Old 08-09-2011, 11:21 PM   #1
Bookem74
Member#: 174481
98 Legacy GT-T
Default Wiring halp please
Car: 98 USDM 5mt Legacy
Engine swap : jdm 96 ej20g from 5mt wrx sedan
Trans swap : 00 rs 5mt (swapped speed sensor but left rs nuetral safety and reverse switch as they both tested good and plug into stock harness)
I'm putting my car back together after being apart for three months and have one plug I just can't figure where it goes, it looks like an oxygen sensor extension harness but I still have the stock headers with the front sensor plugged in and rear sensor has a two wire plug completely different. I have read over fsm diagrams over and over. Now it's possible it is a factory wire to this car but most you guys in the pre '02 forums would be familiar with this than any other forum I'm guessing. I was able to decipgher the old tag down to part # 24039AA051, which I googled,
Click to View Search Results for subaru part 24039AA052 - Google Search subaru part 24039AA052 - Google Search
the only site that shows it is parts planet, which isn't responding my browser says.
So I searched a few subie online parts, ez subaru parts says it's a "sensor harness" and supercedes to part # 24039AA052.
http://www.ezsubaruparts.com/partloc...&siteid=215899
Googled that, same story
Engine swap was done three and a half years ago with zero issues, was swapping trans now and pulled engine to do gaskets, spark plugs and '02+ coils. I did plug everything and hook up enough to start up the engine and drive around the block. No cel, just brake and abs light on dash. So I pulled it back in my garage to dig some more.
Coming from firewall bulk harness is four wires : yellow/red strip, white/black stripe, grey/blue stripe and black (black and grey/blue stripe combine about six inches away from firewall in a grey covering going into the firewall). These combine to a four pin white plug. In the pic it is the wire between the turbo and tmic bracket.
Connecting to that wire is a three foot jumper harness with another four pin white plug. Those colors are : yellow/red stripe, white/black stripe, light blue/ white stripe and blue. Other end of the jumper is again a white plug but now a three pin, the blu/white stripe combines to the blue wire with a grey covering again just like close to the firewall. So where does this other end plug into? Here's what it looks like away from the car.
Now the way the harness is so loosely fitted at the moment it could plug in just about anywhere on the front half of the car, grrrr, I'm stumped.
Bookem74 is offline   Reply With Quote
Old 08-10-2011, 08:18 AM   #2
pmugabi
Member#: 280926
Oddly enough it looks like the 02 sensor harness on a 97/98 car, the one for the EJ20G should be gray.
My guess is that the car was supplied with the EJ20K style O2 harness and an extension harness so that the (short harness) EJ20K O2 sensor could actually be plugged into the EJ20G headers since the EJ20K O2 sensor is originally meant to be installed near the turbo.
Hope the sentence above makes sense.
pmugabi is offline   Reply With Quote
Old 08-10-2011, 01:43 PM   #3
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
That's for the rear 02 sensor on the 2.5RS. Not needed for the swap.
Old 08-11-2011, 07:39 PM   #4
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
that part number you gave is shown here, its an extension for the rear O2 sensor and as Matt said its not needed for the swap. the JDM EJ20G should have all the sensors within arms reach of the engine bay (aka, in the up-pipe or top of the downpipe)
http://opposedforces.com/parts/legac...llustration_1/
elislider is offline   Reply With Quote
Halp please, it's a matter of life and death! shakedotazz Off-Topic 11 07-08-2010 04:36 PM
Bugeye mesh foglight cover hardware?! halp please MrMakesitRain Newbies & FAQs 2 08-14-2009 08:54 AM
Computer Halp Please :( MikeCee Off-Topic 39 04-26-2009 12:22 AM
Local schaumburg and area people, HALP please. OvrClkdPmp Mid West Subaru Owners Club Forum -- MWSOC 10 09-30-2008 08:37 PM
Willing to Paypal for Someone To Record 60 Mins. This Sunday- Halp Please? -auSTIn- Off-Topic 12 02-25-2008 09:31 PM
