Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2015
Old 08-16-2012, 11:50 PM   #901
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
Looks nice up top!
smeerone is offline   Reply With Quote
Old 08-17-2012, 03:53 PM   #902
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
Ended up with 370/410.. On the e85
Old 08-17-2012, 03:54 PM   #903
jockeygolfs
Member#: 260868
2011 STI
God damn man. Stock turbo???
jockeygolfs is offline   Reply With Quote
Old 08-17-2012, 03:57 PM   #904
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
Vf52 ( stock) but remember no top end. I drop off terribly unlike ure beast.
Old 08-17-2012, 03:58 PM   #905
jockeygolfs
Member#: 260868
2011 STI
Ah. Still cool man. Congrats. How many pulls did it take to finish?
Old 08-17-2012, 04:00 PM   #906
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
In total we were on the road 1.2 hours and about 6 3rd gear and 4 all out pulls. Very torquey down low.
Old 08-17-2012, 04:04 PM   #907
Jdub.csu
Member#: 283784
2013 EVO X GSR
This is why I love E85 =)
Jdub.csu is offline   Reply With Quote
Old 08-17-2012, 04:04 PM   #908
jockeygolfs
Member#: 260868
2011 STI
These guys know what they are doing. Phatbotti!! I want a sticker.
Old 08-17-2012, 04:08 PM   #909
jockeygolfs
Member#: 260868
2011 STI
If I had meth I'd still inject and get 107 oct lol.
Old 08-17-2012, 05:35 PM   #910
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
Edit 360/410
Old 08-18-2012, 12:28 PM   #911
jockeygolfs
Member#: 260868
2011 STI
Have an Omni 4bar sensor on the way. Maybe add some more boost in the future.
Old 08-19-2012, 02:21 AM   #912
themaus
Member#: 321211
Working on jockeys car till 1 AM. Good times.
themaus is offline   Reply With Quote
Old 08-19-2012, 07:45 AM   #913
jockeygolfs
Member#: 260868
2011 STI
Themaus and Wrx02ftw were over to work on Themaus' car. Did an oil change and installed gauges. They convinced me to wrap my headers. The problem was I was convinced at 7 pm. Running around to four different auto parts store we could not get enough of the DEI Titanium wrap. Ended up with 50' of 2" DEI wrap in black.
This was the worse idea ever. I let the wrap soak in water for a while since we were all having dinner. Took the headers off and then began wrapping. The black dye was running. Everywhere! Plus it was 50' worth, so I had to pull 50' around and around and around as I made my way on the header. My garage was a mess. Black crap all over my garage.
In the end though it turned out looking good. WRx02ftw put my heat gun into the runners to dry off the wrap. I painted everything with silicone paint. We tested out the paint with a blow torch, yes it works an the wrap did not catch fire. And then we finally installed them.
We went for a drive at 1 am. Verdict...seems as though the temps have gone down minimally.i will have to give it a go some more to see but I don't think I'm going to get my IAT's down to +10* over ambient like I want. We are probably going to have to do more work in the fender well to isolate the intake.
Old 08-19-2012, 11:16 AM   #914
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
Jock i just picked this up
http://www.ptpturboblankets.com/subarublk.shtml
Can't hurt and drastically lowers engine bay temps. Perhaps it can help u. Also are ure intake pipes heat wrapped?
Old 08-19-2012, 11:48 AM   #915
jockeygolfs
Member#: 260868
2011 STI
I used dei reflective tape on my intake. Intake still gets screaming hot. Let me know how the blanket works for you. I've seen articles where they don't seem to help that much but maybe first hand experience will be good.
When it is time to go ewg and new turbo I might try coating them. All in all I just think I'm screwed in the engine temp department.
Old 08-20-2012, 11:43 AM   #916
jockeygolfs
Member#: 260868
2011 STI
Late night working with Themaus and WRX02FTW
Wrapped headers
Old 08-20-2012, 12:07 PM   #917
xluben
Member#: 261612
2002 WRX Sedan
9.9s @ 140mph
http://i1120.photobucket.com/albums/...050254156D.jpg
I put a turbo blanket on recently. Seems to keep things cooler, but I have no solid numbers to back that up. I don't have anything else for heat shielding besides the GrimmSpeed turbo heat shield.
http://forums.nasioc.com/forums/show...postcount=2597
xluben is offline   Reply With Quote
Old 08-20-2012, 12:15 PM   #918
jockeygolfs
Member#: 260868
2011 STI
Have you checked your IAT's with it on? I'm thinking it wouldn't help with IAT's since it is so far from the intake. I think the aluminum on the intake is what is killing me. You have a KSTech as well. I think in the summer I'm just going to be out of luck with IAT's no matter what since I need the larger diameter for my setup.
Old 08-20-2012, 12:29 PM   #919
themaus
Member#: 321211
If the turbo blanket keeps heat in the turbo and helps keeping it out of the engine bay then it would drop the temps of the engine bay which should help with the heatsoak. You should just break down and do it.
Old 08-20-2012, 12:36 PM   #920
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
Originally Posted by themaus
If you the turbo blanket keeps heat in the turbo and helps keeping it out of the engine bay then it would drop the temps of the engine bay which should help with the heatsoak. You should just break down and do it.
Stop being a wuss jock, do it!! Do it!!!! Peer pressure!!!! Lol
Old 08-20-2012, 12:52 PM   #921
Jdub.csu
Member#: 283784
2013 EVO X GSR
Turbo blanket + heat shield FTW lol
Old 08-20-2012, 12:59 PM   #922
jockeygolfs
Member#: 260868
2011 STI
Hahaha like I have been wussing out in my build. I just don't want to spend more money on something that doesn't help much like the wrap. The focus is the IAT. Give me back up on effectiveness first. That is $70 that needs to go towards the next turbo which might need a different size blanket anyways!
And I think my stupid heavy OEM heat shield has to be working better than that aluminum foil grimmspeed shield.
Old 08-20-2012, 01:10 PM   #923
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
U know I'm busting ure chops. Once I get it, I'll do thermal reading at intake and turbo. Keep u posted.
Old 08-20-2012, 01:56 PM   #924
jockeygolfs
Member#: 260868
2011 STI
I know man. I take all comments as joking. Yes please take some temp readings. My issue is that heat wrap was supposed to knock some temps down and that clearly has not happened. I would think heat wrap would be more effective than a turbo blanket since in my mind the turbo will have more exposed areas than a wrapped header for heat to escape. Therefore turbo blanket will not be the answer, in my mind.
I think we need vents closer to the windshield on the hood to help vent air out of the engine compartment. The air is just getting trapped in there.
Old 08-20-2012, 01:59 PM   #925
themaus
Member#: 321211
I have a sawzall. Let's cut your hood up.
Forged Performance: 2011 STi Sedan MONSTER Build **check back often** Forged Performance NASIOC Project Cars 459 04-11-2015 06:26 PM
Will it fit: 2011 STi Sedan exhaust on 2010 WRX Sedan btr22 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 38 04-21-2014 03:11 PM
Fast Motorsports Prototype 08+ wrx sedan and 2011+ sti sedan catback! first pics! IMPORTIMAGE Vendor Announcements 4 05-02-2011 09:50 PM
Comparing 2011 STi Sedan to 2011 WRX Sedan DasWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 12-21-2010 07:09 AM
new with a question about 2011 STI sedan vs. previous STI sedans tommygsubie Newbies & FAQs 37 11-02-2010 12:16 PM
