Welcome to the North American Subaru Impreza Owners Club Monday May 25, 2015
Old 08-17-2011, 04:44 PM   #51
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
I'll chime in.
Originally Posted by Crystal_Imprezav View Post
Nope, latest hiccup is this HC is causing me to get spark blowout way easier... Just put a fresh set of plugs in but I got some misfires yesterday so... At this point, I am over the whole high-compression hype. I am pretty sure there is a reason no other shops, tuners, etc have chimed in here... I am going to take it easy on this setup until I have time to swap the pistons out back to 8.5:1 Wiseco's.
We're getting that right now on low compression pistons.
Originally Posted by berdugo View Post
Have you considered upgrading to CDI ignition to fix spark blow out?
Way ahead of you. I'll let you know how it turns out. Or just watch for our race reports.
Originally Posted by Homemade WRX View Post
you'll also notice that no shops cam in and agreed that HC was a waste or that it didn't work
We'll know soon enough. Provided kelford can get me replacement cams soon enough....
Turn in Concepts is online now   Reply With Quote
Old 08-17-2011, 05:31 PM   #52
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
I had spark blowout problems at 8.5:1 at 30psi in 5th gear down the 1/4. Gapping my plugs down to .020 and adding a HKS DLI2 solved those problems (on E85).
Now, I have the blowout problem at 28psi on in 3rd+ gears not just 5th. I spent a lot of time testing and tuning this setup and it just isn't what it should be on paper. I suspect the short rod ratio has a lot to do with it. Would be very interested to see a MPS or Homemadewrx +4mm rod setup at 10:1.
Crystal_Imprezav is offline   Reply With Quote
Old 08-17-2011, 05:34 PM   #53
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
I dare you to finish your car and test it out and/or send me a long rod motor (or parts) and I would be glad to prove you wrong
Old 08-17-2011, 11:23 PM   #54
n2oiroc
Member#: 141952
03 11 wrx/13 brz
i ran 9.5:1 with stock heads/cams in my 07 sti with a 35r and it made as much or more power than most of the low compression setups with cams and headwork.
n2oiroc is offline   Reply With Quote
Old 08-18-2011, 10:50 AM   #55
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
I assume you are talking about ARFab's 9.5:1 setup. If so, I ran it too. It is not really 9.5:1... Run the calcs on it. It is an OTS Arias piston from a RS. The compression height is altered and therefore only calcs out to a 8.5:1 piston not to mention anything thicker than a stock HG made it even lower in CR. That's why it was not much different than a LC setup...
Old 08-18-2011, 11:31 AM   #56
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
GST runs 10:1 and run ethanol, Junior's Fozzy was on Manley '9.8:1' pistons IIRC, etc..anyone know what P&L is running?
Also, long rods behave differently from EJ25 engines, to an extent.
Do however need to hurry up with that wiring. I finally have my garage back for me and my project It's really sad that I've guys running them for years and my own car still isn't running for one reason or another. Oh well, I guess that's part of having customers. I'm not looking forward to wiring in the new EM.
What cams did you guys need? and you never responded to me on the Wills ring stuff.
Old 08-18-2011, 11:38 AM   #57
Turn in Concepts
Member#: 93646
Many Track Records
The cams are a rather interesting story. Gimme a call and I'll tell you about it, but bottom line is my low friction motor project isn't going to happen this year as we needed the parts.
I did reply. I said I suspect I know what you're thinking and I have some heads you can use to lay out and test the tool path if you'd like.
OH! and I have some other ideas for you if you want to chat about them.
Old 08-18-2011, 11:53 AM   #58
Homemade WRX
Member#: 33782
96 bastard child
yeah, I'll give you a call this afternoon...I somehow didn't get your reply or maybe I'm reading messages in my sleep now
Old 08-18-2011, 02:47 PM   #59
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
IIRC P&L is running stock compression
juanmedina is online now   Reply With Quote
Old 08-18-2011, 02:59 PM   #60
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
GST is running 9:1 the last time I heard.
Junior had those '9.8:1's" in his car and if it was actually doing him any good, we probably would have seen something about it. He would/should have went faster on the stock turbo than he did before but the last update I saw on that car was it went rotated, and now he is selling/trading it to Paul@P&L.
Old 08-18-2011, 03:34 PM   #61
Homemade WRX
Member#: 33782
96 bastard child
He would/should have went faster on the stock turbo than he did before .
care to clarify?
I know GST also has a couple of different engines that they use, so they may have a 9.0:1 for a certain race and 10:1 for another.
Transient response is something I'm assuming you don't care about for drag racing...?...may be part of their strategy in using higher CR for say, tight courses
Once again, I'll note that I don't care about EJ257 engines nor do I 'study' them. It's a good auto-x engine and is a design compromised for emissions as far as I see it. I'm just here to help spout ideas that may or may not be of use. Closest I get to them is sticking a +2 rod and lighter pistons into them
I agree that fundementally a big bore and short dwell with high compression do not work together. MBT timing window becomes very small...even smaller with more pressure. So hitting the target becomes the challenge. Theoretically it can make more power but here in the real world, I think you're finding the limitations of equipment, largely the ignition system.
There's a good SAE paper written up about the boosted Honda F1 engine and they address some of the fundemental issues that I just touched on. It's also just a fun engine to read about
IMO a dragrace EJ25 should get 'lower compression' and more boost.
Old 08-18-2011, 04:08 PM   #62
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
Yessss, I got Micah to semi-agree with me . What do you suggest I try next then, I am getting a little bit of a kick out of this. EG33??
Also, I agree for transient response and for a little bit of added off boost power, yes by all means upping the compression will help. However, so will a smaller turbo or hotside
Old 08-18-2011, 05:15 PM   #63
Homemade WRX
Member#: 33782
96 bastard child
Did you ever answer if the cams were degreed correctly?
I'd like to see you put the cossies back on this setup and see the difference. A simple test with 1 variable.
Con's to using smaller hotside or turbo for the application is the loss of top end power...but I guess that's have to be weighed out with potential power loss from ignition/EM control at RPM.
If the cossies are still having issues, you'll have a better idea of what's going wrong. From there I'd really look into ignition.
EG33's are big/heavy girls but they are bigger and don't mind RPM
Old 08-18-2011, 05:58 PM   #64
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
The cosworth Cams are currently in my buddies car. Really if I'm going to pull the motor out, I would rather just swap the pistons out... If the power comes back then I know it's the hc anyways.
Yes cams were degreed properly.
For me the hc did the same thing as a small hot side. Better transient response and off boost power but lost topend...
Old 08-18-2011, 06:53 PM   #65
Turn in Concepts
Member#: 93646
Many Track Records
Sorry I sounded so distracted on the phone this afternoon. Too much going on, and Tony is out for a long weekend.
As to the thread - we have two different hot sides we run for the turbo depending upon the track. We also adjust redline. Lower for the small one,and higher for the big one. No need to spin the small one all the way out if it doesn't make power there.
Old 08-19-2011, 05:10 PM   #66
Homemade WRX
Member#: 33782
96 bastard child
Not a problem, you sounded busy. I was bored as I just kicked off an hour long test and was caught up no data.
You could still have the ignition short comings be a problem with Cossie cams and be down on power. So....
Old 08-22-2011, 05:56 PM   #67
SW00P_G
Member#: 5591
EJ257 Gt35r
┐HUH?
SW00P_G is offline   Reply With Quote
Old 08-22-2011, 07:18 PM   #68
Homemade WRX
Member#: 33782
96 bastard child
Originally Posted by SW00P_G View Post
┐HUH?
If he were to install the cossie cams and still be down on power, we still don't know if the ignition system is the weakness...thus we haven't learned the actual issue he is having.
Old 08-22-2011, 08:42 PM   #69
02h20
Member#: 130079
2006 STI 9.7@148
CleoTuned@PrecisionTuning
We made 741 on manley HC pistons (9.8:1) stock ports and stock valves with BC280 cams. We made 691 on LC pistons with fully ported heads bigger valves and more bigger cams with the same turbo. 691 was on c16 741 was on e85. Also around the same boost level. The manley pistons work from what I have seen. What exhaust housing are you using on your turbo?
02h20 is offline   Reply With Quote
Old 08-22-2011, 10:01 PM   #70
DJIMPREZA
Member#: 1199
1994 Supra+1K, 22b
alike, 07STI
Hi Jeff, we cosworth released their 9.2 engines, we bought a lot of them, maybe 5 at once, then we went up on another one with 9.5 to 1 cr, after a while we all end up again to 8.5 being the most street/drag friendly. From my recalls I could see how high egts were climbing on hc motors inducing a lot of exhaust manifold pressure (pressure ratio quite higher from low comp) it might be inducing exhaust gas reversing and/or limiting final flow... I am following your results, keep it, DJ
DJIMPREZA is offline   Reply With Quote
Old 08-22-2011, 10:48 PM   #71
juanmedina
Member#: 133146
07 FPgreen 7.37@95
The only way to test that high compression really works is a back to back test with the same mods. As of right now it seems 50/50.
Old 08-22-2011, 11:02 PM   #72
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
Just because high compression isn't working for one person in this particular thread and supposedly a couple others doesn't mean it doesn't work.
Just means they haven't figured out what isn't working right with it.
project_skyline is offline   Reply With Quote
Old 08-22-2011, 11:34 PM   #73
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
mikey will show you guys how its done.
maxpowr is offline   Reply With Quote
Old 08-23-2011, 12:01 AM   #74
Homemade WRX
Member#: 33782
96 bastard child
and then it still doesn't say weather it works or not. It may simply require large primaries or AR on the turbine.
In an engine, NOTHING is cut and dry. Everything is connected.
Old 08-23-2011, 12:57 AM   #75
juanmedina
Member#: 133146
07 FPgreen 7.37@95
or maybe It just simply means that it doesn't work
care to clarify?
If it works the promoters of this high compression engine should device a test that show that it works... Obviously I hope it work who doesn't want better response and more power.
The only impressive high compression setup that I have seen is Md05Sti's, other than that one there is nothing. And that car hasn't even run a good pass thanks to the tranny .
High compression e85 big bore questions 5lipstream Built Motor Discussion 4 07-02-2011 09:39 PM
Wtb sti window spoiler and a big turbo neversummer489 NWIC Private Classifieds 10 03-04-2010 09:52 PM
FS: NC My 2001 RS w/ High compression motor, and other parts Whiteghost 2.5 Private Vehicle 'For Sale' Classifieds 23 10-17-2009 09:16 PM
Big boost, big cams, high compression? Drink Built Motor Discussion 18 03-13-2007 06:02 PM
