Old 08-14-2011, 09:06 PM   #1
caperex09
Member#: 243122
Default Process West vs stock tmic
car is 09wrx at stage2. when PW was installed and dyno-tuned , result was 20wtq/20whp.
only power mod was PW tmic. anyone with same results?
caperex09 is offline   Reply With Quote
Old 08-14-2011, 09:18 PM   #2
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
No numbers but I can believe it...
wrxdrvr is offline   Reply With Quote
Old 08-15-2011, 08:51 AM   #3
sszyma
Member#: 31399
2007 WRX
2014 Forester 6MT
This is from a few years ago
I have another thread with in the power forum but here is the gist. If you look at the dyno graph the only difference between the tunes was the PW TMIC, Samco inlet, APS intake. The intake gave me a little at the top end compared to the previous tune and the inlet really didn't do much but, the increase in torque was incredible. The stock 07 wrx intercooler is very small. The 07 STi tmic would have been a small upgrade. The PW unit I believe is the perfect size for the stock turbo and a little larger. I know all dynos are different but, since I was on the same dyno and increase of 65ft/lb is pretty good for the little TD04.
Event: Retune for Stage 2
Ambient Temp: 75
Elevation: 576ft Chicago IL
Weather: Sunny
Car: 2007 WRX Wagon
Tuner: Jorge @ P&L Motorsports
Dyno Info: DYNOJET
Peak HP at RPM: 244
Peak Torque at RPM: 320
Baseline hp/tq for a stock on same dyno: Not sure, before retune 237whp/255whtq
Target Boost: 16.5 psi
Target AFR: ~11.7
Fuel: 93 Octane from BP in Chicago
Engine/Power Modifications: Maddad DP SwainTech’d, Maddad MP SwainTech’d, Prodrive Axleback, Prodrive BCS, APS 65mm intake, Samco Turbo Inlet
Driveline Modifications: Group N Bushings
Suspension Modifications: All group n bushings, koni inserts, wagon pinks, Oswald subframe and bumper beam
sszyma is offline   Reply With Quote
Old 08-15-2011, 01:15 PM   #4
tekfoc
Member#: 21392
2014 45 AMG MB
WHITE /MB C300 4MATIC
I LOVE my process west
tekfoc is offline   Reply With Quote
Old 08-15-2011, 01:20 PM   #5
Mike 01Hawk
Member#: 219162
2011 WRX Sedan Base
I'm in the same boat wanting to upgrade my '11 WRX TMIC down the road. For the money though I'd give a hard look at the Fast Motorsports FMIC, and I was never a fan of FMIC before. Funny how times change.
Mike 01Hawk is offline   Reply With Quote
Old 08-15-2011, 01:26 PM   #6
The Deliverator
Member#: 42376
2006 92x Aero
I'm quite happy with the results of my PW TMIC, too. VF39, JH2000 coated EL header, Swain coated up pipe and hot side, AVO inlet, stock intake, clark turner email protune. 9-2x Aero (wrx wagon).
On the same dyno (different day, presumably different conditions) a protuned Stage 2 + intake STI made 254whp.
Can't attribute all the difference to the PW tmic, obviously, but it certainly didn't hurt. :-D
The Deliverator is offline   Reply With Quote
Old 08-16-2011, 12:19 PM   #7
Nimbus09
Member#: 212399
09 wrx 301hp/328tq
'00 miata blue
op, you sure the boost was not just upped because the new tmic can handle it?
i can't imagine just the tmic gave you the gains. retuning it with the new tmic is a whole different story.
Nimbus09 is offline   Reply With Quote
Old 08-17-2011, 10:38 AM   #8
my name is joe
Member#: 171412
The stock 08+ sit tmic flows just as good as the pw tmic
. Tube and fin vs bar + plate. Just some info for some of the budget buyers
But of course tmic< fmic < v mount / reversed intake man w/ fmic
my name is joe is offline   Reply With Quote
Old 08-17-2011, 11:12 AM   #9
mdefalco25
Member#: 62985
2005 STi
Platnium Silver
So it sounds like to me that is TMIC (PW) Is more ideal for the WRX guys vs. STi guys? Was considering this TMIC for my 05 STi because of the splitter but on the fence with this one and the Spearco due to it's massive CFM and core size.
mdefalco25 is offline   Reply With Quote
Old 08-17-2011, 11:23 AM   #10
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Your logic is highly flawed and has zero to back it up. There are probably less than 100 V mount cars running and data from them is exactly zero.
Old 08-17-2011, 12:12 PM   #11
arf80
Member#: 125580
2011 WRX 5dr
I'm in the same boat, it's hard to find any hard data or comparisons of the stock TMIC (with reinforced end tanks) vs the various aftermarket options for the 08+ cars at stage 2. Lots of conflicting opinions, though.
arf80 is offline   Reply With Quote
Old 08-17-2011, 01:43 PM   #12
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
I like the V-mounts that some of the WRC cars run for it pulls the weight back from the nose of the car.
Would someone f'en make a FMIC that keeps the OEM beam!!!!
Someday I will open a true testing facility: dyno, full wind tunnel, temp. control, etc., and put some of this stuff more to rest.
tazswing is offline   Reply With Quote
Old 08-17-2011, 01:48 PM   #13
sumfoo1
Member#: 82146
2005 Legacy GT
http://www.importimageracing.com/p/R...1-WRX-LGT.html
its not huge but its better than a tmic and it keeps the bumper beam
sumfoo1 is offline   Reply With Quote
Old 08-17-2011, 01:49 PM   #14
nhat
Member#: 140163
03 STi
hellaflunctional
i'd rather have a big tmic.
Old 08-17-2011, 01:51 PM   #15
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
The power from that mod comes from the tune and intercooler. The intercooler alone will only net a few ponies. You really need to tune the car to take advantage of the better flow and more surface area of a bigger intercooler.
IMO. Spearco TMIC is the best bang for the buck when it comes to TMICs on the market. If a PnL rotated mount 35R car can pull big numbers and survive in Chicago stop n go traffic with a TMIC and minor heat soak, I am sure a stage 2 WRX will be mighy fine w/ the same intercooler.
DoctorNick is offline   Reply With Quote
Old 08-17-2011, 01:59 PM   #16
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
You have no proof of this, thanks for your opinion though.
Old 08-17-2011, 02:12 PM   #17
Nimbus09
Member#: 212399
09 wrx 301hp/328tq
'00 miata blue
is there an echo in here? this thread is not humongous, read before you post.
how are you making the assumption that he has not gotten retuned? is 20 "ponies" a few to you?
but then, you say "you really need to tune the car..." implying he hasn't gotten tuned?
wtf is wrong with you?
go brush up on your.... logic? thinking?
Old 08-17-2011, 02:21 PM   #18
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
I was trying to explain why the bigger IC is more adventitious.
Some people bolt on parts and assume the ECU will be able to handle it.
Old 08-17-2011, 02:48 PM   #19
nhat
Member#: 140163
03 STi
hellaflunctional
a lot of people on this forum do a lot of dumb things to their cars.
brush up on your logic or thinking otherwise you'd be just as dumb as them for making assumptions about what others have done with their car.
Old 08-17-2011, 02:51 PM   #20
Nimbus09
Member#: 212399
09 wrx 301hp/328tq
'00 miata blue
since you're a mod, i'll be nice.
i asked a question. the other guy made the assumptions.
Old 08-17-2011, 02:57 PM   #21
sumfoo1
Member#: 82146
2005 Legacy GT
you are correct, i have no proof but i do have logic and a general knowledge of airflow thats significantly better than average.
Well for the WRX guys the PW intercooler may be better it is a thicker core and they get plenty of airflow through their scoop.
But the FMIC won't heat soak at from engine heat when at a stoplight and the core is bigger than most other TMICs.
I'm sure it gets at least as much airflow as the scoop and we know the engine fans will keep air from becoming stagnant behind the bumper like it does on top of the engine.
I'm not going to lie the core of that intercooler its-self is not my favorite and i think i'd probably change it out but the piping etc is pretty impressive to be able to keep stock intak and stock bumper beam as well as foglights etc.
You'll also have to forgive me as i drive a legacy and my scoop is significantly tinier than the 08+wrx scoop.
but, being a fmic it will be plagued by "rich dip" unless the ecu is converted to speed density.
Is that better?
Old 08-17-2011, 02:59 PM   #22
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
i haven't made assumptions, you idiot. i asked a question to clear things up.
the other moron made the assumption.
dumb****s everywhere!
Dude. Walk away from the computer for a second
Old 08-17-2011, 03:01 PM   #23
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Nope. A FMIC can and does heat soak and a TMIC if shielded with $40 turbo wrap it will not. The problem with the TMIC vs. FMIC debate is there is no proof from either court, just people who spout ideas and opinions which mean zero as none of us has access to a windtunnel or wants to do efficiency testing.
Old 08-17-2011, 03:04 PM   #24
mdefalco25
Member#: 62985
2005 STi
Platnium Silver
This is why I have been favoring the Spearco for my STi but was curious to what others thought due to the splitter for the PW.
Old 08-18-2011, 09:53 AM   #25
BDP
Member#: 275256
I've been looking at the AVO TMIC for my 2011. With no plans on going past a STG II and tune it seems like a good choice. Having owned multiple boosted VW's and having swapped out crappy SMIC's in them. I know how important an upgraded intercooler is not only keeping things safe but heat soak in the summertime.
Largest factor for me besides cost is ease of installation on a TMIC versus a FMIC.
BDP is offline   Reply With Quote
Perrin vs Process West TMIC Bean-Counter Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 98 04-27-2011 11:22 AM
process west vs sti tmic alphaomega0 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 05-10-2009 11:10 AM
STI TMIC Vs Process West TMIC snowmanwrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 02-01-2009 11:54 AM
