Old 08-09-2011, 10:52 AM   #1
jdmwrx94
Member#: 211619
94 jdm wrx
red
Default Broken release bearing
Clutch would'nt work, I cheked and found out my release bearing is broken. One of the "ears" is broken. It unclipped from the pressure plate, I know for sure it has to be replaced, but I wonder if I should replace the full clutch "it's two years old" oem exedy ksb03. It would'nt slip and was in good working condition. I could'nt reclip the release bearing on the pressure plate. Could it be something broken on the pressure plate where it clips, not sure... I will take the engine out in a couple week ends, when I have some time. Any inputs on what could prevent the release bearing to clip in?
jdmwrx94 is offline   Reply With Quote
Old 08-10-2011, 05:21 PM   #2
wrxstijdm
Member#: 254590
1998 V4 Impreza STI
EJ20K engine
If you´re dropping your gearbox, I would replace the clutch... Exedy KSB03 (OEM replacement) clutch kit is not that expensive and it might be worth it to replace the clutch kit and resurface the flywheel...
wrxstijdm is offline   Reply With Quote
Old 08-10-2011, 06:14 PM   #3
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
In there do it, otherwise kick yourself in the ass when it goes out ..
sense of nature is offline   Reply With Quote
Old 08-10-2011, 06:26 PM   #4
ortiz_02
Member#: 277031
02 bugeye
my release bearing went bad on me too, two weeks ago... i suggest you replace the clutch too, its not expensive, i spent 300 dollars all together including the flywheel resurface, and liquids.
ortiz_02 is offline   Reply With Quote
Old 08-11-2011, 08:40 PM   #5
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
try grabbing the fork and jamming it a few times backwards so that it pushes against the pressure plate. sometimes that can get it to clip back in (unless it is indeed broken as you say)
elislider is offline   Reply With Quote
Old 09-07-2011, 07:52 PM   #6
jdmwrx94
Member#: 211619
94 jdm wrx
red
the ring clip that locks the release bearing in the pressure plate is broken too... think i'll need another clutch kit, and clutch disc is indeed wirn out, i'm not sure how much left it has, but the grooves in the disc, are almost flush to the disc 1/16 and 1/32. Can't remember how it was when new...
EJ20G Release Bearing and Input Bearing Information dr3w Pre-2002 Factory Turbo Powertrain 14 06-07-2010 07:56 PM
Wrx throwout bearing, release bearing apgarabu Drivetrain 0 01-18-2010 10:26 AM
02-05 wrx throw out bearing release bearing quadtard Private 'Wanted' Classifieds 2 11-03-2009 12:23 AM
Release bearing, throw out bearing question benyl Transmission (AT/MT) & Driveline 2 09-21-2006 12:26 PM
sticky release bearing? MixeD_MenacE Normally Aspirated Powertrain 1 12-07-2000 12:52 AM
