Welcome to the North American Subaru Impreza Owners Club Sunday April 19, 2015
Old 08-21-2012, 10:04 PM   #951
xluben
Member#: 261612
2002 WRX Sedan
10.9s @ 128mph
Any issues with the Aeromotive 340 and E85? I've heard they don't play well together.
And why is Akuma using a hose for the install in the plastic (08+) housing? It doesn't plug in like the Walbro?
xluben is offline   Reply With Quote
Old 08-21-2012, 10:18 PM   #952
jockeygolfs
Member#: 260868
2011 STI
What pump are you on Xluben?
jockeygolfs is offline   Reply With Quote
Old 08-21-2012, 10:24 PM   #953
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
Is this ure daily?
smeerone is offline   Reply With Quote
Old 08-21-2012, 10:50 PM   #954
jockeygolfs
Member#: 260868
2011 STI
You asking me? Yes it is my daily. Right now I only get gas from one place but yesterday I actually did have to get gas somewhere else because my tank was empty. I can see it being worse with E85.
Old 08-21-2012, 11:59 PM   #955
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
Well that is something to consider. If u have an AP u could run dual maps. But your injectors would likely need to be smaller.
Old 08-22-2012, 12:14 AM   #956
Jdub.csu
Member#: 283784
2013 EVO X GSR
Who the **** told you that? Most people on e run them here
Jdub.csu is offline   Reply With Quote
Old 08-22-2012, 12:15 AM   #957
Jdub.csu
Member#: 283784
2013 EVO X GSR
Smaller? Lol what bigger
Old 08-22-2012, 12:15 AM   #958
xluben
Member#: 261612
2002 WRX Sedan
10.9s @ 128mph
I'm on a Walbro 255. It's just about out of fuel where I'm at now. I'll probably hard wire it next, and I think that will be fine unless I get a bigger turbo. Then I'll probably have to bump the base pressure or get a bigger pump. That Aeromotive 340 looks like a great option, but I've heard bad things about it on E85.
Old 08-22-2012, 12:21 AM   #959
PurpleHeartSti
Member#: 283940
2008 Sti
I called aeromotive about their 340 because I have it and want to do E85. The guy on the phone straight up said e85 is garbage and to stay away from it... So yeah, their pump isn't meant for e85. Definitely a walbro, DW, bosch...
PurpleHeartSti is offline   Reply With Quote
Old 08-22-2012, 12:25 AM   #960
xluben
Member#: 261612
2002 WRX Sedan
10.9s @ 128mph
Who is "here"? Locally? There are plenty of posts about them crapping out on E85. Here and other forums.
I thought you had one in your car? Did it go out?
Old 08-22-2012, 12:35 AM   #961
Jdub.csu
Member#: 283784
2013 EVO X GSR
Colorado. I haven't seen one go bad yet on E so idk. If the manufacture says it then I guess stick away. There is a guy here running bosch but they are stupid loud
Old 08-22-2012, 12:37 AM   #962
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
I meant smaller than 1600 sorry.
Old 08-22-2012, 12:39 AM   #963
Jdub.csu
Member#: 283784
2013 EVO X GSR
From aeromotive.
A: E85 fuel has become a viable option for street performance enthusiasts in recent years. It has some very significant pros, and equally significant cons, to consider. It does provide higher octane, and lower charge air temperatures, and is especially popular in forced induction applications, permitting more aggressive combinations of boost, compression ratios and tuning. It is also less costly per-gallon than high-octane racing gasoline. That said, fuel usage increases 30-35% to support equal HP, somewhat offsetting the lower cost and requiring the HP rating of all fuel system components, including and especially the HP ratings of the fuel pump and fuel injectors, be reduced by 30-35%.
A crucial consideration regarding whether or not to run E85 is its tendency to rapidly and frequently contaminate and clog/block fuel filters, resulting in significant flow restrictions, which in turn may damage the engine and/or cause premature fuel pump failure. The reasons for filter contamination problems with E85 include:
E85 is an alcohol based fuel, and alcohols are hygroscopic (attract and absorb water from the atmosphere), which can accumulate in and clog fine filter elements.
E85 is an agriculturally produced fuel and, being a byproduct of plant material, there have been indications some of this “bio-mass” can accumulate in, and clog fuel filters.
E85 has very strong solvent properties, like many alcohol based liquids, which will act to strip accumulated debris and residues from transport and storage containers, and the inside of fuel tanks and fuel lines, which in turn accumulate in, and clog fuel filters.
Aeromotive has conducted extensive testing of the 340 Stealth Pump in E85 fuel, achieving 1,000 plus run hours of service life operating at 60 PSI and 13.5 Volts. In testing, it was found a filter service interval that gave good fuel pump service life required a new, down-stream filter be installed every 10 run-hours. It is vital to understand that a blocked filter creates severe flow restriction of pump output, building excessively high operating pressure between the pump and the contaminated element. If the Stealth 340 is allowed to run in this environment, operating pressures between pump and filter can exceed 90 PSI, creating extreme current draw and reduced cooling flow, resulting in rapid failure of the fuel pump motor assembly.
WARNING: If you plan to run E85 fuel you must be prepared to install proper filtration, and maintain it as frequently as every 10 run-hours. If not, Aeromotive does NOT recommend you the use of E85 with the 340 Stealth Fuel Pump. Aeromotive’s new product warranty assures the purchaser their 340 Stealth Pump will be free from defects in material and workmanship for one year from the date of purchase. Fuel pump failure caused by clogged/blocked fuel filters is not the result of any defect in the pump itself, and is not covered under this warranty.
For a detailed look at post-pump filter options and what a good one should be like, please see Aeromotive Tech Bulletin: Post-Pump Fuel Filtration TB-102 here:
http://aeromotiveinc.com/2010/05/pos...el-filtration/
For a specific example of the issues related to a clogged post-pump filter, please take a moment to see the Case History File embedded in TB-102 here:
Old 08-22-2012, 05:26 AM   #964
jockeygolfs
Member#: 260868
2011 STI
/e85. The power potential is so strong in pulling me into it but the headaches associated with the fuel in the long run do not seem to be worth it. Add to that this is my DD and there is only one station between me and my work that has it.
Bigger turbo in the future then.
Old 08-22-2012, 08:12 AM   #965
xluben
Member#: 261612
2002 WRX Sedan
10.9s @ 128mph
From aeromotive.
So they don't recommend it, but they're trying to blame it on something other than the pump. It just seems like there have been a lot of failures of that pump on E85 vs. something like the Walbro or DW stock location pumps. I'd really love to use the Aeromotive, but I'm a little hesitant.
Old 08-22-2012, 08:29 AM   #966
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
Xluben, how often are u cleaning ure fuel filter? Did u upgrade to the 100 micron?
Old 08-22-2012, 08:40 AM   #967
xluben
Member#: 261612
2002 WRX Sedan
10.9s @ 128mph
Never cleaned it. Didn't upgrade. Link? A local guy just replaced his after 3 years on E85 with a Walbro and no issues.
Old 08-22-2012, 10:30 AM   #968
jockeygolfs
Member#: 260868
2011 STI
How often are we supposed to change out the fuel filter? I'll probably just get a new one and do a new pump at the same time. Deatschwerks 300 seems promising.
Old 08-22-2012, 10:55 AM   #969
Jdub.csu
Member#: 283784
2013 EVO X GSR
Running stock on pump gas every 60K. 10 hours according to aeromotive at 60 miles per hour is 600 miles yikes.
I would recommend on E that you replace it at least every 10K. That's what most of the tuners around here will tell you, they also tell people to run a separate smaller micron filter too which most guys around here do. They another smaller filter near the fpr that's is washable that they clean every 1,000 miles or so.
Old 08-22-2012, 11:36 AM   #970
xluben
Member#: 261612
2002 WRX Sedan
10.9s @ 128mph
Could this issue be regional? I've seen stories on other boards (other cars) about fuel filters getting gunked up or fuel pumps crapping out on E85, sometimes within just a few hundred miles. There are all sorts of special precautions being taken, but all the MN guys just throw in a Walbro and injectors and run E85 for years with no issues.
Old 08-22-2012, 12:06 PM   #971
jockeygolfs
Member#: 260868
2011 STI
That seems nuts to do that much maintenance. Yes I'm leaving power on the table but less headaches. Plus I like watching my meth gauge and hearing the injection lol.
Old 08-22-2012, 12:08 PM   #972
Jdub.csu
Member#: 283784
2013 EVO X GSR
It's possible, it also depends on the station really. E85 attracts water do areas with more of it are gonna do worse than others
How fast are you going through the meth?
Old 08-22-2012, 12:13 PM   #973
smeerone
Member#: 249068
2010 WRX
DGM Phatbotti Tuned
3-4 grams a day, wait u mean car meth? Lol
Old 08-22-2012, 12:16 PM   #974
Jdub.csu
Member#: 283784
2013 EVO X GSR
Bahaha meth... Only every day for jockeys case
Old 08-22-2012, 01:25 PM   #975
jockeygolfs
Member#: 260868
2011 STI
Since I was done tuning I have not added any meth. I'm down about 1/2 gallon. On one tank of gas.
Forged Performance: 2011 STi Sedan MONSTER Build **check back often** Forged Performance NASIOC Project Cars 459 04-11-2015 06:26 PM
Will it fit: 2011 STi Sedan exhaust on 2010 WRX Sedan btr22 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 38 04-21-2014 03:11 PM
Fast Motorsports Prototype 08+ wrx sedan and 2011+ sti sedan catback! first pics! IMPORTIMAGE Vendor Announcements 4 05-02-2011 09:50 PM
Comparing 2011 STi Sedan to 2011 WRX Sedan DasWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 12-21-2010 07:09 AM
new with a question about 2011 STI sedan vs. previous STI sedans tommygsubie Newbies & FAQs 37 11-02-2010 12:16 PM
