Old 08-15-2011, 09:33 PM   #26
jockeygolfs
Member#: 260868
2011 STI
August 12':
Wrapped headers
August 12':
-4AN Fittings for Meth Injection
Quick Disconnect, No Drip
Intercooler Section
Pump Section
Trunk Section
Fast Acting Valve Section
It all went in pretty straight forward. I had a small issue with the quick disconnect leaking but it was actually my fault for thinking everything was tightened from the vendor. I tightened all the connections down one more time and leaks seem to be gone. Now time to retune to make sure nothing is weird. I think with the larger lines I may be flowing a bit more than before.
Thanks to WRX02FTW for his assistance in the install. I don't think our hands will fall off after we touched so much methanol. I had to blow out the line from the trunk to the engine bay, my lips have not burned off yet.
September 12':
Installed DW300 tonight. Bought the DW65 install kit for the sock fuel filter since the DW300 comes with the universal filter. Installed in about 30 minutes.
October 12':
FiveO 1200 injectors
Kstech Air Pump Block Off Plates
The passenger side air pump block off plate was a PITA. We aborted this due to the entire uppipe needing to be removed for this job. On top of that, the entire turbo would have to be removed because one of the bolts holding the uppipe to the turbo was blocked off by a hard oil line. I will do this air pump delete when I swap the turbo sometime in the future.
jockeygolfs is offline   Reply With Quote
Old 08-15-2011, 09:36 PM   #27
jockeygolfs
Member#: 260868
2011 STI
October 12'
Installed my turbo oil line. The one on the turbo looked shot. It did not have the 90* elbow on it and might have been stressed out. Put the hose from Blouch on. It was a bit long but I tried to arrange it to avoid as much stress on the terminal ends where these hoses tend to leak.
I had to remove the AOS in order to get to the oil line. That caused a slight leak in my radiator line and I had to replace that. I took this time to trim up the AOS lines and remove my meth lines to the intercooler and plug it up.
I did a little mock up of my lines for the intercooler sprayer and it looks like it should all line up nicely.
Intercooler sprayer bar installed
November 12'
No pictures but we hardwired the fuel pump with the Deatschwerks kit.
Full Blown Double Pump Hanger
I'll be rewiring this thing to clean it up.
Debadged
Grimmspeed Uppipe w/ Tial 38mm MVS Wastegate
We also removed the air pump and all associated hard tubing etc.
March 13':
Aeromotive FPR, Walbro 400 E85 Fuel Pump, Rails and SS Lines
Here is the FMIC mounted with Tial Q 50mm BOV, Omni 4 Bar Sensor, AEM IAT Sensor
DCCDPro FuelPro Fuel Pump Controller installed June 13':
Old 08-15-2011, 09:51 PM   #28
Hiroshima
Member#: 287871
Originally Posted by jockeygolfs
Might be a while. Everytime I think I'm close to being done I just want to do a little more. Now I'm thinking GSC valve springs and retainers and possibly a Dom 4XT-R. So with this addition it means a bigger CAI. IT NEVER ENDS!!!
And whose fault is that haha
Hiroshima is offline   Reply With Quote
Old 08-15-2011, 09:52 PM   #29
jockeygolfs
Member#: 260868
2011 STI
June 13':
ETS Rotated Kit prior to shipping. ETS left out two pipes for the hot side connection to the FMIC. The package arrived on Friday. I found out there was a problem as we were installing the kit that afternoon. Thank goodness ETS is 3 hrs behind since they are in Washington and I'm in Florida. The pipes, couplers and t-bolt clamps were shipped next day and arrived by noon on Saturday to complete the install.
PTE 6466 Ball Bearing Turbo. This thing is big!!
Installed Rotated Kit
Header Welds
Exedy Triple Disk Clutch
Old 08-15-2011, 09:58 PM   #30
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
Hell no!! But then again I would not call myself a mechanic either. I would think it isn't horrible if you have enough people to help. $100 is what TAV charges I believe. Plus he does it in less than an hour I bet.
Gracias Senor.
smeerone is offline   Reply With Quote
Old 08-15-2011, 10:02 PM   #31
jockeygolfs
Member#: 260868
2011 STI
July 13':
Preparing to do some preventative measures from steering line fires.
Braided SS power steer line installed.
The braided line came with the wrong fitting to the power steering pump. The shop machined down the fitting that it came with and put M14x1.5 threads on it and it was good to go. Techna Fit did ship the correct fitting the next day but the one I am using is holding up. The 90* fitting at the pump made it difficult to try to hide the hose under the intake manifold. So it had to go up and over the intake manifold. One day I may just make an extension and route the line around the block much like the OEM power steering line. Eitherway it is well protected with the fire sleeve and being away from the exhaust.
Turbo blanket, up pipe and down pipe heat wrapped.
Turbo blanket is great. The bulk head wire harness is between the turbo and strut. There is very little worry about it being melted to a crisp now. I can easily place my hand on the turbo even after a spirited drive.
August 13'
COBB AP V3
Old 08-15-2011, 10:26 PM   #32
spec b 002
Member#: 217716
2010 STI se
Great build man!
spec b 002 is offline   Reply With Quote
Old 08-15-2011, 10:43 PM   #33
krisobe
Member#: 267041
2011 WRX 5dr
I'm jelly.
krisobe is offline   Reply With Quote
Old 08-15-2011, 10:48 PM   #34
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
I wish I lived down near all of you. I would be more than willing to help out so I could learn how to do these things.
Ill be holding another install event soon. I'll let u know in advance.
Old 08-15-2011, 11:12 PM   #35
kevosnowsti
Member#: 202097
2001 Subaru 2.5rs
BRP
WOW, you move a little quick with mods. How do you like the Dom 2.5 XTR? I've been thinking about this turbo over the 20g.
kevosnowsti is offline   Reply With Quote
Old 08-16-2011, 06:01 AM   #36
jockeygolfs
Member#: 260868
2011 STI
March 14': Radium Engineering Walbro 400 E85 Fuel Surge Tank
Old 08-16-2011, 06:09 AM   #37
TGUN11
Member#: 287255
2011 WRX Limited LRP
Tuned by MotionLab
nice man!
You must be a time traveler to purchase and mod the car that much and you purchased it next month....
j/k man.. great build and amazing ride
TGUN11 is offline   Reply With Quote
Old 08-16-2011, 06:53 AM   #38
jockeygolfs
Member#: 260868
2011 STI
May 14': Complete surge tank install by removing hard line feed and return with -8 PTFE lines
Digital Wave lending a hand with his soldering expertise.
Old 08-16-2011, 02:14 PM   #39
jockeygolfs
Member#: 260868
2011 STI
Tuned 5/16/14:
Old 08-16-2011, 03:47 PM   #40
LEGITWRX
Member#: 255816
2006 Subaru WRX WRB
omgwtfbbq
Very excellent build... Lots of awesome components
LEGITWRX is offline   Reply With Quote
Old 08-16-2011, 03:56 PM   #41
jockeygolfs
Member#: 260868
2011 STI
May 24, 20014: So let's try to make this power band stretch a little to the left!!!!! Precision Turbo 6262 Ball Bearing .64 A/R
Retuned!!!
Old 08-16-2011, 08:38 PM   #42
kevosnowsti
Member#: 202097
2001 Subaru 2.5rs
BRP
Originally Posted by jockeygolfs View Post
Wait a little longer and I will have mine for sale lol!!! How about $1200!
I do like it though. The spool is real quick when I step on it while cruising at about 3000-3500 rpm. I am looking to switch just to get more power out of my setup.
Not bad. When you are ready to sell it, post up on here! Or if you remember, shoot me a message and I just may be interested. :thumbs up:
Old 08-16-2011, 09:09 PM   #43
jockeygolfs
Member#: 260868
2011 STI
June 14' Advan RZ 18"x10" +35 and Nitto NT555:
Old 08-16-2011, 11:47 PM   #44
RoninSTI
Member#: 49278
11 STI
good lord!
RoninSTI is offline   Reply With Quote
Old 08-17-2011, 04:56 AM   #45
brickak14
Member#: 262957
2005 Audi S4
Originally Posted by RoninSTI
good lord!
Agreed...
brickak14 is offline   Reply With Quote
Old 08-17-2011, 07:42 AM   #46
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
This was long overdue.
Good job!
xluben is offline   Reply With Quote
Old 08-17-2011, 08:43 AM   #47
jockeygolfs
Member#: 260868
2011 STI
Test Fitting the Wheels July 14':
Project Kics R40 Lugs
Super Pro Front Roll Center Kit
Wheels
Waiting on suspension to finalize the fit. I'm not driving around with these wheels the way that they are.
Old 08-17-2011, 09:17 AM   #48
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Yeah, I saved 4 or 5 posts in my thread, but now they're all filled up!
Old 08-25-2011, 04:32 PM   #49
jockeygolfs
Member#: 260868
2011 STI
Time has come! Engine is dead. Even on a conservative map. i was running at 21.5 PSI max. My mechanic says 19 is the max on OEM pistons. Currently waiting to be towed. I'm in the middle of nowhere. Just south of the city of Okeechobee in FL. Car was sounding awesome and then sputtering. The car was making weird sounds like playing cards in bike spokes.
So I pulled off the road and called Gustavo at TAV racing. He told me to check the oil. It is all gone. The oil light would come on when I pumped the clutch but then disappear. The oil temp reached 240. The car is going to be towed to the dealership but I have a feeling I will be screwed on the warranty, obviously.
The wife is going to go ballistic when she finds out warranty is gone lol.
Already have a quote to ship the car down to TAV. $175. Not bad. Build motor will be $400 by Bertune. $1500 to install. Hopefully no hang ups and we should be good. I am still missing a timing belt, head studs, gaskets and bearings though so that should all add up to about $800. So roughly $3000 total.
Old 08-25-2011, 04:35 PM   #50
JerseyImportz
Member#: 292526
Nice. hella clean.
JerseyImportz is offline   Reply With Quote
Will it fit: 2011 STi Sedan exhaust on 2010 WRX Sedan btr22 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 42 07-08-2016 02:26 PM
Forged Performance: 2011 STi Sedan MONSTER Build **check back often** Forged Performance NASIOC Project Cars 462 07-06-2016 08:06 PM
Fast Motorsports Prototype 08+ wrx sedan and 2011+ sti sedan catback! first pics! IMPORTIMAGE Vendor Announcements 4 05-02-2011 09:50 PM
Comparing 2011 STi Sedan to 2011 WRX Sedan DasWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 12-21-2010 07:09 AM
new with a question about 2011 STI sedan vs. previous STI sedans tommygsubie Newbies & FAQs 37 11-02-2010 12:16 PM
