Go Back   NASIOC > NASIOC Technical > NASIOC Project Cars
Old 11-11-2009, 07:00 PM   #1
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
Default HOW TO: Prova Steering Wheel 2008+ WRX/STI
This is a detail how to install of the Prova D Series Steering wheel for the 2008+ WRX/STi Models. The install will be identical to also the O series.
Innovation is steering wheel design has never felt so good. Prova is proud to announce the new series of OEM replacement steering wheels that allow you to retain all the factory comforts and safety benefits, while getting a sporty and comfortable steering wheel.
Features a Micro Suede and Alcantara wrap to give you a feel that you never want to let go. Not only comfortable, soft, and good looking, these materials are durable as well.
Allows you to retain the Factory air bag, stereo controls, and Cruise Control.
Direct factory replacement means you do not need any hub adapters to make this fit.
358mm (14.1") diameter, compared to the OEM 375mm (14.75"). Giving you a sporty feel that is much more enjoyable to hold.
WARNING: If you are not familiar with SRS AirBag system, please have a professional install this. Neglect to do so can cause serious injury and or death.
Time for install: 20min-1hr depending on skill level
Tools Needed:
Small Flat head screwdriver/pick
Phillips screwdriver
T30 Torques bit
17mm 1/2" drive 6 Point Socket
10mm socket/wrench
1) Disconnect one of the batteries Terminals from the Battery. Using a 10mm Socket/Wrench
2) Get in the car and press on the brakes to use up the remaining voltage that might be stores in some electronic devises.
3) Grab the T30 Torques bit and use it to loosen the airbag from the steering wheel skeleton. The bolts will be on the left and right side of the steering wheel. One on each side
RallySport Direct is offline   Reply With Quote
Old 11-11-2009, 07:01 PM   #2
RallySport Direct
Member#: 33174
We are Open Late!
4) Once the hardware is loosened, proceed to slowly pull the airbag out of the steering wheel.
As you can see the airbag is still connected electronically, so be careful.
5) Look on the back side of the airbag and you will see 2 clips. Get the pick or the small screw driver and pop up the center section. Do this to both clips.
6) Once the clip is popped up pull on the connector and disconnect it from the airbag. Do this to both connectors.
7) Then find the gray wire and push in the small metal tab, and pull up on the tab itself to disconnect it from the back side of the airbag.
After This the airbag unit can be taken out of the steering wheel.
8) Once the airbag is out, proceed to take out the white clip. This has a small tab on top that needs to be pressed down and then the connector will come out.
9) Move the steering wheel at this point to lock it in place. This will allow you to loosen the nut with out having the wheel move. Take the 17mm (MAKE SURE ITS A 6 POINT) socket, and remove the nut the hold the steering wheel to the steering linkage.
10)
BE AWARE! MAKE SURE THE CLOCK SPRING DOES NOT MOVE WHEN YOU REMOVE THE STEERING WHEEL!
Once the nut has been removed, proceed to wiggle the steering wheel towards and away from you until it comes off the shaft. This will take a little effort, but does not require a puller. Once the wheel is off proceed to move the connectors out of the way and take the steering wheel off.
Old 11-11-2009, 07:01 PM   #3
RallySport Direct
Member#: 33174
We are Open Late!
11) Once the wheel is off, proceed to take the Phillips screw driver and remove the 2 bolts that hold the back side plastic cover off the wheel.
12) On the bottom of the wheel, a C shaped brackets hold the bottom of the back cover to the steering wheel. Apply slight pressure to each one and spread them to pop the back cover off.
13) Proceed to lift up the rear cover to get access to the 2 bolts that hold the controls pieces on for the Radio and for the Cruise Control.
14) Get the Phillips screw driver and remover these bolts.
15) Once the bolts are removed, proceed to take remove the controls off the steering wheel.
OEM Next to the Prova D Shape
The way the image was taken it makes them look the same size. However the Prova is Smaller.
Old 11-11-2009, 07:02 PM   #4
RallySport Direct
Member#: 33174
We are Open Late!
16) Put the side controls into the new Prova Wheel, and reinstall using the same hardware as you took off.
17) Realign the back cover plastic piece and re-secure the lower C clip around the wheel.
18) Get the 2 bolts that hold the backing cover and re-secure them to the wheel.
19) Once all the small bolts have been secured, put the steering wheel on the shaft. Make sure to allign the 2 plastic pins with the holes in the steering wheel. These are your automatic blinker return along with steering wheel angle sensor, and also a way to make sure you put the wheel back into the same position as you took it off. Once aligned use some force to gentle push the steering wheel onto the shaft.And get it to sit down as much as you can.
20) Reconnect the white clip, by just pushing it in. If its taking allot of effort, you might have the clip upside down. You will hear a small clicking noise when it goes in.
21) Proceed to hand tighten the nut, to prevent any cross threading.
Followed up by torquing it down to 45newtons/meter (or about 38ft/lbs)
Old 11-11-2009, 07:03 PM   #5
RallySport Direct
Member#: 33174
We are Open Late!
22) Reconnect the airbag connectors and push in the center clips.
23) Reinstall the Gray wire by pushing it onto the connector.
24) Get the airbag and place it in the steering wheel, proceed to get the T27 Torques fitting and HAND tighten both sides of the airbag into place on the steering wheel.
25) Once hand tighten. Grab the airbag with your hands and genteelly tug on it to make sure that both bolts are secured into the wheel. If secured proceed to tighten both Torques bolts down.
26) Double Check to make sure that everything is secured. Grab the wheel and make sure there is no abnormal play in it. This should be just as rigid as the stock unit.
Old 11-11-2009, 07:03 PM   #6
RallySport Direct
Member#: 33174
We are Open Late!
27) Reconnect the battery.
28) Start the car and make sure that the SRS airbag light turns off as normal. If it stays on, you made a mistake and MUST address it prior to driving the car.
29) Enjoy the new Prova Steering wheel!
Please post up if you have any questions or concerns regarding this install.
Kirill
RallySportDirect.com
801-748-4910 ext 1006
RallySportDirect.com is in no way shape or form responsible for any damages or injuries that might occur during or do to the install of this product or do to the how to. This is a how to write up, that should be used in conjunction with the OEM manual, and should only be performed by a professional.
Old 11-14-2009, 11:54 PM   #7
nairbmik
Member#: 220259
09 2.5i
SSM
Wow, what a tutorial. I wish all how-to guides were as detailed as this!
nairbmik is offline   Reply With Quote
Old 11-21-2009, 07:03 PM   #8
Shohin
Member#: 170188
2016 STI Limited
will this also work for an 08 WRX (note: I have the prem. pkg. with the same steering wheel controls)?
Shohin is offline   Reply With Quote
Old 11-23-2009, 11:37 AM   #9
RallySport Direct
Member#: 33174
We are Open Late!
Yes it should. Subaru is very consistent from vehicle to vehicle as far as how the items are actually hooked up.
Old 11-23-2009, 07:19 PM   #10
rallyracersti
Member#: 147522
2015 wrx
Wrb
that thing looks badass
rallyracersti is offline   Reply With Quote
Old 11-23-2009, 07:37 PM   #11
wantsti
Member#: 134764
04 sti
java black pearl
On step 9 and 10 You should leave the nut on the last few threads when trying to loosen the steering wheel so you don't yank it off and ruin your clock spring wires.
just a suggestion.
wantsti is offline   Reply With Quote
Old 11-23-2009, 07:59 PM   #12
andrewhans
Member#: 154128
1987 Volvo 240DL
Red
any interest in doing replacement steering wheels for the older subies as well... im sure many would be interested
andrewhans is offline   Reply With Quote
Old 11-23-2009, 08:28 PM   #13
Imprezzedwitsubies
Member#: 216116
2015 BRZ Limited
14' Triumph America
If I could afford that I would get it lol. Nice wheel!
Imprezzedwitsubies is offline   Reply With Quote
Old 11-28-2009, 12:55 PM   #14
Krondor
Member#: 187845
2008 STi
Just added to my buy list. As soon as I find a Black Alcantara Dash Cover with matching red stitch. Very nice thank you for the option.
Krondor is offline   Reply With Quote
Old 01-02-2010, 09:36 AM   #15
Cdn 2.5i
Member#: 109912
2005 Legacy 2.5i 5dr
Yes, +1 excellent walkthrough.
Cdn 2.5i is offline   Reply With Quote
Old 01-03-2010, 06:15 PM   #16
Dubya R Ex
Member#: 119223
2006 WRX
I shall say it again, i demand you make prova make them for the 04-07 subies! I DEMAND SATISFACTION!
Dubya R Ex is offline   Reply With Quote
Old 01-04-2010, 01:17 PM   #17
RallySport Direct
Member#: 33174
We are Open Late!
We have seen people actually get these to fit the GD's. However it wasnt 100% perfect fit.
Old 01-07-2010, 05:37 PM   #18
Dubya R Ex
Member#: 119223
2006 WRX
Im sure it can be done, but I just don't understand why they wouldn't want to make them, its not like there wouldn't be a market for them.
Old 01-07-2010, 06:04 PM   #19
RallySport Direct
Member#: 33174
We are Open Late!
We ran the idea by them, and that is something they where not interested into doing right now. With the release of the new 2010 Legacy, they have been busy doing R&D with that car.
Old 01-07-2010, 06:14 PM   #20
Dubya R Ex
Member#: 119223
2006 WRX
i heard damd is coming out with some for our years? Any truth behind that?
Old 01-07-2010, 06:20 PM   #21
RallySport Direct
Member#: 33174
We are Open Late!
We do not deal with DAMD, only Prova. So I do not have info about their product line
Old 01-07-2010, 07:31 PM   #22
J-Rod 555
Member#: 209231
2008 WRX, 95 leggy
White to the both of them
^^^ look on the PROVA wheel it says DAMD...
J-Rod 555 is offline   Reply With Quote
Old 01-07-2010, 08:38 PM   #23
RallySport Direct
Member#: 33174
We are Open Late!
Correct. But DAMD Makes them for Prova. But we deal with Prova and not DAMD. Prova has said they have no plans to release a GD wheel. If DAMD does, it does not always mean that Prova will.
Subaru Made the S204 in Japan, but we only got the STi.
Old 01-07-2010, 09:23 PM   #24
J-Rod 555
Member#: 209231
2008 WRX, 95 leggy
good looking, I drive a GH8 so I don't care too much if they release a gd steering wheel...
Old 01-28-2010, 11:20 AM   #25
Dubya R Ex
Member#: 119223
2006 WRX
but if damd releases them for the GD you guys better as well
How To: 2008 WRX/STi Coilover Install RallySport Direct NASIOC Project Cars 40 08-11-2014 05:53 PM
How To: Change a power steering pump on WRX/STi Gamble_WRX Service & Maintenance 23 04-06-2013 08:22 AM
How To: Prova Air Oil Separator RallySport Direct NASIOC Project Cars 52 10-12-2010 10:26 AM
sparco steering wheel adapter wrx sti bootman Interior/Dressup/Audio & Security 1 07-07-2009 03:10 AM
Spec C MY06 steering wheel on WRX/STI 02.. How? alfo40 Interior & Exterior Modification 6 03-06-2006 10:14 AM
