Old 08-29-2011, 04:39 PM   #76
stu
Member#: 25768
35R bugeye
Slowbaru
wow you are very lucky. good luck with the rest of your build
stu is offline   Reply With Quote
Old 08-29-2011, 06:33 PM   #77
jockeygolfs
Member#: 260868
2011 STI
Thanks. I think I'm going to ride out this next motor and stick to my original plan of swapping it later this year or so. Now that I'm starting back at 0 miles on the engine I should be good to go for a while. Probably wait until the actual warranty ends. This will give me time to do plan out any other ideas I come up with such as heads etc. I doubt it though.
Bertune says my block should be done by this weekend. Two cylinders will need to be honed as well to fit the Cosworth pistons with the proper clearance.
jockeygolfs is offline   Reply With Quote
Old 08-29-2011, 07:50 PM   #78
Jdub.csu
Member#: 283784
2013 EVO X GSR
Why don't you have the dealership install your killer B setup so you know this engine will last?
Jdub.csu is offline   Reply With Quote
Old 08-29-2011, 07:52 PM   #79
jockeygolfs
Member#: 260868
2011 STI
Hmmm, not a bad idea. Not sure if they would go for it since it isn't OEM. I guess I can ask.
Old 08-29-2011, 08:04 PM   #80
Jdub.csu
Member#: 283784
2013 EVO X GSR
Can't hurt to ask =)
Old 08-29-2011, 08:08 PM   #81
jockeygolfs
Member#: 260868
2011 STI
I am still wondering if the pick up was really an issue. They only said that the engine spun the bearing. Maybe I'll drop by on the dealership tomorrow to take a look.
I'm swapping my 12 mm oil pump for a 11 mm oil pump for my future build. Too many threads out there that have scared me away from the 12 mm.
Old 08-29-2011, 09:35 PM   #82
Jdub.csu
Member#: 283784
2013 EVO X GSR
That sounds like an oil issue to me, and we all know the stock pickup blows.
Let us know what they say about the pickup.
Old 08-29-2011, 09:52 PM   #83
Ce10
Member#: 231031
07 STI
Wow this car is amazing. Props my brother.
Ce10 is offline   Reply With Quote
Old 08-29-2011, 10:19 PM   #84
CTSparky
Member#: 282204
2011 5 Door STi
Plasma Blue Pearl
you are the luckiest man alive.
CTSparky is offline   Reply With Quote
Old 08-29-2011, 10:33 PM   #85
jockeygolfs
Member#: 260868
2011 STI
I have a friend that I piss off a lot because of some of my luck. I don't have the car in my hands yet so I don't want to get too happy just yet! I won't see the parts list until I go pick up the car. I really hope they went with replacing the full long block and all the other parts that deal with the oil system.
It will be really nuts of they give me a new turbo as well. I doubt it. Plus I hope my DOM 2.5XT-R is still fully functional.
Old 08-29-2011, 10:33 PM   #86
jockeygolfs
Member#: 260868
2011 STI
Much appreciated.
Old 08-30-2011, 08:02 AM   #87
Wanarex
Member#: 173034
Great well-rounded built you've got. You've also got one of the best dealership stories I've heard. Congrats on the new block!
Wanarex is offline   Reply With Quote
Old 08-30-2011, 08:35 AM   #88
jockeygolfs
Member#: 260868
2011 STI
^Thanks! That was my goal. Power might take a back seat after all of this for a bit. Time to beef up handling maybe.
I made the call today to see if they will put in my Killer B pick up and they said they can't since this is technically a warranty issue.
I also tried to see if I could keep the block they are pulling and they said they can't give it to me because it has to be sent back to Subaru.
For now it looks as though I'm getting a new short block and not a long block. Hopefully these guys know how to clean everything out properly. According to the service rep they do not know the cause of the failure other than the lack of oil in the pan.
Old 08-30-2011, 12:18 PM   #89
Jdub.csu
Member#: 283784
2013 EVO X GSR
You could ask if you could pay to replace the pickup with the killer B one or get an oil pressure gauge asap once you get the car back.
I don't trust the pickups on those cars at all. They are pos.
Old 08-30-2011, 02:25 PM   #90
jockeygolfs
Member#: 260868
2011 STI
Yeah I think I'm going to have the pick up installed shortly after I get the car back. It seems like a messy thing to try to DIY. Might have someone do it for me.
The oil pressure gauge will be next but I need a nice mounting piece. Where do I put it??
Old 08-30-2011, 03:08 PM   #91
gregroot198521
Member#: 280844
2006 STi
Above the mirror: LINK to Mach V's item page.
gregroot198521 is offline   Reply With Quote
Old 08-30-2011, 03:16 PM   #92
jockeygolfs
Member#: 260868
2011 STI
Interesting. Where are all the wires supposed to go??
Old 08-30-2011, 03:25 PM   #93
gregroot198521
Member#: 280844
2006 STi
Between the headliner and the roof is what I understood or maybe stuffed in the crack between the edge of the window and the window. Haven't taken the plunge and installed yet, cause I still need to install the sandwich adapter when I get my oil changed. You don't have the limited model do you? If you do, it looks like it needs some cutting down to work with sunroof control box, which I'll be doing sometime after I'm back in VA.
Old 08-30-2011, 03:46 PM   #94
jockeygolfs
Member#: 260868
2011 STI
I have the base STI. I need to see more pics of this installed.
Old 08-30-2011, 04:59 PM   #95
jockeygolfs
Member#: 260868
2011 STI
So get this. My dad's car he let me borrow is now taking a dump on me! Apparently he knew there was an issue but didn't let me know. I drove over 150 miles to Miami with my daughter last week not knowing about this. Now I'm on my way home and stuck at a shopping center.
The problem....bad piston. Million bucks says his mechanic told him about it but he figures the car is fine.
Nice dad.
Old 08-30-2011, 05:47 PM   #96
arf80
Member#: 125580
2011 WRX 5dr
So you're going to have two new engines basically? Or is the built motor on hold?
arf80 is offline   Reply With Quote
Old 08-30-2011, 06:18 PM   #97
jockeygolfs
Member#: 260868
2011 STI
Yes, I have two motors. One is being built right now and the other is being installed by the dealership.
Yes, I am that nuts.
Old 08-30-2011, 07:08 PM   #98
betterthansx
Member#: 259103
07' Mazdaspeed3
Cosmic Blue
That's not nuts...it's convenient!
betterthansx is offline   Reply With Quote
Old 08-30-2011, 07:15 PM   #99
jockeygolfs
Member#: 260868
2011 STI
^ good to see people think like I do sometimes. Can you convince my wife?
Old 08-30-2011, 09:05 PM   #100
jockeygolfs
Member#: 260868
2011 STI
Picking up a rental Chevy Aveo tomorrow Can't wait!!
Will it fit: 2011 STi Sedan exhaust on 2010 WRX Sedan btr22 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 42 07-08-2016 02:26 PM
Forged Performance: 2011 STi Sedan MONSTER Build **check back often** Forged Performance NASIOC Project Cars 462 07-06-2016 08:06 PM
Fast Motorsports Prototype 08+ wrx sedan and 2011+ sti sedan catback! first pics! IMPORTIMAGE Vendor Announcements 4 05-02-2011 09:50 PM
Comparing 2011 STi Sedan to 2011 WRX Sedan DasWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 12-21-2010 07:09 AM
new with a question about 2011 STI sedan vs. previous STI sedans tommygsubie Newbies & FAQs 37 11-02-2010 12:16 PM
