Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 06-17-2013, 12:04 PM   #1426
alva8193
Member#: 318755
2012 Phatbotti Tuned
Congrats jockey! looking good, now get that clutch installed so i can do some clutch drops
alva8193 is offline   Reply With Quote
Old 06-17-2013, 12:11 PM   #1427
jockeygolfs
Member#: 260868
2011 STI
Thanks guys. Here at Motion Motorsports in Miami right now getting clutch put in.
jockeygolfs is offline   Reply With Quote
Old 06-17-2013, 09:52 PM   #1428
b154wheel
Member#: 206874
2010 Impreza WRX
That turbo be huge!!!! Also is it me or did some of those pics on the last page not load?
b154wheel is offline   Reply With Quote
Old 06-17-2013, 10:18 PM   #1429
jockeygolfs
Member#: 260868
2011 STI
They work for me
Old 06-17-2013, 10:21 PM   #1430
jockeygolfs
Member#: 260868
2011 STI
Clutch installed. Pics to come.
Old 06-17-2013, 11:12 PM   #1431
WrxFtw02
Member#: 231192
2003 WRX
PROs Tuned 270/251
This car is baller, always a fun time working on it.
WrxFtw02 is offline   Reply With Quote
Old 06-18-2013, 09:27 AM   #1432
jockeygolfs
Member#: 260868
2011 STI
Exedy Triple Disk Clutch
Old 06-21-2013, 02:34 AM   #1433
b154wheel
Member#: 206874
2010 Impreza WRX
Yea thats weird. All the pics work for me know. huh.
Anyways, car is looking good. Very clean and looking like it's going to be pretty fast. I'm curious what kind of numbers you are going to get.
Old 06-21-2013, 07:45 AM   #1434
jockeygolfs
Member#: 260868
2011 STI
Thank you! I get tuned this Sunday. Mikey says it should be around 550whp. I'm not going to hold him to it though. Whatever it makes it makes. Fuel is my limiter right now. People are making 600-700 whp on this turbo right now but they also have 2000 injectors and dual pumps etc.
I'm going to see what I can make on my current setup and then in the future I will be upgrading my fuel system. The car is always evolving
Old 06-21-2013, 09:19 PM   #1435
Jdub.csu
Member#: 283784
2013 EVO X GSR
Sounds like a blast!
Jdub.csu is offline   Reply With Quote
Old 06-21-2013, 10:55 PM   #1436
jockeygolfs
Member#: 260868
2011 STI
I wish. I have been having fuel pump problems for the past few weeks. I'm starting to learn that my wiring job was really bad in the beginning. I would think I fixed one thing and then something would happen. Spent this morning hooking up my DCCD Pro up an finally got it working and then my pump died. Checked all my wiring and drove myself nuts. Took the pump out, tested it and did some new soldering. When I finally had everything back together again I tried to crank the car to find I had killed the battery.
Luckily I have a neighbor with a charger. While I waited for him to come home to help me out I decided to solder all my connections and get rid of all the crimp connections. I do have crimped quick disconnects for the relay and FPC. It makes it easier for me to take the FPC out as needed and to be able to hook the fuel pump up for 100% flow if something goes wrong with the FPC. One day I may swap these for weather pack connectors which I will then use solder on those.
The car is finally running again though. I have another Walbro 400 on order for a back up just in case.
Lesson of the day, just solder as many connection as possible.
Old 06-22-2013, 12:23 AM   #1437
b154wheel
Member#: 206874
2010 Impreza WRX
Solder>Crimp connectors
Old 06-23-2013, 03:47 PM   #1438
jockeygolfs
Member#: 260868
2011 STI
Tuning began this morning. We were able to do sbout five pulls until the fuel pump would not flow enough fuel to keep the pressures up. It was determined that the pump was on its way out. Thank god I was able to still drive it home which was an hour away.
I just happened to order a new Walbro400 E85 on Friday for a Saturday delivery. I brought all my tools to fix the car if something happened except for the damn spare pump.
New pump is installed and took the pump for a test. Fuel pressure was able to hit 100 psi. I'm at a 65 base pressure. Yes that is too high and could be the cause of the problems. I now have the pressure reduced to 48 psi. That is as low as it will go.
I will be going back down to meet Mikey this evening to wrap up my tune.
Old 06-24-2013, 12:23 AM   #1439
nattywrx
Member#: 271998
Phatbotti tuned 16GXT E85
Keep us updated!! Anxious for the results
nattywrx is offline   Reply With Quote
Old 06-24-2013, 07:22 AM   #1440
jockeygolfs
Member#: 260868
2011 STI
456 whp 434 TQ using Airboy to calculate. The gains are nice and feel amazing. My 1200's are unable to supply enough fuel to keep going. Looks like 2000's will be in my future to push this huge turbo. Gains up top compared to older graphs are very nice though. Slight shift of about 500 rpms to the right up to about 5250 RPM but then after that the car keeps going and climbs in power and tq. Ill post a graph soon.
Old 06-28-2013, 08:53 PM   #1441
jockeygolfs
Member#: 260868
2011 STI
Before graphs can be posted I have ID2000's coming . Screw it lol.
Old 06-29-2013, 01:18 AM   #1442
Jdub.csu
Member#: 283784
2013 EVO X GSR
Yay go all the way lol
Old 06-29-2013, 09:50 AM   #1443
b154wheel
Member#: 206874
2010 Impreza WRX
Old 07-02-2013, 06:39 PM   #1444
rallyknight13
Member#: 156634
2000 Fozzy S
White / Grey Met
Stock pistons look pretty decent:
That looks like an EJ22T block ?
rallyknight13 is offline   Reply With Quote
Old 07-02-2013, 06:41 PM   #1445
jockeygolfs
Member#: 260868
2011 STI
No, that is the stock Ej257.
Old 07-03-2013, 11:04 AM   #1446
M4c0770
Member#: 225851
07 Spec Wannabe
Limited in San Remo Red
He might b confusing gasket with closed deck !
M4c0770 is offline   Reply With Quote
Old 07-03-2013, 02:39 PM   #1447
Masta Splint
Member#: 189211
2005 18g WRX wagon
Looks ****ing amazingly awesome dude!!!! I love it. I want a white 13 STi so bad, gotta wait till sept. to pick mine up. Very nice ride.
Masta Splint is offline   Reply With Quote
Old 07-03-2013, 06:30 PM   #1448
jockeygolfs
Member#: 260868
2011 STI
Thank you!
Old 07-11-2013, 12:13 PM   #1449
niamh
Member#: 244433
2006 STi!!!!!!!
grey
Car sounds amazing Jockey!!
niamh is offline   Reply With Quote
Old 07-11-2013, 12:22 PM   #1450
jockeygolfs
Member#: 260868
2011 STI
Thanks
Will it fit: 2011 STi Sedan exhaust on 2010 WRX Sedan btr22 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 41 Yesterday 11:44 AM
Forged Performance: 2011 STi Sedan MONSTER Build **check back often** Forged Performance NASIOC Project Cars 461 09-10-2015 01:14 PM
Fast Motorsports Prototype 08+ wrx sedan and 2011+ sti sedan catback! first pics! IMPORTIMAGE Vendor Announcements 4 05-02-2011 10:50 PM
Comparing 2011 STi Sedan to 2011 WRX Sedan DasWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 12-21-2010 08:09 AM
new with a question about 2011 STI sedan vs. previous STI sedans tommygsubie Newbies & FAQs 37 11-02-2010 01:16 PM
