Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Complete Car Part-Out
Closed Thread
Old 08-12-2011, 01:40 PM   #1
NXTLVL
Member Sales Rating: (4)
Member#: 184759
01 07 TBSS/E36 M3
Default Rsti Part Out!*6 Speed*twin Plate*fmic*fp Red, Etc...
Everything down the middle must go! There are several items not listed (New STI short block, pistons,etc) that are not listed yet. These will be updated as parts comoff car, or back in hand... Here the list....
6 speed JDM Spec C none DCCD tranny swap (tranny,axles, drive shaft, rear diff,tranny mounts, shifter w/ linkage, pitch mount rod) $3,300 *SOLD
Exedy Twin plate clutch assembly $800 *SOLD
Heavily worked 2L heads: 1mm oversized intake and exhaust stainless valves, Brian Crowler Titanium springs & retainers, 5angle intake, 3 angle exhaust port work, gasket matched intake porting (with cut blades, gasket matched port exhaust, and 280 cams $1500obo
Whiteline rear diff bushing kit *NEW! Never installed $70
KS Tech 73mm Intake (turbo side) $75
Ported/gasket matched WRX intake manifold, Ported/deleted TGV's w/ WRX throttle body $250 *SOLD
STI Carbon reinforced timing belt $100
FP Red turbo,3" inlet, 7cm exhaust housing
* Will be back from getting freshly rebuilt next week! $750
Turbo XS 4” down pipe $200
STI turbo coolant tank $25
STI radiator $100 obo
Radiator fans $65
A/C compressor $100 *pending sell
A/C compressor mount w/ tentioner pulley $50 *pending sell
HKS BOV w/ adapter kit $100 *SOLD
Starter $50
Auto meter oil pressure gauge w/ sending unit(electric) $40
P/S pump $75 *SOLD
P/S fluid resevor $25
NXTLVL is offline
Old 08-12-2011, 01:45 PM   #2
NXTLVL
Member#: 184759
01 07 TBSS/E36 M3
NXTLVL is offline
Old 08-12-2011, 01:48 PM   #3
NXTLVL
Member#: 184759
01 07 TBSS/E36 M3
Dang, that was fast! PM's responded. List updated...
NXTLVL is offline
Old 08-12-2011, 02:10 PM   #4
crashtke
Member Sales Rating: (8)
Member#: 120912
The 6 speed is a great transmission. I drove it personally and it shifted perfect. Pair it with the twin disk and it really is an awesome combo! The clutch is normally a $2000+ clutch. Bump for a great deal!
crashtke is offline
Old 08-12-2011, 06:52 PM   #5
NXTLVL
Member#: 184759
01 07 TBSS/E36 M3
PM's responded.List updated
NXTLVL is offline
Old 08-13-2011, 10:14 AM   #6
crashtke
Member#: 120912
I just wish I had the cash for the 6 speed and clutch! My build might go a totally different direction, lol.
crashtke is offline
Old 08-13-2011, 10:18 AM   #7
NXTLVL
Member#: 184759
01 07 TBSS/E36 M3
That would be an interesting swap for your setup.
NXTLVL is offline
Old 08-13-2011, 12:27 PM   #8
NXTLVL
Member#: 184759
01 07 TBSS/E36 M3
pm's responded. List adjusted
NXTLVL is offline
Old 08-13-2011, 10:48 PM   #9
Quadsbc
Member Sales Rating: (36)
Member#: 170415
2002 Hardware store
bumper clips, that is all
Please take some pics of the heads. Miles on them? who did the work? stock 2.0 dish or 2.5l matched?
Quadsbc is offline
Old 08-13-2011, 10:56 PM   #10
WagonMafioso
Member#: 222641
how many miles on the tranny? V7 or V8, does it use 5 x 100 hubs or 5 x 114.5?
WagonMafioso is offline
Old 08-13-2011, 11:01 PM   #11
NXTLVL
Member#: 184759
01 07 TBSS/E36 M3
I can get you better pictures, but these are of just after the heads were pulled and found a broken sleeve in cylinder 4. So, sorry, they haven't been cleaned at this time.
Current miles were 1,7XX mile as of time from built to installed to bottom end issue. Heads are fine thou. Work was peformed by Chastain Motor works in Jonesboro, GA. Super tech'y questions, you may want to ask b reel on WRXAtlanta. He current has the heads with him at Chastain. Here is the link to heads. (You will find that my call name there is Sanders, you will see my name refference in the thread.)
http://wrxatlanta.com/forums/showthread.php?t=31361
NXTLVL is offline
Old 08-13-2011, 11:01 PM   #12
crashtke
Member#: 120912
Having seen the transmission, it uses 5x100 hubs. I am not sure how many miles though.
crashtke is offline
Old 08-13-2011, 11:06 PM   #13
NXTLVL
Member#: 184759
01 07 TBSS/E36 M3
I believe it's a V7. Here is the code off the casing: EA-TY856WB2GA.
It is the 5X100 R160 setup.
I believe that the person I got it from when I bought the car said it had around 69K kilometers on it then. I may have driven it 2-3K miles since I had the car.
NXTLVL is offline
Old 08-15-2011, 12:17 AM   #14
NXTLVL
Member#: 184759
01 07 TBSS/E36 M3
ttttttttttttt
NXTLVL is offline
Old 08-15-2011, 09:31 PM   #15
r8ram
Member Sales Rating: (9)
Member#: 135169
2004 STi WRB
2000 VSM EK9
Pm sent
r8ram is offline
Old 08-16-2011, 02:02 AM   #16
Gluis
Member#: 245584
07 Impreza WRX STI
Do those head work on a 07 STI block? Will they have the same CR?
Regards,
GS
Gluis is offline
Old 08-16-2011, 10:38 AM   #17
NXTLVL
Member#: 184759
01 07 TBSS/E36 M3
Regards,
GS
I don't see why not. I had a brand new STI short block with CP's in my car with these heads. The CR in theory would be higher, but the chambers have been cleaned up/ opened up, so it's maybe a point off from stock. I do not have the exact CR for stock STI pistons setup.
NXTLVL is offline
Old 08-16-2011, 08:35 PM   #18
NXTLVL
Member#: 184759
01 07 TBSS/E36 M3
Listing and pricing updated
NXTLVL is offline
Old 08-18-2011, 09:22 PM   #19
NXTLVL
Member#: 184759
01 07 TBSS/E36 M3
Ttttttt
NXTLVL is offline
Old 08-19-2011, 11:21 PM   #20
NXTLVL
Member#: 184759
01 07 TBSS/E36 M3
ttttt
NXTLVL is offline
Old 08-19-2011, 11:53 PM   #21
abrumlev
Member Sales Rating: (6)
Member#: 197920
2005 Legacy GT
ABP
Do you still have that turbo inlet?
abrumlev is offline
Old 08-20-2011, 11:25 AM   #22
NXTLVL
Member#: 184759
01 07 TBSS/E36 M3
Yes I do!
NXTLVL is offline
Old 08-20-2011, 11:28 AM   #23
wrath1517
Member Sales Rating: (85)
Member#: 193723
2002 RS STI HYBRID
Legit parts!!!!
wrath1517 is offline
Old 08-20-2011, 12:09 PM   #24
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Since you are not actually parting out a complete vehicle, you must use the other sub-forums to post your parts.
Mulder is offline
Closed Thread
fs (ma) 98 rsti part out subajay Complete Car Part-Out 139 02-05-2012 10:58 PM
FS MA: 98 rsti part out subajay NESIC Private Classifieds 93 03-14-2010 01:37 PM
fs rsti part out subajay Tri-State Area Private Classifieds 6 02-02-2010 09:54 AM
2000 Rsti Part Out NXTLVL Complete Car Part-Out 59 12-16-2009 08:54 AM
