Old 08-14-2011, 03:03 PM   #1
LanceGantry
Member#: 209473
06 sti on effanolz
Juantuned
Default Beta Testing Maperformance Ball Bearing Billet 20G 430whp- Juan Tuned
Event: Road Dyno
Ambient Temp: 90
Elevation: 1000
Weather: clear
Track and Conditions: asphalt, clean, flat
Tires: 225/45/17 falken ziex
Car: 06 WRX Sti
Tuner: Juan Medina
Dyno Info: Virtual Dyno and Airboy
Transmission: 6spd
Gear: 4th
VD-Peak HP at RPM: 430whp @ 6897 RPM
VD-Peak Torque at RPM: 409wtq @ 4509 RPM
Peak HP at RPM: 400whp @ 6680 RPM
Peak Torque at RPM: 377wtq @ 4500 RPM
Baseline hp/tq for a stock on same dyno: 215whp
Target Boost: 25psi
Target AFR: 11.5
Fuel: E85
Engine/Power Modifications: Maperformance BB Billet 20g 8cm2, DeatchWerks 1100cc side feed injectors, Perrin v2 fuel rails, full 3" TBE, injen catted downpipe, Borla Hush CBE, Hallman MBC, air intake shield, Walbro 255, TGV deletes by Juan Medina, 70mm APS CAI, APS hard inlet, GT Spec gen 2 headers/uppipe, Grimmspeed PnP intake manifold, 11 STi TMIC
Driveline Modifications: ACT HD SS.
Suspension Modifications: tanabe gf 210 springs
Other Modifications: Gruppe N motor/transmission mounts, pitch stop, ss brake lines, wrx trunk swap
I decided to go big this time and see if I could get 400 whp out of the stock block conservatively and maintain my sneaky daily driver. Juan was down with the plan from day 1 and helped a ton to reach that goal. Upgraded from Blouch 18g to Maperformance 20g, 70 mm APS CAI from homemade CAI, APS turbo inlet from stock, 2011 sti tmic from 06 STi TMIC, GT Spec gen 2 headers/uppipe from stock. This goes with 1100cc DW injectors on e85. The tune is great, turbo has great spool and the car feels super smooth. Even idle and start up are nice and consistent. Power is great and immediate, numbers indicate that it makes more power every where than my 18g. The car was tuned in Hades and now that the weather is cooler, it is getting even stronger. Huge thanks to Juan and Tyler for all the help, it was definitely worth it!
week old learning view
best pulls in better conditions.
LanceGantry is offline   Reply With Quote
Old 08-14-2011, 03:05 PM   #2
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
this car is sick, it turn out awesome the response is amazing. It hits torque kind of late because is catted. Yes it has a CAT . But if you look at 3000rpm it makes more power than some VF39s on E85.
The turbo also sounds sick, here is a crappy video but you get the idea. This was on low boost 20-21psi
Huge thanks to Maperformance for letting me test this turbo, you can't beat the performance of this turbo for the money.
Old 08-14-2011, 03:28 PM   #3
bilt2run
Member#: 134211
very nice..been thinking of getting this unit or the 1.5xtr, they are similar in power but a big price difference....
bilt2run is offline   Reply With Quote
Old 08-14-2011, 04:46 PM   #4
K1WRC
Member#: 64511
2003 WRX sedan WRB
VF36 EJ207
This Internal wastegate?
K1WRC is offline   Reply With Quote
Old 08-14-2011, 10:08 PM   #5
juanmedina
Member#: 133146
Yeah I think they are really similar they are both modified 30r CHRA . With the Maperformance 20G you don't get the hard oil and coolant lines but you can modified the stock ones and they will work.
Yes sir is IWG, I don't see a need to waste money in EWG setup. Rusell the OP is suppose to get a 4 bar OMNI sensor this week. I will post high boost plots as soon as we get it. At lower boost setting it holds boost all the way and the delivery is very smooth.
On the virtual dyno graph the red line is his blouch 18g 7cm2 on E85 , you guys can see there is gains every where. Like I said before no turbo will beat this power band.
Old 08-14-2011, 11:21 PM   #6
CatfaceType-R
Member#: 81102
I hate this tuner, he is the worst tuner ever...
BWAHAAHHAHA!
CatfaceType-R is offline   Reply With Quote
Old 08-14-2011, 11:23 PM   #7
juanmedina
Member#: 133146
haha I want my popcorn back carmi
Old 08-15-2011, 12:01 AM   #8
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
Slow ! Lol
Visconti is offline   Reply With Quote
Old 08-15-2011, 06:27 AM   #9
MattPersman
Member#: 139385
good job Juan
MattPersman is offline   Reply With Quote
Old 08-15-2011, 09:20 AM   #10
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
we need to frumrol!!!
looks good
FuJi K is offline   Reply With Quote
Old 08-15-2011, 09:26 AM   #11
CatfaceType-R
Member#: 81102
Old 08-15-2011, 11:15 AM   #12
sumfoo1
Member#: 82146
2005 Legacy GT
Pump numbers ???
sumfoo1 is offline   Reply With Quote
Old 08-15-2011, 01:14 PM   #13
juanmedina
Member#: 133146
Originally Posted by [email protected] Shop CT View Post
Slow ! Lol
haha I know
Originally Posted by MattPersman View Post
good job Juan
thanks Matt
looks good
shifting and filming is kind of hard, sure Fuji
Originally Posted by sumfoo1 View Post
Pump numbers ???
I have no pump numbers but I would think you can make 370-380whp Dyno Jet with 100-200rpm later spool.
Old 08-15-2011, 01:14 PM   #14
K1WRC
Member#: 64511
2003 WRX sedan WRB
VF36 EJ207
That's awesome for IWG, rock steady at over 20psi. Definately going to be looking into this turbo once my motor finally dies. Nice to have IWG and a "stockish" turbo sitting there for CA smog inspection.
Old 08-15-2011, 05:03 PM   #15
engstb
Member#: 268737
2005 STI
I like
engstb is offline   Reply With Quote
Old 08-15-2011, 05:17 PM   #16
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
im sure the boost is solid with the hallman, but the boost curve plotted is not the actual boost curve....the stock MAP sensor pegs ~23.5 psi....thats why its a flat line at 23.5 psi
Old 08-15-2011, 06:04 PM   #17
juanmedina
Member#: 133146
this is true, thats why I said I will be posting a new graph when the OP gets his OMNI 4 bar sensor, probably this week or next week.
At 20psi and 17psi the drop on boost from peak to redline is <1psi
Old 08-15-2011, 06:06 PM   #18
Phatron
Member#: 36033
CEO PhatBottiTuning
Huge thanks to Maperformance for letting me test this turbo, you can beat the performance of this turbo for the money.
Old 08-15-2011, 06:44 PM   #19
juanmedina
Member#: 133146
stop it Ron , fixed
Old 08-15-2011, 09:12 PM   #20
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Great job tuning Juan! These MAP turbos seem pretty nice. They deff have my eye...
rexworx is offline   Reply With Quote
Old 08-17-2011, 01:50 AM   #21
blue_wrx_chic03
Member#: 34519
03 WRX
WRX blue
How much is this turbo and can you use the stock inlet?
blue_wrx_chic03 is offline   Reply With Quote
Old 08-17-2011, 02:24 AM   #22
Phatron
Member#: 36033
CEO PhatBottiTuning
Old 08-17-2011, 02:40 AM   #23
SVT_WRX
Member#: 164830
G61 III OVE 58e
SVT_WRX is offline   Reply With Quote
Old 08-17-2011, 12:38 PM   #24
Black07STiGuy
Member#: 155930
2008 WRX Josh Tuned
VF39+JoshTune=330hp/350tq
i will be getting on around tax time, thanks for these videos and results you have set my mind for me!
Black07STiGuy is offline   Reply With Quote
Old 08-18-2011, 10:59 AM   #25
juanmedina
Member#: 133146
They are amazing for the money
$1200, if you modify you hard lines and get the braided oil line with the restrictor for GT30r it will come out to about $1270. It is a great deal when ball bearing turbos out last journal bearing and also when hybrid ball bearings (ceramic cartridge) out last regular ball bearing by 3 times their life per my work experience.
I have an update for later , we installed the OMNI 4 bar sensor so I will post boost plots tonight or tomorrow. We also gained quite a few wtq and whp at 3000rpm an at redline thanks to better weather . We are going to try to run a little more boost also....
FS/FT : PT 6262 ball bearing & Billet Turbo oldman_sti Engine/Power/Exhaust 7 09-13-2011 10:25 PM
MAP Billet Ball Bearing Bolt-on Turbocharger Dyno Results Are In!!!!! maperformance Proven Power Bragging 85 07-27-2011 12:58 AM
PTE Billet Turbochargers.. IN STOCK! Journal and Ball Bearing! Built Industries Engine/Power/Exhaust 2 08-24-2009 02:08 PM
