DoinkMobb
Member#: 3787
2008 Gay
Car
Is the RS tranny absolutely necessary for the swap? There's nothing wrong with mine, closer gear ratios would be nice, but i can live with my longer ratios.
What's the cost of an engine swap? I need to start selling personal belongings.
DoinkMobb is offline   Reply With Quote
Old 07-31-2002, 06:34 PM   #15
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
not absolutely necessary...
but my b/f just swapped an ej20T into his 1.8...
using the stock tranny...
lasted a month... no more tranny...
(granted, it IS a rally car...)
just seems best to $$$ and do it right...
jamie
Old 08-01-2002, 12:02 AM   #16
Wellhung
Member#: 21724
1995 Impreza LX 2.2
Red...ish
Default my little, and I mean little, experience
There's a 1.8 at the end of my road for sell, and I test drove it just to feel the difference between 2.2&1.8, and for the increase of 0-60 in 11.5 seconds to 0-60 in 10, I think it'd be more cost effecient to check around for a RS instead of "tossing" in the 2.2.
Like I say though, I'm not the most experienced.....but I'm working on it.
Wellhung is offline   Reply With Quote
Old 08-01-2002, 12:28 AM   #17
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
And how many miles were on that tranny?
Swapping from an EJ25D to an EJ255 or EJ257... TaurusMcRae007 Normally Aspirated Powertrain 6 06-04-2009 05:20 PM
1.8 to 2.5 engine swap + pp6 pitcrew Subaru Conversions 0 02-16-2008 12:50 AM
swapping from 1.8 to 2.2 question xrturbo Normally Aspirated Powertrain 27 02-18-2006 03:09 AM
Quick questions for those that have swapped from a 1.8 to a 2.5. EcksJay Subaru Conversions 16 05-06-2005 05:47 AM
when going from 1.8 to 2.5 is the throttle plate needed? mines in, not running right mcu81 Subaru Conversions 4 08-03-2004 12:44 AM
