Old 08-25-2011, 04:52 PM   #51
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
Originally Posted by jockeygolfs
Time has come! Engine is dead. Even on a conservative map. i was running at 21.5 PSI max. My mechanic says 19 is the max on OEM pistons. Currently waiting to be towed. I'm in the middle of nowhere. Just south of the city of Okeechobee in FL. Car was sounding awesome and then sputtering. The car was making weird sounds like playing cards in bike spokes.
So I pulled off the road and called Gustavo at TAV racing. He told me to check the oil. It is all gone. The oil light would come on when I pumped the clutch but then disappear. The oil temp reached 240. The car is going to be towed to the dealership but I have a feeling I will be screwed on the warranty, obviously.
The wife is going to go ballistic when she finds out warranty is gone lol.
Already have a quote to ship the car down to TAV. $175. Not bad. Build motor will be $400 by Bertune. $1500 to install. Hopefully no hang ups and we should be good. I am still missing a timing belt, head studs, gaskets and bearings though so that should all add up to about $800. So roughly $3000 total.
What!!!!! Sorry man.
smeerone is offline   Reply With Quote
Old 08-25-2011, 04:57 PM   #52
last lemming alive
Member#: 139465
2011 STi Limited
Satin White Pearl
Man you serioiusly have the "gotta haves". You're my hero! Your not alone with dealing with the ole ball'n chain though, been there and done that. Just tell her look honey, I have another engine I was going to swap in anyway! Then you stretch the truth and say hey honey, I'll be able to sell the OEM unit for some cash - dont forget to smile when you lay down the news.
A word of advice - though you may already know it - get a total game plan and a realistic outlook on what you really want to achieve. You seem to keep moving your goals, that's ok as long as all the other parts keep up with the new goals. If you don't think the plan over each time the plan changes you risk having a weak link that makes things go way wrong.
Also you will almost never be satisfied with the amount of power. Who is. Remember its your DD, not a race car, and even good parts and install wont guarantee you wont have many little issues you will always be chasing down. The more you mod the more likely that is.
Just some friendly advice. Otherwise have fun. and good luck.
last lemming alive is offline   Reply With Quote
Old 08-25-2011, 05:06 PM   #53
CTSparky
Member#: 282204
2011 5 Door STi
Plasma Blue Pearl
I'm sorry to hear this. I hope you and your wife work things out.
good luck in the engine rebuild. At least now you can built the bottom end to handle the power.
CTSparky is offline   Reply With Quote
Old 08-25-2011, 06:26 PM   #54
jockeygolfs
Member#: 260868
2011 STI
July 14:
DC Power Engineering 180 Amp Alternator
jockeygolfs is offline   Reply With Quote
Old 08-25-2011, 09:23 PM   #55
jockeygolfs
Member#: 260868
2011 STI
July 14:
Paint Matched Rear Garnish
Fortune Auto
Advan RZ 18"x10" +35
Old 08-26-2011, 07:23 AM   #56
jockeygolfs
Member#: 260868
2011 STI
Default Jockeygolf's 2011 STI Sedan Build
August 14': SPC Lateral Control Arms and Toe Link Installed
Rear Lower Control Arms and Toe Arms:
Swapped my 6262 for a new 6262. Oil leaking once again!!!!
Superpro Center Roll Kit
More bushings have come in.
Whiteline Caster/antilift Bushings
Whiteline Front Control Arm Front Inner Lower Bushings
Whiteline Steering Rack Bushings
Whiteline Positive Shift Bushings
Whiteline Positive Shift Bushings:
Old 08-26-2011, 02:49 PM   #57
jockeygolfs
Member#: 260868
2011 STI
Front Sway Bar Whiteline 22mm:
Rear Sway Bar Whiteline 22mm:
Kartboy Endlinks:
2015 STI 13:1 Steering Rack:
Steering Rack with Whiteline Steering Bushings:
Old 08-26-2011, 11:47 PM   #58
Jdub.csu
Member#: 283784
2013 EVO X GSR
Its to bad your stock engine went. Keep us updated on what goes on with the dealership.
Jdub.csu is offline   Reply With Quote
Old 08-27-2011, 10:42 AM   #59
jockeygolfs
Member#: 260868
2011 STI
Rear Diff Whiteline Bushings:
Front lower control arm inner front bushing:
Old 08-27-2011, 05:18 PM   #60
CapeCod27
Member#: 207701
2015 STi
This is my problem, I bought a 2011 wrx, and have done everything to get the most out of the stock VF52, tbe,injectors, fuel pump, cai, intercooler, BPV etc... plus all the suspension work and bushings, blah, blah, blah, it's really fast for a DD, but now i'm thinking bigger turbo......
I don't keep a car for more than 2 years, if I broke down what i've spent on my car in mods for the 2 months i've owned it by 24 months (time before I trade it in) plus my car payment of $420 per month that would total probably $620 per month for 2 years.....GODDAMNIT, I should just buy a GT-R and not touch the thing and be happy...with a friggin warantee on top of it because mine is gone.
CapeCod27 is offline   Reply With Quote
Old 08-27-2011, 05:44 PM   #61
Jdub.csu
Member#: 283784
2013 EVO X GSR
You would still touch it though, insurance would be more, sales tax, license ext.
Such is the life of a car enthusiast. Why do people that love building gaming machines build machines that are overkill and could wipe the face of some business servers... Because they can.
It's a never ending cycle, and it's an expensive cycle lol
Old 08-27-2011, 06:57 PM   #62
jockeygolfs
Member#: 260868
2011 STI
September 14':
Whiteline Rear Subframe Inserts
Superpro Trailing Arm Bushings
Whiteline Antilift/caster Bushing
Old 08-29-2011, 09:44 AM   #63
jockeygolfs
Member#: 260868
2011 STI
October 14' Radium Multipump Surge Tank:
So change in plans. I want to be able to run E85 witbout worrying about the pump failing. Bosch 044 are not designed for E85. So I have decided to go with Radium Multipump Surge Tank with two Walbro 465's:
Mounting Plate
Fuel Injector Clinic 2150's
Old 08-29-2011, 10:00 AM   #64
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
Spun rod bearing in cylinder #1 is the failure that the dealership has found so far. They are continuing to break it down and a Subaru rep will be around today or tomorrow to check it out.
What damage could a spun rod bearing do to the rest of the engine?
A whole lot. It looks like the proverbial can of worms is opening up....
Old 08-29-2011, 10:24 AM   #65
jockeygolfs
Member#: 260868
2011 STI
12/17/14 Build 2.x:
Outfront Motorsports Closed Deck Block with 1/2" Head Studs and Pinned Mains
CP Pistons Coated Crowns
Pauter X Beams
Ferrea Dual Springs
Ferrea +1 Competition Plus Valves
Ferrea Tooled Steel Retainers
Ferrea Locks, Seats, Seals
Kelford 280's
CP with coated crowns:
Old 08-29-2011, 11:13 AM   #66
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
I was worried about that. Hopefully I stopped driving in time to not cause catastrophic damage. If the damage is a spun bearing would the power level of my car matter? Isn't a spun bearing an oiling issue? maybe their crappy pick up broke and that caused the oil issue and spun the bearing?
All plausible, but see what SOA has to say. Ure issue has been very common as of late for that year car.
Old 08-29-2011, 02:17 PM   #67
jockeygolfs
Member#: 260868
2011 STI
July 15': Aeromotive Fuel Pump Controller and Autometer Tach Adapter
Old 08-29-2011, 02:20 PM   #68
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
HOLY CRAP!!!!! SOA will do a one time good will block replacement!!!!!!! They are paying for everything!!!! Block and all associated parts!!!! Reasoning being it is a relatively new car with only 19k miles. Real awesome. I'll release the dealership name once i get the car back!!!
Told ya to wait haha Congrats man.
Old 08-29-2011, 02:31 PM   #69
jockeygolfs
Member#: 260868
2011 STI
August 15':
Koyorad Radiator
Fuelab Large Seat High Flow Regulator
Block Assembly
[/url]
Old 08-29-2011, 02:58 PM   #70
WRXt4cy
Member#: 172698
11 STi BW 8374 E85
02 v8 Spec C E85
Glad to hear they are fixing it for you. A broken piston would be one thing I can understand blaming on tuning or increasing power output, but spinning a bearing at your mileage seems more like manufacturing defect to me assuming you changed the oil regularly and maintained the correct level of oil.
Are they considering your warranty voided now since you modded the car?
WRXt4cy is offline   Reply With Quote
Old 08-29-2011, 03:09 PM   #71
jockeygolfs
Member#: 260868
2011 STI
They said no. I have had the dealership do every oil change at 3,000+ miles so that is not an issue. I did leave a message for them that I wanted a picture of the pick up pipe and that I knew about the failures they have with them. Maybe that was the real issue and they knew that should be on them even with all the mods. Who knows. Eitherway I'm not complaining! I will sing the praises of this dealership once all is said and done. Maybe as soon as Friday they said.
My block is still being built this week though. Gives me time for some stocks to go up to pay for the swap lol.
Old 08-29-2011, 03:16 PM   #72
berge56
Member#: 56754
2004 Hybrid 2.5XTR
RIP [email protected]
Great build man! We have the same setup with the exception that I had 100mm pistons installed. :up:
berge56 is offline   Reply With Quote
Old 08-29-2011, 03:21 PM   #73
jockeygolfs
Member#: 260868
2011 STI
Whoa. Did you sleeve?
Old 08-29-2011, 03:49 PM   #74
truwrxtacy
Member#: 84786
2011 STi
Wow! What a badass dealership
truwrxtacy is offline   Reply With Quote
Old 08-29-2011, 03:51 PM   #75
jockeygolfs
Member#: 260868
2011 STI
Badass Subaru Rep!!! He was the one that told the dealership Subaru would cover it!
Will it fit: 2011 STi Sedan exhaust on 2010 WRX Sedan btr22 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 41 02-07-2016 10:44 AM
Forged Performance: 2011 STi Sedan MONSTER Build **check back often** Forged Performance NASIOC Project Cars 461 09-10-2015 12:14 PM
Fast Motorsports Prototype 08+ wrx sedan and 2011+ sti sedan catback! first pics! IMPORTIMAGE Vendor Announcements 4 05-02-2011 09:50 PM
Comparing 2011 STi Sedan to 2011 WRX Sedan DasWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 12-21-2010 07:09 AM
new with a question about 2011 STI sedan vs. previous STI sedans tommygsubie Newbies & FAQs 37 11-02-2010 12:16 PM
