Old 08-15-2011, 02:54 AM   #1
bmxpunk
Member#: 89599
1995 almost 22B:)
red
Default EJ20g wired 95 intermit run/fuel pump relay clicking
Very strange problem.
My 95 impreza is wired as an wrx with an ej20g and I am currently running Rob's 550 tune. Car ran fine for 2 years, and I recently started stripping the wiring harness of anything not needed (cruise control, airbag, radio) as this is a rally car.
The car ran perfectly for 1.5 months after stripping the harness then one day at the dairy queen drive up window a relay under the dash (later found to be the fuel pump relay) starts clicking and the car dies and won't start.
Got the car back to my house and it started and idled for 5 minutes then the clicking and returned and it would die. I turned the key to start it again and the wastegate solenoid starts clicking, and the fuel pump won't run. Does this for the next few minutes while I continue to try starting. Then the fuel pump runs, car starts, idles, dies, and the wastegate solenoid starts clicking again.
I have the entire harness out of the car tonight and I have been going through each circuit testing continuity and they all seem to be perfect.
the systems that I stripped off the harness came off complete so I don't have any powers or grounds that aren't accounted for. Anyone have any ideas?
bmxpunk is offline   Reply With Quote
Old 08-15-2011, 07:21 AM   #2
peanutswagon
Member#: 197057
1997 98 Foz V3 swap
Bump for my man. Good question
peanutswagon is offline   Reply With Quote
Old 08-15-2011, 08:20 AM   #3
eg33GC
Member#: 206851
56 Belair
Pro Street
ground the main and fp relay straight to the car, see what taht gives you
eg33GC is offline   Reply With Quote
Old 08-15-2011, 09:06 AM   #4
suberdave
Member#: 101865
88 GL-10 STi
Sounds like a grounding problem... you have to test it in the car, not on the bench. try doing voltage drops not resestance checks, to check the wiring.
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 09-18-2011, 12:15 PM   #5
bmxpunk
Member#: 89599
1995 almost 22B:)
red
I sent my ecu to omahasubaru to try out while I redid some of my wiring. His car started to do the same thing once he plugged in my computer. So now we have to figure out if something went wrong in the ecu.
In the mean time, does anyone know where I can get replacement terminals for the subaru connectors? I have all of the wiring out of the car and I want to replace some of my spliced wires with just 1 piece of wire.
STi ver3 to 2000 RS: Fuel pump relay wire? DeusExMachina Subaru Conversions 9 08-15-2014 03:39 PM
need fuel pump and fuel pump relay 4/18/10 raceckr MWSOC Private Classifieds 1 04-18-2010 03:05 AM
Fuel Pump Relay Control and Airconditioner Cut Relay Control modifiedauto Newbies & FAQs 0 09-19-2007 08:43 PM
Fuel Filter replacement - where is fuel pump relay? SeenDubAYouAreEx Newbies & FAQs 4 07-11-2007 09:29 PM
2.5RS no spark...fuel pump relay clicking polak13 Normally Aspirated Powertrain 8 01-26-2006 03:25 PM
